Galant VR-4 Forums » Galant VR-4 » Technical Discussions » Curtting springs.
Curtting springs.
91Vr4white
Galant VR-4 org Post #: 1117159 posted 04/07/13 01:01 PM     Remind Me!  Send Private Message   Edit Post
Is anyone running cut springs on the rear of their galant? Has anyone done this? Not looking for speculation only actual experiences.
I'm looking to cut about a coil off to make the car sit level. I've searched and can't find hardly any info on this. I've seen a few guys talk about cutting aftermarket springs but not stock.
For those that have. How much did you cut off an how much did ride quality suffer?
Posts: 26 | From: Owensboro, KY | Member Since: 03/30/13 | IP: (166.205.55.22) | Report this post to a Moderator
GeezyE39A
Galant VR-4 org Post #: 1117160 posted 04/07/13 01:10 PM     Remind Me!  Send Private Message   Edit Post
Cutting springs is by far the worst thing you could do , it has a massive effect on ride quality, spring rate , reduce the overall effectiveness of your suspension and not to mention its so easy to mess up
I have bought a car on time with cut springs , it was horrible experience and so I bought coil overs asap. I suggest the same to you
| | | IP: (208.54.85.149) | Report this post to a Moderator
91Vr4white
Galant VR-4 org Post #: 1117163 posted 04/07/13 01:18 PM     Remind Me!  Send Private Message   Edit Post
I've cut springs on so many cars I cannot keep track. An you are right... To a point. But if its done mildly there is very minimal noticable difference.
I'm not talking about slamming the car but only leveling out the rear. I know one of you have done this.
Posts: 26 | From: Owensboro, KY | Member Since: 03/30/13 | IP: (166.205.55.37) | Report this post to a Moderator
blacksheep
Baraqsheep
205/1000
Galant VR-4 org Post #: 1117167 posted 04/07/13 01:50 PM     Remind Me!  Send Private Message   Edit Post
On progressive springs, you can cut some of the dead coils off - I know for the gvr4 - you can cut the H&R springs by 1 coil max and lose no peformance or ride quality.
1992 Galant VR-4. 205/1000. Nile Black. Sunroof.
Posts: 15473 | From: Urbandale, Iowa 50323 | Member Since: 05/01/02 | IP: (50.81.220.243) | Report this post to a Moderator
raptorWagon
1350/2000
362/1000
Galant VR-4 org Post #: 1117173 posted 04/07/13 02:29 PM     Remind Me!  Send Private Message   Edit Post
Quoting 91Vr4white:
All of us that have or are running modified Evo 8/9 suspension, had to cut coils unless they run aftermarket Evo lowering springs.
As mentioned, there is a right way and wrong way to cutting springs.
92 Galant VR-4 362/1000
76 Galant Hardtop
79 Galant Sigma Wagon
88 Fiji Blue Starion
94 Montero SR
Posts: 2793 | From: Oak Harbor, WA | Member Since: 05/17/07 | IP: (67.183.68.117) | Report this post to a Moderator
91Vr4white
Galant VR-4 org Post #: 1117189 posted 04/07/13 04:41 PM     Remind Me!  Send Private Message   Edit Post
So no one had done this on stock suspension? Not even tried it? I just want to get rid of the rake.
I'm on a budget. I just got the car and it needs struts bad. So I was hoping I could so this while I was changing struts for cheep. I've looked bad can't find any used sprigs and from what I've read it seems even with lowering springs the car will still sit higher in the rear then in front. The car is not an auto cross car and I can live with a little bit of a rough ride, I just want to find someone who has done this or tried it. With good or bad results just looking for real world info.
As I said before I'm talking about maybe a coil not cutting the shit out of the spring.
Someone please give me a good cheap way to level this car out. Thanks
Posts: 26 | From: Owensboro, KY | Member Since: 03/30/13 | IP: (166.205.55.25) | Report this post to a Moderator
715/1000
1284/2000
Galant VR-4 org Post #: 1117267 posted 04/08/13 08:37 AM     Remind Me!  Send Private Message   Edit Post
buy some evo rear springs. They will lower the ride. Also way stiffer, makes it tail happy.
#1284/2K NB, Totaled
#715/1K KG, Rebuilding
02 Acura TL daily duty unit
12yr+ Vr4 owner.
Honda/Acura master tech.
Family Guy
mikus
weiterhin das Huhn f#$k
1994/2000
Galant VR-4 org Post #: 1117287 posted 04/08/13 11:14 AM     Remind Me!  Send Private Message   Edit Post
You might hear 1, maybe 2 real-experience opinions on cutting stockers if any at all.
Go for it, you sound like you know what to do and what to expect. It's free, easy, and if you mess them up I'm sure someone here has some stockers sitting on a shelf anwyay.
Posts: 2763 | From: Aurora IL | Member Since: 01/11/07 | IP: (198.178.234.30) | Report this post to a Moderator
Barnes
Firechicken
908/1000
237/2000
Galant VR-4 org Post #: 1117312 posted 04/08/13 02:02 PM     Remind Me!  Send Private Message   Edit Post
I have 1g TEL springs on AGX's. I cut the front springs a coil or so to even things out. Feels fine to me. (Well, as fine as it can ride on AGXs that is.)
-Jon Barnes
#580/2000 (Long Gone)
#908/1000 Black (Sold)
#237/2000 White
Posts: 6249 | From: Richland, WA | Member Since: 02/09/03 | IP: (198.232.211.130) | Report this post to a Moderator
Galant VR-4 org Post #: 1117354 posted 04/08/13 04:44 PM     Remind Me!  Send Private Message   Edit Post
Same as Barnes, but GR2s. I cut the front springs and ground the ends. They work great (but they are a higher spring rate than stock springs, so the cutting effect would actually be slightly greater).
91 VR4 855 Nile Black
92 VR4 828 Belize Green-SOLD
91 VR4 115 Nile Black -SOLD
Posts: 10842 | From: Michigan | Member Since: 03/05/01 | IP: (12.1.210.228) | Report this post to a Moderator
91Vr4white
Galant VR-4 org Post #: 1117378 posted 04/08/13 07:59 PM     Remind Me!  Send Private Message   Edit Post
Screw it I'm going to try it. Anyone have a pair of stock springs they want to donate incase this doesn't work out? Lol
Posts: 26 | From: Owensboro, KY | Member Since: 03/30/13 | IP: (166.205.55.36) | Report this post to a Moderator
CutlassJim
poop load of room
1799/2000
1788/2000
935/1000
912/1000
Galant VR-4 org Post #: 1117397 posted 04/08/13 10:30 PM     Remind Me!  Send Private Message   Edit Post
Quoting prove_it:
I have a set of stock Evo 9 springs taking up space in my basement if you want them cheap. I've also cut springs and not had any adverse effects. They don't make lowering springs for an Expo so I cut my stockers 1/4 coil at a time until it sat level with the lowered front. The key is to use a blade and not a cut-off wheel. Heat kills spring steel. It will also raise the spring rate of the spring.
I love my crazy mother!!!
Posts: 1678 | From: Manchester, NH | Member Since: 07/17/06 | IP: (75.69.152.105) | Report this post to a Moderator
91Vr4white
Galant VR-4 org Post #: 1117399 posted 04/08/13 10:36 PM     Remind Me!  Send Private Message   Edit Post
How much will the Evo springs drop it with a stock replacement strut? Email me [email protected]
Posts: 26 | From: Owensboro, KY | Member Since: 03/30/13 | IP: (76.182.155.26) | Report this post to a Moderator
0 registered and 26 anonymous users are browsing this forum.
Generated in 0.077 seconds in which 0.056 seconds were spent on a total of 14 queries. Turbo powered.
