Galant VR-4 Forums » Marketplace » Cars For Sale » FS: 1991 Summit White, #1886/2000, Florida, SOLD
keydiver
Galant VR-4 org Post #: 559039 posted 11/07/07 09:38 AM     Remind Me!  Send Private Message   Edit Post
Well, seeing as how I have put <1,000 miles on #1886 in the past 2 years, its time for someone else to enjoy the car. I have tons of mods on it, and have rebuilt just about everything on the car, so I'll be adding to the mods list as I remember them:
Engine:
Fairly recent rebuild with 2G pistons, ~5K miles
No balance shafts
Fresh head with HKS 264/264 cams, 3G lifters
EVO3 ported exhaust manifold
EVO3 ported O2 housing
EVO3 16G turbo with ported turbine, ceramic coated - holds solid boost at any psi
ARP rod bolts/nuts and main bolts
Turbotrix silicone coolant hoses
Koyo Aluminum racing radiator
Progressive 100psi water/meth injection
RRE Griffin/Spearco FMIC system
1990-style oil cooler (external cooler included, never installed though)
Carbon Fiber spark plug cover and Greddy oil cap
Relocated Odyssey Red Top battery
1994 hall-effect CAS
Supra fuelpump with rewire
All #6-AN fuel lines under the hood with Earl's fuel filter
Essex/Aeromotive FPR @ 43 psi
Siemens Deka 750cc injectors
Venom Intake Manifold
EVO8 MAS with Dejon intake and K&N filter
Gabor Stainless Steel exhaust shield
Chassis:
1993 headlights with HID low beams
FONDMetal 16" wheels with Toyo Proxes 225/55R-16 tires (>70% tread)
All 4 sets of wheel bearings replaced
polyurethane sway bar bushings all around, as well as fresh Mitsu endlinks
RRE stainless brake lines
slotted rotors with EBC green lining in front, Metalmaster in rear
KYB GR-2 struts all around
H&R springs with one turn removed in rear
Whiteline Front Strut Bar
2 1/2" exhaust, no cat, electric cutout, stainless resonator, extra O2 bung
Original paint (except hood was repainted when I bought it)
Sunroof! (although I never use it)
Never in an accident, southern car most of its life
Drives very straight
Drivetrain:
Centerforce Dual Friction 2500 clutch
RRE lightened flywheel
ThreeSpeed Scattershield
TRE rebuilt transmission (~15,000 miles) with all the goodies: dual synchros, improved rails, 15% overdrive 5th gear, 4-spider center diff, too much to remember)
Mofugas short shifter
Symborski shifter bushings
4-bolt LSD rear diff WITH 4WS! (very rare)
RRE stainless clutch line
brass shift linkage bushings on transmission
Extra stuff:
MOMO steering wheel! Very nice! With MMC horn button!
Professionally converted R134 A/C system blows nice and cold
In dash Aerometer Cobalt electric fuel pressure gauge
Cyberdyne "Blinky Light" O2 gauge
DEFI 2 BAR boost gauge
MINT ECU with a DSMChip, of course
leather interior is in excellent condition
Original factory mats
Sony AM/FM/Cassette w/ Sony CD changer in the trunk
upgraded speaker system
Rack shown in pictures NOT included (sold)
Greddy Profec B electronic boost controller
Comes with the original window sticker, leatherette owners manual case, and owners manual
#1886/2000 original dash plaque intact
The bad stuff:
The usual dents and scratches after 160K+ miles of hauling bicycles and a kayak around
The front bumper cover has seen better days, as you can see in the pix
I recently removed the cruise stuff under the hood, as it was worthless anyway
Possible motor mount issue, as the exhaust slip joint wants to pull apart once in a while when making 22psi pulls
All the emissions stuff has been removed, so you'd better not live in a state with emissions visual inspections.
The car does have a compressor surge issue, if you give it partial throttle and then lift off. I feel that the problem may be that the EVO3 turbo is too small for all the rest of the mods that I have. This can also cause the car to want to stall upon sudden deceleration. This seems to be a common complaint from guys with a large Dejon intake pipe and an upgraded turbo, and may be due to some of the air being blown off by the BOV being pushed backwards through the MAS, causing the car to go rich. I'm still experimenting with a fix for this.
Well, that's it, and I'll add to it as I think of more of the mods I've done in the 8 years/100,000 miles that I've owned #1886/2000. The car is a rush to drive, always garage-kept, and a VERY reliable daily driver. It runs 20+ psi of boost all day long with no issues. I will even consider delivery anywhere in the CONUS, as the car has been built to be very dependable, as it was my primary transportation all these years.
Any SERIOUS offers considered.
Edited by keydiver (12/06/07 02:24 PM)
| | | IP: (74.163.235.231) | Report this post to a Moderator
keydiver
Galant VR-4 org Post #: 559204 posted 11/07/07 01:50 PM     Remind Me!  Send Private Message   Edit Post
I just had to put up a picture of the nice MOMO steering wheel. I fell in love with them after driving Turboflanagan's car 2 years ago.
This is a current picture under the hood:
Galant VR-4 org Post #: 559205 posted 11/07/07 01:53 PM     Remind Me!  Send Private Message   Edit Post
Jeff, you're making me cry. Please don't leave us.
91 VR4 855 Nile Black
92 VR4 828 Belize Green-SOLD
91 VR4 115 Nile Black -SOLD
Posts: 10771 | From: Michigan | Member Since: 03/05/01 | IP: (12.1.210.225) | Report this post to a Moderator
blacksheep
Baraqsheep
205/1000
Galant VR-4 org Post #: 559211 posted 11/07/07 02:05 PM     Remind Me!  Send Private Message   Edit Post
Oh my - this is a dark day. We have Harry with his car up for sale and now Jeff! Good luck with the sale, Jeff! Please stay around...
1992 Galant VR-4. 205/1000. Nile Black. Sunroof.
Posts: 15473 | From: Urbandale, Iowa 50323 | Member Since: 05/01/02 | IP: (206.195.193.254) | Report this post to a Moderator
a2vr4
Boot Strap Bill's boy
Galant VR-4 org Post #: 559281 posted 11/07/07 05:02 PM     Remind Me!  Send Private Message   Edit Post
he has two doesn't' he?
~Brian
91 Galant GSX auto green
582/2000 Belize Green crushed
92 Expo sp 2wd auto white crushed
@garagemoreno
Posts: 1543 | From: Ann Arbor MI | Member Since: 08/13/05 | IP: (67.38.24.113) | Report this post to a Moderator
Rock Star Status
Galant VR-4 org Post #: 559290 posted 11/07/07 05:12 PM     Remind Me!  Send Private Message   Edit Post
+1578979484 This is a wonderful deal on a really nice car! Jeff is more than an asset to this community, and it would be a shame to see him go.
Rance lives here...
Posts: 12049 | From: Cleveland, OH | Member Since: 12/21/04 | IP: (64.118.153.66) | Report this post to a Moderator
GalantGSX
Galant VR-4 org Post #: 559345 posted 11/07/07 06:47 PM     Remind Me!  Send Private Message   Edit Post
This sure would go nicely with my White G-GSX. What part of Florida are you located in?
| | | IP: (24.110.108.247) | Report this post to a Moderator
Senior Ricer
1552/2000
Galant VR-4 org Post #: 559356 posted 11/07/07 07:24 PM     Remind Me!  Send Private Message   Edit Post
I'm going to take a wild guess and say "Hobe Sound" like it says at the bottom of his post.
Posts: 13235 | From: Orange County, NY | Member Since: 09/11/03 | IP: (68.197.59.65) | Report this post to a Moderator
sag1441
ohi2u purge control valve
Galant VR-4 org Post #: 559402 posted 11/07/07 08:51 PM     Remind Me!  Send Private Message   Edit Post
ill buy your rack
Posts: 2309 | From: Fort Collins, Colorado | Member Since: 10/27/04 | IP: (71.196.161.121) | Report this post to a Moderator
keydiver
Galant VR-4 org Post #: 559426 posted 11/07/07 09:33 PM     Remind Me!  Send Private Message   Edit Post
Rack is already gone. Hobe Sound is in Southern Martin County, just north of Palm Beach County.
Jeff
Galant VR-4 org Post #: 559459 posted 11/07/07 10:10 PM     Remind Me!  Send Private Message   Edit Post
~Brian
Nope. Sold the other one already to SJG, right?
Posts: 10771 | From: Michigan | Member Since: 03/05/01 | IP: (65.73.152.188) | Report this post to a Moderator
keydiver
Galant VR-4 org Post #: 559545 posted 11/08/07 06:30 AM     Remind Me!  Send Private Message   Edit Post
Yes, Sam took possession of #880/1000 January 2006.
Jeff
a2vr4
Galant VR-4 org Post #: 559596 posted 11/08/07 08:12 AM     Remind Me!  Send Private Message   Edit Post
well then I must concur with kc!
~Brian
@garagemoreno
Posts: 1543 | From: Ann Arbor MI | Member Since: 08/13/05 | IP: (67.38.2.36) | Report this post to a Moderator
sjg
Galant VR-4 org Post #: 559757 posted 11/08/07 11:21 AM     Remind Me!  Send Private Message   Edit Post
Jeff
Yep, It's broken down in my driveway right now.
Jeff is a great guy to buy a car from. He maintains them meticulously and always does the work right, and he isn't afraid to tell you what's wrong with it if anything. This is a good deal for someone.
| | | IP: (67.1.178.188) | Report this post to a Moderator
crankwalk
Galant VR-4 org Post #: 560209 posted 11/09/07 08:14 AM     Remind Me!  Send Private Message   Edit Post
Saw it in person back in June and when you see the engine bay in person you can REALLY tell that details were put into that car. Great example of a stock looking car and then when you pop the hood its "WOW!"
Good luck!
| | | IP: (24.99.218.210) | Report this post to a Moderator
keydiver
Galant VR-4 org Post #: 560216 posted 11/09/07 08:35 AM     Remind Me!  Send Private Message   Edit Post
Gotta love a sleeper! I've tried to keep the car as stock looking outside as possible, so as not to attract too much attention. Walk softly and carry a big stick, I always say.
| | | IP: (74.253.123.163) | Report this post to a Moderator
getboosted
Galant VR-4 org Post #: 560406 posted 11/09/07 02:53 PM     Remind Me!  Send Private Message   Edit Post
Does your car still have working A/C? Too many great cars for sale lately! Thanks.
____________________
Posts: 135 | From: Charlotte, NC, USA | Member Since: 12/05/02 | IP: (70.159.60.130) | Report this post to a Moderator
keydiver
Galant VR-4 org Post #: 560471 posted 11/09/07 05:44 PM     Remind Me!  Send Private Message   Edit Post
Yes. I had it professionally converted to R134A a few years ago, and it was still blowing VERY cold last time I used it. You can't live in south Florida without A/C.
| | | IP: (65.8.124.176) | Report this post to a Moderator
keydiver
Galant VR-4 org Post #: 560725 posted 11/10/07 05:39 PM     Remind Me!  Send Private Message   Edit Post
Some guys have been asking for interior shots. The rear interior is mint, looks like new. The front mats are a little worn, but they ARE original 16 year old mats! The sun had started going down, so sorry for a couple of blurry pix:
keydiver
Galant VR-4 org Post #: 560969 posted 11/11/07 04:43 PM     Remind Me!  Send Private Message   Edit Post
I found some more pictures in Member's Rides:
Member's Rides
and some from the Florida meet earlier this year:
Kelly Park
Edited by keydiver (11/11/07 04:44 PM)
SirSteele
Galant VR-4 org Post #: 561519 posted 11/13/07 12:33 AM     Remind Me!  Send Private Message   Edit Post
Check your PM's.
| | | IP: (12.218.247.231) | Report this post to a Moderator
Nate
May I have your autograph?
Galant VR-4 org Post #: 563409 posted 11/17/07 06:47 AM     Remind Me!  Send Private Message   Edit Post
Bump for a really clean, extremely well taken care of car.
Posts: 944 | From: Worcester, Pa | Member Since: 02/23/01 | IP: (68.80.219.189) | Report this post to a Moderator
Garfield Wright
Galant VR-4 org Post #: 566386 posted 11/24/07 10:27 AM     Remind Me!  Send Private Message   Edit Post
I stopped by Jeff yesterday & test drove this car. Jeff has done a wonderful job with it & the car is flawless. It pulls like a freight train @ 21psi on the evo3 16g, stops very good & handles impressively.
If anyone is condisering buying this car, you shouldn't think twice about it. I personally guarantee it's everything Jeff says it is & more If I had the funds when I stopped by, I would've brought it home with me.
| | | IP: (75.74.8.7) | Report this post to a Moderator
4nmscle
Member +
Galant VR-4 org Post #: 566642 posted 11/25/07 02:00 PM     Remind Me!  Send Private Message   Edit Post
what are you using for tunning?
is it just a chippd ecu?
Posts: 362 | From: Harvest,AL | Member Since: 05/31/07 | IP: (65.4.24.35) | Report this post to a Moderator
keydiver
Galant VR-4 org Post #: 566651 posted 11/25/07 02:41 PM     Remind Me!  Send Private Message   Edit Post
You mention a "chippd ecu" like its a bad thing. I *had* an AFC and a wideband, and made adjustments to the timing and AFR maps in the chip until I was satisfied with the tune, and no longer needed to do any finetuning with the AFC, so I removed it.
| | | IP: (70.156.152.121) | Report this post to a Moderator
Pages: 1 | 2
0 registered and 18 anonymous users are browsing this forum.
Generated in 0.078 seconds in which 0.043 seconds were spent on a total of 14 queries. Turbo powered.
