Galant VR-4 Forums » Galant VR-4 » Technical Discussions » Clutch pedal assembly
Brunoboy
Jesus Clips
352/1000
556/1000
Galant VR-4 org Post #: 1022311 posted 10/02/11 03:25 AM     Remind Me!  Send Private Message   Edit Post
I'm assuming now my clutch pedal assembly is bad, two slaves and two master cylinders, adjusted all the way to the last thread and my pedal has about an inch up top of no Pressure before the clutch even engages or disengages. I can't get my clutch to full disengage with new everything and an extended rod. Anyone take out the clutch pedal assembly? Is it hard ? And anyone weld it to fix the "slop" of a warn assembly?
-shane
556/1000 KG 8/10/13 .... Sold
352/1000 Summit White sold in 2011 and was totaled by new owner......
92 Eclipse Gsx R.I.P
96 Eclipse Gsx Sold
Posts: 2880 | From: San Bruno,CA Home of SFO | Member Since: 04/25/08 | IP: (166.205.139.133) | Report this post to a Moderator
295hp 35r BR4
550/2000
Galant VR-4 org Post #: 1022355 posted 10/02/11 12:39 PM     Remind Me!  Send Private Message   Edit Post
Eventually after about 190,000 miles the clutch pedal gets worn out, mine had got Soo bad that it wouldn't go in any gear anymore. Then i changed Them to new ones and bam works like new again. There's 2 pieces that u need to replace under there, the long clutch pedal and a small flange it connects too. All in all it's only about 25-35 bucks but they are a pain in the ass to change out because of the tight location. Some people do weld them though.
2001 R34 Nissan Skyline “Eleanor”
JZX90 Toyota Mark II Tourer V "Laura"
90 Nissan Skyline GTR "Tanya"
90 Eclipse GST "Kerri"
91 Galant VR4 "Samara"
Posts: 3717 | From: Houston, Texas | Member Since: 04/07/11 | IP: (208.54.39.153) | Report this post to a Moderator
gramkrakr89
Now with Jelly next week is roasted marshmallows and hershey bars
689/1000
Galant VR-4 org Post #: 1022362 posted 10/02/11 01:13 PM     Remind Me!  Send Private Message   Edit Post
i've heard that welding is an effective way to keep it from warping and such... my pedal is getting pretty bad too, but I got some more travel out of it by adjusting the top pedal stop up a little more...
the pedal sits a little higher now, but with the proper master adjustment, it makes a world of difference for opening up that little bit of stroke needed...
of course if the pedal assembly is getting worn, it is best to replace or repair it
Posts: 308 | From: Cincinnati, OH | Member Since: 01/25/10 | IP: (174.252.203.65) | Report this post to a Moderator
295hp 35r BR4
550/2000
Galant VR-4 org Post #: 1022369 posted 10/02/11 01:30 PM     Remind Me!  Send Private Message   Edit Post
Yeah man because once it gets to that point all the adjustment in the world won't help it if the metal in that flange is all boogered up. Just go to the dealer and order those 2 pieces, you'll thank me later
Posts: 3717 | From: Houston, Texas | Member Since: 04/07/11 | IP: (208.54.39.169) | Report this post to a Moderator
Brunoboy
Jesus Clips
352/1000
556/1000
Galant VR-4 org Post #: 1022374 posted 10/02/11 01:56 PM     Remind Me!  Send Private Message   Edit Post
ive been replacing masters and slaves like no other, I do have a XTD Stage 4 in it with the 6 puck unsprung disc for the past 12k miles. I adjusted the cruise switch out for more pedal play and adjusted the master rod out to the last thread with about an inch of the clutch pedal feeling no pressure. I assume my pedal assembly is done and the car itself has 221,xxx miles on the damn assembly.
-Shane
96 Eclipse Gsx Sold
Posts: 2880 | From: San Bruno,CA Home of SFO | Member Since: 04/25/08 | IP: (74.51.145.216) | Report this post to a Moderator
dsm10o0
Member ++
705/2000
556/1000
Galant VR-4 org Post #: 1022394 posted 10/02/11 03:12 PM     Remind Me!  Send Private Message   Edit Post
Ted could weld that up. I remember him having that problem. Its a bitch to get to, I had to take the dash off of my old Sgt when it had that same problem.
91 VR-4 705/2000
92 VR-4 556/1000
03 Evo 8 -New toy
05 Nissan Armada toy hauler
Posts: 680 | From: San Jose CA | Member Since: 06/16/10 | IP: (76.103.55.216) | Report this post to a Moderator
Brunoboy
Jesus Clips
352/1000
556/1000
Galant VR-4 org Post #: 1022396 posted 10/02/11 03:14 PM     Remind Me!  Send Private Message   Edit Post
sgt? lol yea Nico, wanna come over and pull this out for me? ahahaha, jk, but i hope it doesnt take to long, i read many write ups on how to remove it. and I am pretty sure thats what it is.
96 Eclipse Gsx Sold
295hp 35r BR4
550/2000
Galant VR-4 org Post #: 1022411 posted 10/02/11 03:26 PM     Remind Me!  Send Private Message   Edit Post
It'll take atleast 4 hours with all the crap you gotta take out under the dash, not to mention you will be upside down all up in the dash 100 percent of the time so a smaller person would be more ideal for this job.
Posts: 3717 | From: Houston, Texas | Member Since: 04/07/11 | IP: (208.54.39.219) | Report this post to a Moderator
Brunoboy
Jesus Clips
352/1000
556/1000
Galant VR-4 org Post #: 1022449 posted 10/02/11 06:08 PM     Remind Me!  Send Private Message   Edit Post
Started an hr ago all done except the master cylinder and pulling it out lol
96 Eclipse Gsx Sold
Posts: 2880 | From: San Bruno,CA Home of SFO | Member Since: 04/25/08 | IP: (166.205.136.100) | Report this post to a Moderator
Brunoboy
Jesus Clips
352/1000
556/1000
Galant VR-4 org Post #: 1022536 posted 10/03/11 01:49 AM     Remind Me!  Send Private Message   Edit Post
I can't remove it, I took the steering shaft off as well, how do I remove it out the back ?
96 Eclipse Gsx Sold
Posts: 2880 | From: San Bruno,CA Home of SFO | Member Since: 04/25/08 | IP: (166.205.137.200) | Report this post to a Moderator
295hp 35r BR4
550/2000
Galant VR-4 org Post #: 1022542 posted 10/03/11 02:03 AM     Remind Me!  Send Private Message   Edit Post
do u have the 2 new pieces or are you going to just have it welded? theres alot of stuff u need to remove under the dash in order to get the pedal assembly out. goodluck man
Posts: 3717 | From: Houston, Texas | Member Since: 04/07/11 | IP: (24.249.34.170) | Report this post to a Moderator
Brunoboy
Jesus Clips
352/1000
556/1000
Galant VR-4 org Post #: 1022545 posted 10/03/11 02:41 AM     Remind Me!  Send Private Message   Edit Post
i took off all the bolts, i took off the master cylinder, i took off the brake booster, i took off the steering column plus the steering shaft. i am going to take it out and see whats wrong with it. I cant even twist it around to get it out and if i pull forward its pulling the speed cable.... any help would be nice.
-Shane
96 Eclipse Gsx Sold
cupajoe
Member +
1242/2000
Galant VR-4 org Post #: 1022587 posted 10/03/11 09:34 AM     Remind Me!  Send Private Message   Edit Post
I remember doing this a couple years back, its just a pita. Aslong as the bolts are all removed and you pulled the brake boost away from the firewall there should be nothing physically holding it back. Use a flat head to pull it away from the stud(Floor)then just keeping playing with it until you can rotate it out from under there. Good luck, I'm going to have to be doing this soon with my galant.
EDIT: Did you read the write up on dsmtalk from Taboo? If you need a link I can link it.
Edited by cupajoe (10/03/11 09:38 AM)
Posts: 343 | From: Lake Mary, FL | Member Since: 03/01/10 | IP: (68.228.22.176) | Report this post to a Moderator
Brunoboy
Jesus Clips
352/1000
556/1000
Galant VR-4 org Post #: 1022630 posted 10/03/11 12:47 PM     Remind Me!  Send Private Message   Edit Post
link me please, there wasnt any pics i could find. also the brake booster only pulls out so far.
96 Eclipse Gsx Sold
Brunoboy
Jesus Clips
352/1000
556/1000
Galant VR-4 org Post #: 1022694 posted 10/03/11 03:52 PM     Remind Me!  Send Private Message   Edit Post
so i got it out, the speed sensor was in the way, pulled for slack and the pedal assembly came out. it seems fine, no play, im having it welded anyways since its out, I dont want to ever have to pull this again.
96 Eclipse Gsx Sold
295hp 35r BR4
550/2000
Galant VR-4 org Post #: 1022711 posted 10/03/11 04:41 PM     Remind Me!  Send Private Message   Edit Post
I'll Prob have mine welded in my other cars since its like a permanent solution. its the GST that i actually replaced the new stuff with.
cupajoe
Member +
1242/2000
Galant VR-4 org Post #: 1022873 posted 10/03/11 10:07 PM     Remind Me!  Send Private Message   Edit Post
Quoting brunoboy:
Sorry I'm a little late on the link, just got home. But glad you got it out and I agree might aswell weld it while its out.
GVR4 1242/2000
Generated in 0.074 seconds in which 0.047 seconds were spent on a total of 14 queries. Turbo powered.
