Galant VR-4 Forums » Marketplace » Cars For Sale » FS: 1991VR4 (?/1000) Desmoines,Iowa *****SOLD*****
jcgalntvr4-244 Galant VR4.org Moderator
WAY 2 many
244/2000
Galant VR-4 org Post #: 931951 posted 09/16/10 07:39 PM     Remind Me!  Send Private Message   Edit Post
First off I bought this car about 3 years ago with intentions of parting it out. Since then Some of my ideas for 244/2000 have changed so I dont really want to part the car as its in pretty good shape. It does need new paint as the paint is crap on the car.
Non sunroof 1991 Galant has about 160k on the body, and 10k at the most on the engine. The paint is rough w/ oxidation.
Parts list:
6-bolt engine, JE pistons on Eagle Rods.
SBR cast manifold
fp2 272 cams
Tial 38mm wastegate recirc.
Full 3" exhaust
GM Maf-T blow through Setup.
Tial Blow off valve
IRC street kit FMIC (Spearco 2-210 core i think, with short route piping).
PTE 50 trim internal wg opening is welded shut due to external.
ND 650cc injectors
Aeromotive FPR
ND Supra pump hardwired
ACT 2100 PP w/ 6-puck disc
Cynergy Segmented Flywheel
H&R Sport springs
KYB GR-2s
5-lug hub conversion. (Stock galants came with a 4-lug setup)
late 90s GSX wheels, the ones that came on the late 2g GSX.
2g GSX/3kgt SL dual piston calipers on front.
EPROM ecu w/ dsmchip for 650s
S-AFC II
new tie rod ends
new altnator
turboxs mbc
2 slim fans
Maft Translater
brand new falken azenis rt615 tires
Also the car no longer has 4WS.
4 Bolt rear
poly motor mounts
new gas tank rubber filler tube
Carpet is removed but have another that comes with the car
Baller orange valve cover
My email is [email protected] or you can PM me here dont be afraid to make an offer you never know I might just take it.
1991 JDM Galant Vr4
1991 Galant Vr4 244/2000
1991 Galant Vr4 30/2000
1991 Galant Vr4 142/2000
Yeah Im an addict.......
Edited by jcgalntvr4-244 (04/14/11 06:16 PM)
Posts: 3135 | From: DesMoines Iowa | Member Since: 11/09/03 | IP: (75.170.215.152) | Report this post to a Moderator
blacksheep
Baraqsheep
205/1000
Galant VR-4 org Post #: 931989 posted 09/16/10 09:40 PM     Remind Me!  Send Private Message   Edit Post
This thing runs and drives?
Any rust?
Damn you for even making me think about this...
1992 Galant VR-4. 205/1000. Nile Black. Sunroof.
Posts: 15473 | From: Urbandale, Iowa 50323 | Member Since: 05/01/02 | IP: (173.20.46.32) | Report this post to a Moderator
WAY 2 many
244/2000
Galant VR-4 org Post #: 932011 posted 09/16/10 11:06 PM     Remind Me!  Send Private Message   Edit Post
Its not in real bad shape as far as rust goes. The underside is just surface rust KC. The car came from STL and it has been stored inside for the last 3 years I would only drive it to charge the battery and keep it lubed up..... If I were going to "keep" the car I would prob have it treated or undercoated being that were in Iowa lol but its never seen snow since I have owned it. It does have the bends in the seam weld where some dumbasses have jacked it up before.... but all in all its in real good shape for a midwest car.
JC
1991 JDM Galant Vr4
Edited by jcgalntvr4-244 (09/16/10 11:09 PM)
dsmer06
I fail at the internet.
246/1000
Galant VR-4 org Post #: 932168 posted 09/17/10 10:27 AM     Remind Me!  Send Private Message   Edit Post
Quoting blacksheep:
Any rust?
Don't think, just do!
#246/1000
Posts: 636 | From: Des Moines, IA | Member Since: 02/27/08 | IP: (97.125.180.86) | Report this post to a Moderator
WAY 2 many
244/2000
Galant VR-4 org Post #: 932315 posted 09/17/10 06:18 PM     Remind Me!  Send Private Message   Edit Post
Quoting blacksheep:
Any rust?
Its even got that VR4 Smell you like so much...And that comes free with the car
1991 JDM Galant Vr4
dsmer06
246/1000
Galant VR-4 org Post #: 932319 posted 09/17/10 06:32 PM     Remind Me!  Send Private Message   Edit Post
I know the answer is probably no, but would you want to trade for a Stealth?
#246/1000
Posts: 636 | From: Des Moines, IA | Member Since: 02/27/08 | IP: (69.66.191.79) | Report this post to a Moderator
blacksheep
Baraqsheep
205/1000
Galant VR-4 org Post #: 932346 posted 09/17/10 09:15 PM     Remind Me!  Send Private Message   Edit Post
Quoting jcgalntvr4-244:
Quoting blacksheep:
Any rust?
You know my current situation - maybe if you kept it for another year
WAY 2 many
244/2000
Galant VR-4 org Post #: 934684 posted 09/26/10 08:24 PM     Remind Me!  Send Private Message   Edit Post
Taking offers guys need to get rid of this car shootme some pm's
1991 JDM Galant Vr4
Posts: 3135 | From: DesMoines Iowa | Member Since: 11/09/03 | IP: (75.170.211.81) | Report this post to a Moderator
WAY 2 many
244/2000
Galant VR-4 org Post #: 939248 posted 10/13/10 10:41 AM     Remind Me!  Send Private Message   Edit Post
Not sure what happened with the posts here lol but someone needs this car and winter is coming an I need it gone
JC
1991 JDM Galant Vr4
Posts: 3135 | From: DesMoines Iowa | Member Since: 11/09/03 | IP: (75.170.229.30) | Report this post to a Moderator
JB
Other
Galant VR-4 org Post #: 939321 posted 10/13/10 01:47 PM     Remind Me!  Send Private Message   Edit Post
Would you hesitate to drive this car long distances?
JBiz
Half Man, Half Amazing
Posts: 5836 | From: MA | Member Since: 08/15/04 | IP: (108.7.34.19) | Report this post to a Moderator
mikus
weiterhin das Huhn f#$k
1994/2000
Galant VR-4 org Post #: 939352 posted 10/13/10 03:24 PM     Remind Me!  Send Private Message   Edit Post
+1 on running status please - idle, leakages, distance reliability, what psi it's on currently
Posts: 2763 | From: Aurora IL | Member Since: 01/11/07 | IP: (198.178.234.30) | Report this post to a Moderator
Old Balls
425/1000
Galant VR-4 org Post #: 939388 posted 10/13/10 04:31 PM     Remind Me!  Send Private Message   Edit Post
I have seen this car and all it needs is a little cosmetic wrenching and the PCV vac hoses re-routed. The BOV is tapped into the same pipe as the PCV and that causes inconsistent vac/boost signals that cause the BOV to open before needed.
That should take about 5 minutes and some scrap vac lines.
1992 Galant VR4 click
Posts: 9009 | From: Davenport, Iowa USA | Member Since: 12/16/03 | IP: (173.28.64.157) | Report this post to a Moderator
WAY 2 many
244/2000
Galant VR-4 org Post #: 939416 posted 10/13/10 06:21 PM     Remind Me!  Send Private Message   Edit Post
It needs a new batt. and what Terry said, I drove it from KC MO to DesMoines Iowa with no probs at all. I also have a JDM rear bumper I would throw in with the car fo an extra 400.00
I wouldnt worry about driving this car long distance's but hey it is a galant vr4 we are talking about here.
Here is my cell if anyone wants to talk 1(515)202-4461
Thanks,
JC
1991 JDM Galant Vr4
blacksheep
Baraqsheep
205/1000
Galant VR-4 org Post #: 939480 posted 10/13/10 09:45 PM     Remind Me!  Send Private Message   Edit Post
Rumor has it that a local gvr4 guy has a wedding coming up and this would be an AWESOME gift
Posts: 15473 | From: Urbandale, Iowa 50323 | Member Since: 05/01/02 | IP: (173.25.245.215) | Report this post to a Moderator
WAY 2 many
244/2000
Galant VR-4 org Post #: 939526 posted 10/13/10 11:34 PM     Remind Me!  Send Private Message   Edit Post
Sounds good you give me 5000.00 and Ill give you the car and 1500.00
1991 JDM Galant Vr4
Spott
The Deer Hitman
Galant VR-4 org Post #: 939538 posted 10/14/10 01:13 AM     Remind Me!  Send Private Message   Edit Post
I know have the wedding guy drive it out to vegas for me.
91 sold #657/2000
-Mike
Ever notice how when you get behind the wheel of a car,
you are the only person in the world that is not a complete moron?
So what do I do with these other two doors?
Posts: 1529 | From: Las Vegas | Member Since: 01/05/04 | IP: (70.173.253.166) | Report this post to a Moderator
blacksheep
Baraqsheep
205/1000
Galant VR-4 org Post #: 939581 posted 10/14/10 08:31 AM     Remind Me!  Send Private Message   Edit Post
Too late, he jumps on a plane to vegas at 4:30 pm today.
Mike - send me your contact info if you see this. I will try and touch base with you!
WAY 2 many
244/2000
Galant VR-4 org Post #: 941652 posted 10/20/10 09:35 PM     Remind Me!  Send Private Message   Edit Post
1991 JDM Galant Vr4
Posts: 3135 | From: DesMoines Iowa | Member Since: 11/09/03 | IP: (75.170.231.194) | Report this post to a Moderator
WAY 2 many
244/2000
Galant VR-4 org Post #: 947397 posted 11/08/10 09:32 PM     Remind Me!  Send Private Message   Edit Post
bump.................... Buy me or I set it on fire and collect the insurance money ..............................
1991 JDM Galant Vr4
Posts: 3135 | From: DesMoines Iowa | Member Since: 11/09/03 | IP: (75.170.221.168) | Report this post to a Moderator
OneTitle to rule them all.
77/2000
Galant VR-4 org Post #: 947422 posted 11/08/10 10:49 PM     Remind Me!  Send Private Message   Edit Post
Let's swap the goodies into 77 and then sell the shell!
Ryan Hertz
Posts: 13501 | From: Chicago, IL | Member Since: 07/29/02 | IP: (75.3.113.253) | Report this post to a Moderator
Old Balls
425/1000
Galant VR-4 org Post #: 947425 posted 11/08/10 11:01 PM     Remind Me!  Send Private Message   Edit Post
Yeah, get busy Hertzy.
Although awefully late in the year to start this. Freezing our asses off in a puny Chicago garage in January is not to much fun.
Posts: 9009 | From: Davenport, Iowa USA | Member Since: 12/16/03 | IP: (173.26.17.192) | Report this post to a Moderator
WAY 2 many
244/2000
Galant VR-4 org Post #: 947879 posted 11/10/10 05:22 PM     Remind Me!  Send Private Message   Edit Post
Quoting Hertz:
Make me an offer and we can talk about it =)
1991 JDM Galant Vr4
Posts: 3135 | From: DesMoines Iowa | Member Since: 11/09/03 | IP: (75.170.209.248) | Report this post to a Moderator
WAY 2 many
244/2000
Galant VR-4 org Post #: 947883 posted 11/10/10 05:23 PM     Remind Me!  Send Private Message   Edit Post
Quoting Terry Posten:
Nah fuck that We can wait till next summer and Ill go get it and bring it back here and we can do it here.
JC
1991 JDM Galant Vr4
WAY 2 many
244/2000
Galant VR-4 org Post #: 953465 posted 11/29/10 05:59 PM     Remind Me!  Send Private Message   Edit Post
Bump
1991 JDM Galant Vr4
Posts: 3135 | From: DesMoines Iowa | Member Since: 11/09/03 | IP: (75.170.230.106) | Report this post to a Moderator
blacksheep
Baraqsheep
205/1000
Galant VR-4 org Post #: 954162 posted 12/01/10 07:44 PM     Remind Me!  Send Private Message   Edit Post
Ayyyyyyy - call me, nukka!
Posts: 15473 | From: Urbandale, Iowa 50323 | Member Since: 05/01/02 | IP: (173.25.234.59) | Report this post to a Moderator
Pages: 1 | 2 | 3
0 registered and 18 anonymous users are browsing this forum.
Generated in 0.055 seconds in which 0.026 seconds were spent on a total of 14 queries. Turbo powered.
