Galant VR-4 Forums » Galant VR-4 » Technical Discussions » Calling all cars...
Calling all cars...
James
Does lots of head
Galant VR-4 org Post #: 1080403 posted 08/11/12 06:54 PM     Remind Me!  Send Private Message   Edit Post
Yes, this is about idle problems, but it's past the basics now...
Well I've reached the end of my line on stopping the galant from dying at idle when it reaches temp.
I have no vac/boost leaks that I can see or hear. (using soapy water ect)
I rebuilt the TB.
3in exhaust no cat magnaflow muffler
Boost gauge, running boost off wastegate pressure (10lbs)
I've essentially replaced everything on the intake side, from the Jpipe up to the intake Mani gasket.
ISC/TPS are In spec, no cels
The car runs fine at cool temps, I assume the ISC is doing its job correctly. When the car reaches temp, or aprox 8 miles worth of driving, the idle will begin to falter when I push in the clutch, say to put it in N for a stoplight.
If I I turn the car off, say to go into a store, when I come out she runs fine, till the temp is back up and the same issue repeats itself. Here are some videos to depict what's happening.
I'm I'm need of obscure help, because the basic vac leak/FIAV/ISC answers aren't going to cut it anymore.
First video here is showing the fresh cool motor idle, with a few second of exhaust.
Second video is me at a stoplight/sign with my lame issue, I blip the gas up to 1500 for a second, and the end I'm trying to hold it around 8-9
Third video is me coasting down a side street in neutral, showing the same. The. A small third gear pull
I swear this has to be something temperature related. Maybe computer related? Could it be the ECU? I don't have another one to swap out and see.
She was playing nice when I took the videos and didn't die at all, just faltered. Usually she will bounce down once or twice then die on the third try. It's quite embarrassing really.]
1990 Summit White Galant GSX
Chipped EPROM ECU/2g maf/550cc injectors/3in exhaust /E316G/FMIC/Wally255/AeromotiveAFPR/lower shores MBC
Posts: 1322 | From: Port richey Florida | Member Since: 04/08/12 | IP: (198.228.200.20) | Report this post to a Moderator
JamesFoster
Infamous BMX Master
666/666
Galant VR-4 org Post #: 1080414 posted 08/11/12 08:30 PM     Remind Me!  Send Private Message   Edit Post
Is your BOV recirculated?
Does not exist and that is all that ever will be.
Posts: 583 | From: ALL | Member Since: 10/14/08 | IP: (166.137.88.41) | Report this post to a Moderator
James
Does lots of head
Galant VR-4 org Post #: 1080437 posted 08/11/12 11:46 PM     Remind Me!  Send Private Message   Edit Post
Yes
Posts: 1322 | From: Port richey Florida | Member Since: 04/08/12 | IP: (198.228.200.28) | Report this post to a Moderator
Noobsauce
1865/2000
Galant VR-4 org Post #: 1080438 posted 08/11/12 11:52 PM     Remind Me!  Send Private Message   Edit Post
Do you have link? If so post a log of the intake and coolant temps.
Posts: 159 | From: Beaverton, Oregon | Member Since: 04/07/12 | IP: (24.21.177.205) | Report this post to a Moderator
Hard Snarker
1051/2000
Galant VR-4 org Post #: 1080439 posted 08/11/12 11:53 PM     Remind Me!  Send Private Message   Edit Post
Try a different ECU just in case. It could be the ISC drivers.
-Mark
1051
Posts: 11965 | From: Yakima, WA | Member Since: 04/29/01 | IP: (68.185.43.218) | Report this post to a Moderator
James
Does lots of head
Galant VR-4 org Post #: 1080440 posted 08/12/12 12:17 AM     Remind Me!  Send Private Message   Edit Post
I don't have anything to log with :/ I bought a palm logger from a member here but it didn't work when I plugged it in.
I'm also at a Loss as to how to fix that. But that's another day.
I don't have a different ECU, and the only local DSMer uses an AEM brain.
If someone has a ECU they would like to send me to test that would be great. Obviously I'll play shipping both ways.
Posts: 1322 | From: Port richey Florida | Member Since: 04/08/12 | IP: (198.228.200.29) | Report this post to a Moderator
Noobsauce
1865/2000
Galant VR-4 org Post #: 1080454 posted 08/12/12 02:17 AM     Remind Me!  Send Private Message   Edit Post
Have you tested the coolant temp sender on the t stat housing?
DynastyLCD
Dissapointing Member
73/1000
881/1000
Galant VR-4 org Post #: 1080458 posted 08/12/12 03:39 AM     Remind Me!  Send Private Message   Edit Post
ive got an idea for you. let the car get fully up to temp, turn on all the lights and highbeams, fan motor for your heat/AC, radio, etc. with it warmed up, adjust that BISS screw til you can idle at 850 - 1000.
i've seen alot of people set it improperly, where they will set it to idle low (750 - 850) with no lights or any electrical load on. but then as soon as you hit the lights and the radio, etc, wants to die cause the idle drops off too low.
- Phil
'92 Galant VR4 - 881/1000 - 2.0/FPgreen daily
'92 Eagle Talon TSi - 2.3/3052/1600's/killmode.
'05 Honda TRX450r - pack-a-punched woods weapon
You call down the thunder, and i'll reap the whirlwind.
Posts: 761 | From: Harwinton, CT | Member Since: 05/12/06 | IP: (75.9.132.108) | Report this post to a Moderator
138/2000
152/1000
Galant VR-4 org Post #: 1080468 posted 08/12/12 06:01 AM     Remind Me!  Send Private Message   Edit Post
^ yup... this or the ecu idea would be the best guesses.
138/2000
152/1000
Posts: 3675 | From: Klamath Falls, Or | Member Since: 07/27/11 | IP: (70.44.237.230) | Report this post to a Moderator
James
Does lots of head
Galant VR-4 org Post #: 1080472 posted 08/12/12 08:02 AM     Remind Me!  Send Private Message   Edit Post
It's not the biss I know that, the idle is properly set. I'll check the coolant sensor, I assume I can find the info on vfaq.
Posts: 1322 | From: Port richey Florida | Member Since: 04/08/12 | IP: (198.228.200.16) | Report this post to a Moderator
LIV4PSI
dyslexic 1051
1501/2000
Galant VR-4 org Post #: 1080485 posted 08/12/12 10:23 AM     Remind Me!  Send Private Message   Edit Post
I would at least check the caps on your ECU. If it hasn't been rebuilt it, I'm sure it needs to be soon.
-Craig
1501 Build Thread
Posts: 1762 | From: O-H-I-O | Member Since: 11/24/11 | IP: (151.213.71.56) | Report this post to a Moderator
James
Does lots of head
Galant VR-4 org Post #: 1080486 posted 08/12/12 10:42 AM     Remind Me!  Send Private Message   Edit Post
The ECU is clean. I posted a thread about my ECU about a month ago. Found out its a clean 92 eagle talon 5 speed non EPROM ECU.
Apparently my multi isn't in my car, so I'll have to wait till tomorrow after work to check the coolant sensor.
Edited by James (08/12/12 10:44 AM)
Posts: 1322 | From: Port richey Florida | Member Since: 04/08/12 | IP: (198.228.200.25) | Report this post to a Moderator
ktmrider
Cool Guy Crowd
Galant VR-4 org Post #: 1080488 posted 08/12/12 11:13 AM     Remind Me!  Send Private Message   Edit Post
James I realize you bought a logger however you NEED to get some type of real-time measurement device. You'll continue to go round-round on the site til then.
Did you ever bypass the FIAV ( just FIAV and not the ISC )? Can't see that in any of your posts. Also the suggestion about another ECU is sound too, so many ECU ISC drivers get damaged by even a slightly bad ISC. Logger will also tell you what your ISC duty cycle is at, another great way to tell the health of your ECU.
Mike O.
#464/1000 - Sold
05 Legacy GT - slush box
#86/2000 - Sold ( again )
Posts: 3121 | From: Portland, OR | Member Since: 09/10/07 | IP: (68.42.40.118) | Report this post to a Moderator
James
Does lots of head
Galant VR-4 org Post #: 1080493 posted 08/12/12 11:40 AM     Remind Me!  Send Private Message   Edit Post
Trust me I want to be logging, I didn't want to throw away $80 to get a logging setup that didn't work.
But the palm won't connect with my car. I think it has something to do with the car being a galant GSX, maybe the wiring in the diagnostics port is slightly different.
The TB is blocked off, FIAV only, ISC still functional.
If someone has a extra ECU they don't need then send it to me to test with! I'll pay shipping
Both ways. But sadly port richey Florida is the home of non turbo old people cars. I don't have 10 Dsm buddies I can call up to swap ecus with.
Posts: 1322 | From: Port richey Florida | Member Since: 04/08/12 | IP: (198.228.200.32) | Report this post to a Moderator
James
Does lots of head
Galant VR-4 org Post #: 1080677 posted 08/13/12 01:53 PM     Remind Me!  Send Private Message   Edit Post
I'll be checking the coolant today after work. And I'm picking up a timing light to check my base timing, since I never did it when I bought the car.
James
Does lots of head
Galant VR-4 org Post #: 1080703 posted 08/13/12 04:28 PM     Remind Me!  Send Private Message   Edit Post
The voltages from the coolant plug ad sensor are so far off that I think I'm doing it wrong.
I'm not seeing anything on the sensor side with ohms, and I'm seeing 50v +\- on the plug side.
Edited by James (08/13/12 05:50 PM)
Posts: 1322 | From: Port richey Florida | Member Since: 04/08/12 | IP: (173.169.249.157) | Report this post to a Moderator
James
Does lots of head
Galant VR-4 org Post #: 1080706 posted 08/13/12 05:04 PM     Remind Me!  Send Private Message   Edit Post
eh the voltmeter was on millivolts or something i guess when i saw the 50. i couldnt get any reading on the correct setting. my stepdad lost the set of grounding wires i had made up so i cant ground out the timing plug to check my base timing.
all in all im done for the time being. its a thousand degrees outand im tired of something so simple like a bad idle getting the better of me when ive been around this platform for so long. ill just learn how to work the brake and the gas at the same time when im coming to a stop to keep the car from dying.
James
Does lots of head
Galant VR-4 org Post #: 1081338 posted 08/17/12 12:39 PM     Remind Me!  Send Private Message   Edit Post
Got the coolant temp sensor replaced today (thanks Jnr). But it didn't fix anything, the sensor was bad though so I'm sure I'll probably get some better gas mileage!
Only thing left is ECU I think...
Posts: 1322 | From: Port richey Florida | Member Since: 04/08/12 | IP: (198.228.200.26) | Report this post to a Moderator
doelcow
575/1000
Galant VR-4 org Post #: 1081413 posted 08/17/12 08:09 PM     Remind Me!  Send Private Message   Edit Post
Make sure you don't have any air pockets in your coolant. I know it sounds crazy but... it can mess with your idle.
Just took the insurance off of 832... was told that it was the 27th car I have insured..
Hitler's Galant VR4
Posts: 35 | From: Norfolk, VA | Member Since: 09/14/10 | IP: (72.218.238.90) | Report this post to a Moderator
James
Does lots of head
Galant VR-4 org Post #: 1081432 posted 08/17/12 10:47 PM     Remind Me!  Send Private Message   Edit Post
I'm pretty sure I got all the air out, though again I don't think that ls something that would only cause this to happen when hot.
I'm driving down to ft Myers for the weekend and I'll be meeting a DSM buddy down there. He has a extra ECU and has link so we will not only be trying a good ECU, but getting some logging done also! (assuming it connects with the car, unlike mine).
Posts: 1322 | From: Port richey Florida | Member Since: 04/08/12 | IP: (198.228.228.27) | Report this post to a Moderator
theevozero
Member +
480/2000
Galant VR-4 org Post #: 1081524 posted 08/18/12 03:09 PM     Remind Me!  Send Private Message   Edit Post
Crankwalk. All the 6 bolts I've seen that die when you push the clutch in, had crankwalk. The failed thrust bearing put a huge load on the engine when you press 2100-2600 lbs of pressure on it.
L1, Diesel ASE Master
1991 Gvr4 480/2000 290k miles.(garage queen, race car)
1998 Integra LS, (nice suspension) daily duty.
2009 GMC Sierra 1500 Denali AWD
2000 Volvo S70 T5, 5 speed(fun project #2)
Posts: 331 | From: Odessa, Texas | Member Since: 10/12/11 | IP: (12.203.48.130) | Report this post to a Moderator
doelcow
575/1000
Galant VR-4 org Post #: 1081589 posted 08/18/12 08:32 PM     Remind Me!  Send Private Message   Edit Post
Why would it be fine cold then?
Hitler's Galant VR4
James
Does lots of head
Galant VR-4 org Post #: 1081610 posted 08/18/12 11:27 PM     Remind Me!  Send Private Message   Edit Post
Yes.... It's crank walk.... Just like the guy who blew his motor because he didn't have a oil filter... That was crank walk also. Trying a new ECU tomorrow. I'll update then!
Posts: 1322 | From: Port richey Florida | Member Since: 04/08/12 | IP: (198.228.228.31) | Report this post to a Moderator
theevozero
Member +
480/2000
Galant VR-4 org Post #: 1082270 posted 08/23/12 09:19 AM     Remind Me!  Send Private Message   Edit Post
Alright man, it was just something to keep in mind. If you don't like the answers your gonna get, don't ask questions. I've been there, done that a thousand times and have verifed my findings. I also wouldn't post in any help section till you have a complete diagnosis. I bet if you know what you were doing, you wouldn't post until you had a log. Raw data speaks a thousand words. Good luck to you though.
Edited by TheEvoZero (08/23/12 09:23 AM)
dammitjim
Member +
Galant VR-4 org Post #: 1082286 posted 08/23/12 10:21 AM     Remind Me!  Send Private Message   Edit Post
Do a compression test and post the results
Posts: 312 | From: WI | Member Since: 10/11/11 | IP: (204.246.4.105) | Report this post to a Moderator
Pages: 1 | 2
0 registered and 9 anonymous users are browsing this forum.
Generated in 0.082 seconds in which 0.047 seconds were spent on a total of 14 queries. Turbo powered.
