Galant VR-4 Forums » Galant VR-4 » Technical Discussions » Sitting motor
Sitting motor
The_Big_Weave
Member +
Galant VR-4 org Post #: 1053949 posted 02/29/12 03:06 AM     Remind Me!  Send Private Message   Edit Post
Got a galant the other day from a guy doing a GSX swap. He never got around to finishing it and the car sat for 3 years. The motor only has 40k, oem Mitsubishi rebuild. I got the motor started and it runs fine. Wondering if I need to worry about oil pump or anything interal? Doing a timing belt kit when I pull it for a CSM swap.
554/1k SOLD
Non-galant owner.
01 S2K
Posts: 390 | From: Rapid City, SD | Member Since: 02/27/09 | IP: (209.159.237.160) | Report this post to a Moderator
omertaitalia
Member +
435/2000
Galant VR-4 org Post #: 1053978 posted 02/29/12 10:00 AM     Remind Me!  Send Private Message   Edit Post
im a little confused, you bought a vr4 from a guy doing a gsx swap?, do you mean you bought a vr4 with a eclipse gsx motor in it?
#616-1000-sold
#435-2000
1992 Mistubishi Expo AWD 7 pass. van (4g63 swapped)
2010 Ducati 848
Posts: 410 | From: Downtown Los Angeles CA/Lake T... | Member Since: 05/07/09 | IP: (24.176.247.63) | Report this post to a Moderator
alansupra94
Excuse the retarded question.
4/1000
Galant VR-4 org Post #: 1053985 posted 02/29/12 10:26 AM     Remind Me!  Send Private Message   Edit Post
Quoting The_Big_Weave:
For me, if the motor was fully assembled, I can't see anything really going bad, especially if it runs fine. I would recommend changing the spark plugs, cleaning the injectors and all the belts. I would also check for oil/coolant leaks (especially if the BSR was done).
Anyone else want to chime in?
1992 Galant VR4
1996 Toyota Supra TT
Posts: 1909 | From: Wayne,NJ | Member Since: 03/03/10 | IP: (192.132.228.1) | Report this post to a Moderator
The_Big_Weave
Member +
Galant VR-4 org Post #: 1054006 posted 02/29/12 01:58 PM     Remind Me!  Send Private Message   Edit Post
It was a galant gsx to vr4 swap.
554/1k SOLD
Non-galant owner.
01 S2K
Posts: 390 | From: Rapid City, SD | Member Since: 02/27/09 | IP: (174.253.151.184) | Report this post to a Moderator
KiNgMaRtY
Member +++
802/1000
Galant VR-4 org Post #: 1054018 posted 02/29/12 03:41 PM     Remind Me!  Send Private Message   Edit Post
It should be fine, about the same difference when a car sits for years and then gets stated back up. May just want to do some of the fluid changes and such as mentioned, plugs wires...
92 GVR4 #802 link
17 CTS-V,06 Evo IX MR, 98 Montero
94 MX5 M-Edition - On Xidas, LS1 Swap in progress
SOLD: 92 GVR4 #611
Posts: 800 | From: Corona, CA | Member Since: 04/08/08 | IP: (98.189.79.130) | Report this post to a Moderator
Generated in 0.055 seconds in which 0.041 seconds were spent on a total of 14 queries. Turbo powered.
