Galant VR-4 Forums » Marketplace » Cars For Sale » FS: 1833 of 2000 Galant VR-4 Indianapolis - First $4k takes it.
Matt W
Galant VR-4 org Post #: 884039 posted 03/22/10 06:54 PM     Remind Me!  Send Private Message   Edit Post
Tax Checks, put them to good use It is time to do this. I don't have the time to enjoy the car with everything going on.
Up for sale is my 1991 Mitsubishi Galant VR-4. You can see pictures below. It was previously owned by Jon Roberts (former owner of the board). I bought the car and have not driven it as much as I should have. I drove it a few times in the snow this year (the car was incredible in the snow with the 4 bolt with LSD, and the Yokohoma Ice grips) and the rest of the years it has never seen snow or ice. The car doesn't have any real rust on the underneath of it.
This is one of the cleanest Galants I have seen. The interior I would rate right now is an 8.5 and could easily be a 9 if someone would just clean it up and work on the leather.
The exterior is probably an 8.5, and just has a few spots it needs touched up on.
The car currently has a engine that was rebuilt with stock 2G pistons, and an old 14B turbo with no coolant lines going into it. It used to have an old L2 turbo on it, but I pulled that off as it needs to be rebuilt (hence the lack of the coolant lines going into it).
Mods are as follows:
3" inch Buschur exhaust with no cat and also has a 3" resonator
welded in
2G Mas
Keydiver Chip
FIC 750cc injectors
K&N
2G Manifold, ported
14B turbo that works, but needs to be replaced
engine with blown headgasket
timing belt is in the great shape
upgraded 93 headlights (brightest out there)
ported 02 housing
Spearco/Griffin top/bottom flow IC
RRE pipes
Custom made Water Injection System
Tre Rebuilt Transmission that shifts GREAT (rebuilt by Tre with
under ~10k miles on rebuilt)
4 bolt read end w/ LSD
4WS delete
MP3 CD player installed available for Sat radio
Front strut bar
rear strut bar
Zeitronix Wideband with Digital Boost Display, AFR, and Lambda
battery relocated
15" stock wheels sandblasted silver
15" ice grip yokohoma snow tires
15" Yokohama AVS tires
17" Rota wheels with Kumho tires in front and Yokohama in rear
Talon Steering Wheel
Walboro Fuel pump
KYB AGX shocks
H&R springs with 1 Cut
adjustable camble bolts
1 degree caster adjustment
Rear 27MM sway bar
leather shift boot
AC removed
PS removed.
ACT 2600LB clutch
lightened flywheel
SS brake lines
90 DSM oil cooler
Modine all metal radiator
Stock BOV crushed
Dejon Stop leak BOV mod
Hallman Boost Controller
SX Fuel pressure regulator with Gauge
balance shafts removed.
I think that is it. I probably have forgotten a few things.
If you are looking for a great daily driver just throw a head gasket on it and you're good to go. If you want to run low 12's or high 11's the car is ready to go with a turbo upgrade.
Includes a spare shortblock with head/cams (needs work, the head does)
I also have an old L2 turbo that needs to be rebuilt, plus a set of 17" Rota Rims with Kumho and Yokohoma Tires on it (front and rear). I can include these. I'm asking 7,000 for the car WITH spare short block, turbo, and
17" wheels and the Yokohama tires with the snow tires on it. The price may seem high but once you see the pictures and a short block is included and have a look at the car you'll see the value.
If you're looking for a clean Galant to mod, drive, race, or enjoy you'll be hard pressed to find a different car.
I will entertain reasonable offers I'm not in any desperate need or hurry to sell it since it is just sitting safely in my garage.
Lastly, if you have a Evo for sale I'll consider a trade. Of course I'll add cash on my end because I would not expect a straight up trade, but won't argue with you if you want to ;-)
Pics are here: Car has silver wheels now (look great) and needs washed, that is really the only difference in looks. Oh, and it does not have Momo wheel and the K&N is behind the headlight now instead of right off the turbo.
Price for all: $6,000 (includes extra good short block, turbo wheels, etc.)
-Matt
Edited by Matt W (02/27/11 05:36 PM)
Posts: 382 | From: Noblesville, Indiana | Member Since: 08/18/01 | IP: (98.220.142.79) | Report this post to a Moderator
ScreaminE
Just don't like an idiot
Galant VR-4 org Post #: 884056 posted 03/22/10 08:17 PM     Remind Me!  Send Private Message   Edit Post
7k for a car with a blown head gasket?
-Scott H.
1267/2000 - sold
Posts: 646 | From: Pittsburgh South Hills | Member Since: 09/04/08 | IP: (71.60.42.243) | Report this post to a Moderator
4wheelsqueal
Member +
Galant VR-4 org Post #: 884326 posted 03/23/10 09:23 PM     Remind Me!  Send Private Message   Edit Post
i think, if i'm readin it correctly, for $7000 you get a spare motor.
1997 Eclipse GSX - sold
2004 Evo RS
1996 Eclipse Spyder AWD - sold
555/2000 NB - 286,000 miles - sold
713/1000 KG - sold
1945/2000 BG - sold
1803/2000 SW RHD - sold
1049/2000 - sold
Posts: 446 | From: Shawano,WI | Member Since: 12/06/08 | IP: (173.86.188.219) | Report this post to a Moderator
Matt W
Galant VR-4 org Post #: 884357 posted 03/24/10 12:01 AM     Remind Me!  Send Private Message   Edit Post
Yeah. And the engine in it needs a head gasket. So once that is replaced 2 working motors.
-Matt
Former owner of #1833
Matt W
Galant VR-4 org Post #: 903959 posted 06/02/10 07:33 PM     Remind Me!  Send Private Message   Edit Post
BUMP and to $6,000.
blacksheep
Baraqsheep
205/1000
Galant VR-4 org Post #: 903978 posted 06/02/10 08:56 PM     Remind Me!  Send Private Message   Edit Post
OG Jon Roberts bump. Looks good!
1992 Galant VR-4. 205/1000. Nile Black. Sunroof.
Edited by blacksheep (06/02/10 08:56 PM)
Posts: 15473 | From: Urbandale, Iowa 50323 | Member Since: 05/01/02 | IP: (173.20.46.32) | Report this post to a Moderator
Matt W
Galant VR-4 org Post #: 948656 posted 11/13/10 12:24 PM     Remind Me!  Send Private Message   Edit Post
Update: The car is now running with a brand new head gasket and ported head installed. I also had Fathouse (a famous Evo owner) look over the car and get it running in top notch. It needs cleaned up a bit (I am working on it now) but it runs really well.
I've also lowered the price for $6,000. This includes spare block / head (of course they need work). Snow tires, regular Yokohoma AVS and 17" wheels.
Matt W
Galant VR-4 org Post #: 960804 posted 12/30/10 06:55 PM     Remind Me!  Send Private Message   Edit Post
Reduced to $5,500.
edit: more pics here:
Edited by Matt W (01/02/11 01:19 PM)
Matt W
Galant VR-4 org Post #: 972756 posted 02/26/11 03:32 AM     Remind Me!  Send Private Message   Edit Post
Bump: Reduced to 4k FIRM (this does not include spare "short block/turbo)
One of the nicest galants you will find.
Also has manual seat belts installed, not those stupid mouse belts.
Edited by Matt W (03/01/11 12:54 PM)
4G63_GSR
Member +++
Galant VR-4 org Post #: 973490 posted 03/01/11 01:02 PM     Remind Me!  Send Private Message   Edit Post
wow this is tempting! i'm not looking for a monster gvr4. just looking for a clean DD.
144/1000 <---- SOLD
Pretty Girls Make Us Buy Beer_Ugly Girls Make Us Drink Beer
Posts: 852 | From: wis | Member Since: 01/22/03 | IP: (76.199.201.5) | Report this post to a Moderator
Matt W
Galant VR-4 org Post #: 975152 posted 03/07/11 10:04 PM     Remind Me!  Send Private Message   Edit Post
Bump!
And let me also state (lots of things to remember) it has a manual rack in it, no power steering, but it is not hard at all, except for parallel parking, which I never do.
Matt
maxash0775
1736/2000
Galant VR-4 org Post #: 975169 posted 03/07/11 11:28 PM     Remind Me!  Send Private Message   Edit Post
Great looking car. just a clarifying question, is it ready to drive right now (like back to california) or does it need a head gasket? How many miles also, I must have missed it.
Finally Got my GVR4
Posts: 217 | From: Bakersfield, CA | Member Since: 10/19/09 | IP: (98.150.26.5) | Report this post to a Moderator
Matt W
Galant VR-4 org Post #: 976479 posted 03/13/11 12:31 PM     Remind Me!  Send Private Message   Edit Post
It is ready to drive, does not need a headgasket, 153k miles on it or so. I have not driven it hardly at all over the past year or so, so it could be driven to california, but like anything...that is a long drive.
Matt
mikus
weiterhin das Huhn f#$k
1994/2000
Galant VR-4 org Post #: 976529 posted 03/13/11 07:59 PM     Remind Me!  Send Private Message   Edit Post
I looked at this car today and took it around the neighborhood, everything's just as described. The TRE shifts great, it fired right up, drove fine and pulled as good as a dusty 14b would. The two full wheel/tire sets have plenty of tread and good condition, 3rd set tread is pretty decent.
As for "will it drive to CA" -- it's a 20 year old 4G63, if you have to ask you shouldn't try! but I wouldn't feel too concerned driving it back ~4hrs to my home from what I saw.
Posts: 2763 | From: Aurora IL | Member Since: 01/11/07 | IP: (198.178.234.30) | Report this post to a Moderator
Matt W
Galant VR-4 org Post #: 976530 posted 03/13/11 08:01 PM     Remind Me!  Send Private Message   Edit Post
Thanks Mike. Great meeting you. As a note, I can't seem to locate the front strut bar. I will keep looking. It was a cheapo bar you can make for about $20 in supplies so I wanted to disclose that.
-Matt
talontyme
Member +
224/2000
1505/2000
Galant VR-4 org Post #: 976544 posted 03/13/11 09:13 PM     Remind Me!  Send Private Message   Edit Post
Is this still for sale?
95 Mitsu GSX-650hp monster
92 Laser RS awd-sold
1505/2000-sold
224/2000-traded
Posts: 329 | From: Portsmouth,VA. | Member Since: 03/16/09 | IP: (98.141.3.180) | Report this post to a Moderator
Matt W
Galant VR-4 org Post #: 976545 posted 03/13/11 09:17 PM     Remind Me!  Send Private Message   Edit Post
Pending...just waiting for a deposit.
szewczyd
Newbie
Galant VR-4 org Post #: 976653 posted 03/14/11 10:37 AM     Remind Me!  Send Private Message   Edit Post
lol your killing me I have cash in hand!
Posts: 1 | From: Dousman, WI | Member Since: 05/28/10 | IP: (63.131.127.138) | Report this post to a Moderator
MMorgan
294/1000
Galant VR-4 org Post #: 976730 posted 03/14/11 05:57 PM     Remind Me!  Send Private Message   Edit Post
There's a line buddy! I got cash ready to be in his hand.
Formerly known as Akidosigh1
90 Talon TSI AWD
90 Talon TSI AWD SCCA ProRally - Traded
91 Galant VR-4 - Back in the game, 7-14-14
92 Galant VR-4 - Sold
89 Colt GT - Sold
89 Mirage Turbo - Sold
91 Elcipse GSX - Sold
99 Eclipse GS - Totaled
Posts: 1918 | From: Haymarket, VA | Member Since: 03/16/03 | IP: (173.79.0.178) | Report this post to a Moderator
Matt W
Galant VR-4 org Post #: 976784 posted 03/14/11 08:56 PM     Remind Me!  Send Private Message   Edit Post
note to self. Auction next time :P
Matt
Matt W
Galant VR-4 org Post #: 979976 posted 03/26/11 11:39 AM     Remind Me!  Send Private Message   Edit Post
Back on the market! Buyer lost his job! Okay guys, lets get this done. 4k firm.
Posts: 382 | From: Noblesville, Indiana | Member Since: 08/18/01 | IP: (98.220.129.149) | Report this post to a Moderator
highspeed
Galant VR-4 org Post #: 980083 posted 03/26/11 10:21 PM     Remind Me!  Send Private Message   Edit Post
Hmmmmmm
wish I had one
Posts: 134 | From: AFCRAPISTAN | Member Since: 09/22/07 | IP: (62.67.9.2) | Report this post to a Moderator
TARZAN
Newbie
Galant VR-4 org Post #: 981267 posted 03/31/11 04:44 PM     Remind Me!  Send Private Message   Edit Post
Please PM me your number. My 03 Cobra is scheduled to sell Saturday.
Thanks,
-Will
Too many toys never hurt anybody
Posts: 12 | From: Memphis | Member Since: 04/26/09 | IP: (98.251.169.129) | Report this post to a Moderator
GSNT
Deer Slayer
Galant VR-4 org Post #: 981624 posted 04/01/11 10:42 PM     Remind Me!  Send Private Message   Edit Post
Very interested as well. Any interest in trading for a pretty quick 50 trim equipped white 93 Tsi AWD?
Posts: 521 | From: Louisville, KY | Member Since: 07/06/03 | IP: (24.15.31.72) | Report this post to a Moderator
Matt W
Galant VR-4 org Post #: 981700 posted 04/02/11 01:36 PM     Remind Me!  Send Private Message   Edit Post
No interest in any trades unless you have a clean Evo and of course I would add cash.
Pages: 1 | 2
Rating: *
Generated in 0.064 seconds in which 0.03 seconds were spent on a total of 14 queries. Turbo powered.
