Galant VR-4 Forums » Marketplace » Cars For Sale » SOLD: 1517/2000, NB, Aurora, CO, $4500 SOLD
Justin
Galant VR-4 org Post #: 1049690 posted 02/02/12 11:44 PM     Remind Me!  Send Private Message   Edit Post
Here is a current mod list for my car.
Engine:
.5mm oversized stock CR pistons
Stock reconditioned rods
Stock STD/STD crankshaft
ACL race bearings
BSE w/ OEM parts
MHI gasket set
MHI MLS head gasket
Stock rebuilt cylinder head
3G revised lifters
ARP head studs
Hyundai "smooth" valve cover
Stock intake manifold
NA throttle body
FP race exhaust manifold
FP Green turbocharger
-10 AN braided turbo oil return hose
Exhaust:
MAPerformance O2 housing
TiAL MV-S wastegate, recirculated
2.5" downpipe
3" cat or test pipe
3" cat back
3" Magnaflow dual tip muffler
(exhaust is designed to appear stock to uninformed folks)
Intake and Intercooler:
K+N air filter (designed for a PowerStroke)
3" intake pipe, cold air (custom)
2.5" hotside piping (custom)
24"x12"x3" core, 3" in and out (ebay)
3" cold side piping (custom)
3" GM MAF
Turbo XS Type H-RFL bov
Intercooler nitrous sprayer (not completed)
Electronics and fuel:
GM MAFT
SAFC2
Keydiver ECU w/ chip
HKS turbo timer
AEM Tru Boost
Glowshift oil pressure gauge
Glowshift WBO2
Glowshift EGT
FIC 750cc injectors
Fuelab remote AFPR
Walbro 255 lph pump, rewired
Stock fuel rail
Liquid filled fuel pressure gauge
Cooling:
Stock radiator (new)
OEM thermostat
Aftermarket 12" "pusher" fan
Aftermarket 10" "pusher" fan
6"x11"x1" oil cooler
-8 AN oil cooler lines
1990 DSM oil filter housing
Transmission:
Jack's build (23 spline)
DSM gearset
1st and 2nd double synchro
4-spider diff
Remaining drivetrain:
Prothane engine/trans mounts
Competition Clutch Stage 5 PP
4 puck unsprung disc
RRE "no name" flywheel
Comp Clutch forged clutch fork
3/4" bore slave
Braided clutch flex hose
OEM rebuilt master
DSM M/C reservoir
4-bolt rear diff
1G rear subframe
5-lug conversion
Filled carrier bearings
Torque Solution carrier bushings
Steering:
4WS delete
DSM front steering rack
DSM reservoir
Large P/S cooler
Brakes/wheels:
Recently replaced OEM brake master cylinder
Stock rotors
Stock calipers
ABS delete
Stainless braided flex lines
4G Eclipse 17x7.5 five spoke
235/45R17 97V Goodyear Eagle rubber
Suspension:
Stock springs
Monroe struts
Stock swaybars
Poly front subframe bushings
Poly front control arm bushings
Poly front swaybar bushings
Exterior:
93 headlights
DIY amber corners
JDM fenders
Notorious bumper mod
Misc.:
Trunk mounted Optima battery
Lots of additional ground straps
Grant steering wheel
Cruise control delete
Emissions delete (still has a cat)
A/C delete
Poly shifter base bushings
1G shifter with Galant knob
Welded pedal assembly
Please click my build thread in my signature and read it. That tells the vast majority of the story.
Car currently has approximately 170,000 miles on the chassis. The engine, trans, and clutch all have less than 5,000 miles. The turbo has less than 10,000 miles.
I have owned this car since July of '05. I simply am growing restless with it and want to see someone get some enjoyment out of it. The car is solid mechanically. Cosmetically, it is a bit rough. It has never been in any major accidents, but there are numerous scratches, dents, dings and other small imperfections. The JDM fenders are JDM "carbon black", not Nile Black. The front bumper is Belize Green. There are some panels missing/broken in the inerior. You'll get replacements with the sale. Rust is minimal, and is isolated to the inside of the front fenders behind the the front tires. The tires are in great shape, and were installed just before Christmas last year.
There is a crack that runs the entire width of the windshield, but is below the vision line. The antenna is MIA and has a piece of tape blocking the hole from the inside.
I bought this car for a ridiculous $300 dollars. It was worth maybe $250. It needed everything. This means that much of the car has received my attention. In the time that I have owned this vehicle, I have replaced the front wheel bearings, ball joints (twice), tie rod ends, sway bar endlinks, front axles, shifter cables, front strut bearing plates, struts, and I'm sure more that I am forgetting. I also performed every mod to this car. The stereo is a Pioneer head unit and Pioneer speakers. The stereo is nothing special. It currently is only good for CD's because there is no antenna.
When I built this engine, I used a brand new OEM hydraulic tensioner for the timing belt, new water pump, ALL new coolant hoses, new clamps, new vacuum hoses, a perfect timing belt cover, new radiator, new oil cooler, new OFH, all new belts, new plug wires, OEM PCV valve, Evo half moon plug.
Heat blows hot.
Wipers work.
Rear defroster is not working.
Sunroof goes back, but not up.
If you use the drivers door to lock/unlock the car, the passenger front door does not respond. If you use the passenger front door to lock/unlock the car, all doors respond as normal.
Windows work.
No tint.
Clock works.
Automatic seatbelts work.
Dash plaque is still there.
Many more pics are available, and more can be taken. Just ask.
Edited by galant1517 (05/03/12 08:09 PM)
| | | IP: (208.54.38.155) | Report this post to a Moderator
Okayplayer
Member +
1968/2000
Galant VR-4 org Post #: 1049775 posted 02/03/12 01:29 PM     Remind Me!  Send Private Message   Edit Post
I can't believe you are selling her Justin, what's the next project? Rear wheel drive I'm guessing. GLWS
My car eats turbos
1991 Galant VR4 (1968/2000 NB)
2006 Galant SE
1986 Chevy C10
Posts: 255 | From: Denver, CO | Member Since: 01/14/10 | IP: (75.71.188.11) | Report this post to a Moderator
Justin
Galant VR-4 org Post #: 1049883 posted 02/04/12 02:15 AM     Remind Me!  Send Private Message   Edit Post
| | | IP: (208.54.38.156) | Report this post to a Moderator
Justin
Galant VR-4 org Post #: 1049954 posted 02/04/12 02:29 PM     Remind Me!  Send Private Message   Edit Post
Current pic of the engine compartment...
| | | IP: (208.54.38.162) | Report this post to a Moderator
GVR4NGER694
Galant VR-4 org Post #: 1050048 posted 02/05/12 02:44 AM     Remind Me!  Send Private Message   Edit Post
It's nice man... You should get what you want for
| | | IP: (75.166.116.136) | Report this post to a Moderator
Justin
Galant VR-4 org Post #: 1050109 posted 02/05/12 04:45 PM     Remind Me!  Send Private Message   Edit Post
I have been slowly adding info to the original post so please be sure to check back to it.
turbojew
Small Tattoo of 97 Chrysler Concorde on Left Buttock
Galant VR-4 org Post #: 1050772 posted 02/08/12 11:11 PM     Remind Me!  Send Private Message   Edit Post
Are you interested in any trades?
97 Chrysler Concorde 20k original
89 Mitsubishi Starion Sold
I vant b0000000000000000st.
Posts: 126 | From: Dallas, Tx | Member Since: 01/02/12 | IP: (24.38.213.61) | Report this post to a Moderator
Justin
Galant VR-4 org Post #: 1050945 posted 02/09/12 07:12 PM     Remind Me!  Send Private Message   Edit Post
I'm open to the idea of a trade, although I'd prefer to just sell it.
Unfortunately I'm not interested in a Starion. I've already had two of them.
| | | IP: (208.54.38.225) | Report this post to a Moderator
turbojew
Galant VR-4 org Post #: 1050973 posted 02/09/12 08:59 PM     Remind Me!  Send Private Message   Edit Post
Interested in a 51 nash ambassador? Needs resto
95 yukon 255k new trans has a lil body damage
99 sable 160k newer trans and new fuel pump n tires n brakes
Edited by turbojew (02/09/12 09:02 PM)
Justin
Galant VR-4 org Post #: 1050980 posted 02/09/12 09:17 PM     Remind Me!  Send Private Message   Edit Post
I would take a NICE square body extended cab S-10 2WD + cash.
Also interested in 60's era Volvo 122's, and 144's.
I would take a Buick Grand National, GMC Cyclone, and potentially others, but unfortunately not a Nash or Yukon, and definately not a Sable. Sorry.
Justin
Galant VR-4 org Post #: 1052306 posted 02/18/12 01:00 AM     Remind Me!  Send Private Message   Edit Post
craigslist ad
Edited by galant1517 (03/11/12 05:27 PM)
| | | IP: (208.54.38.189) | Report this post to a Moderator
GVR47111K
slurpees, hot dogs and pickled eggs are still offered
711/1000
Galant VR-4 org Post #: 1052363 posted 02/18/12 05:10 PM     Remind Me!  Send Private Message   Edit Post
Hang on to it for awhile while I save up and I'll give you 711 plus 4k
-Will V.
'92 #711/1000 KG
If it works, you learn something. If it breaks, you learn even more.
Posts: 457 | From: 80022, CO | Member Since: 11/07/11 | IP: (184.96.23.42) | Report this post to a Moderator
mikeromero
Galant VR-4 org Post #: 1053231 posted 02/24/12 10:15 PM     Remind Me!  Send Private Message   Edit Post
:Would u take 5K
| | | IP: (24.8.200.69) | Report this post to a Moderator
Justin
Galant VR-4 org Post #: 1053235 posted 02/24/12 10:35 PM     Remind Me!  Send Private Message   Edit Post
That's too low.
| | | IP: (208.54.32.146) | Report this post to a Moderator
Justin
Galant VR-4 org Post #: 1055898 posted 03/10/12 11:19 PM     Remind Me!  Send Private Message   Edit Post
bump
Drivers seat
Edited by galant1517 (03/11/12 06:11 PM)
| | | IP: (208.54.40.247) | Report this post to a Moderator
Justin
Galant VR-4 org Post #: 1056211 posted 03/12/12 09:53 PM     Remind Me!  Send Private Message   Edit Post
I was able to get over to a friends shop this afternoon and put her on the lift.
These two shots show the 4-bolt LSD rear.
This shot shows the ground that is run from the battery all the way to the engine, and lack of rust.
General underside of car, no rust, 3 inch press bent exhaust.
2.5 inch mandrel bent downpipe and underside of engine
Oil cooler and lines
The lighting sucks but this is the rear of the car.
| | | IP: (208.54.38.167) | Report this post to a Moderator
Justin
Galant VR-4 org Post #: 1059056 posted 03/26/12 10:03 PM     Remind Me!  Send Private Message   Edit Post
Bumpity
| | | IP: (208.54.38.150) | Report this post to a Moderator
Justin
Galant VR-4 org Post #: 1063294 posted 04/19/12 09:18 PM     Remind Me!  Send Private Message   Edit Post
Considering trying to sell all of my spare parts seperately.
Bump for this, and $4,500.00 OBO CAR ONLY.
Edited by galant1517 (04/26/12 08:21 PM)
| | | IP: (208.72.68.226) | Report this post to a Moderator
Diego
Mad Hatter Suite Touche Debackle Guage filled by Justin
1309/2000
Galant VR-4 org Post #: 1063363 posted 04/20/12 08:54 AM     Remind Me!  Send Private Message   Edit Post
Ohhhh parts... I will take the 4 bolt I never grabbed... a 5lug swap, and.... a PS Fender that is on your wall... after that there is sunroof motor... but I don't think I seen it when we were in there.
"I love blackjack. But I'm not addicted to gambling. I'm addicted to sitting in a semi circle."
91 nile black vr4, 1309/2000
Posts: 2132 | From: In a van down by the river, Io... | Member Since: 12/09/07 | IP: (72.24.236.141) | Report this post to a Moderator
Justin
Galant VR-4 org Post #: 1063381 posted 04/20/12 10:38 AM     Remind Me!  Send Private Message   Edit Post
got a sunroof motor. the assembled four bolt will be expensive to ship. but i dont have any front knuckles for the 5 lug.
Justin
Galant VR-4 org Post #: 1064573 posted 04/26/12 08:23 PM     Remind Me!  Send Private Message   Edit Post
New price, $4500 firm. I found something else I want and this needs to go.
GVR47111K
711/1000
Galant VR-4 org Post #: 1065559 posted 05/03/12 09:55 AM     Remind Me!  Send Private Message   Edit Post
Damn, you sold it? What's next for you? RWD?
-Will V.
'92 #711/1000 KG
Posts: 457 | From: 80022, CO | Member Since: 11/07/11 | IP: (66.110.182.2) | Report this post to a Moderator
Justin
Galant VR-4 org Post #: 1065620 posted 05/03/12 04:39 PM     Remind Me!  Send Private Message   Edit Post
Yep, it is gone. It went last night. Not exactly sure what's coming next, but I'm not looking for another project. The vehicle I was looking at got sold before I sold 1517, so back to the drawing board...
| | | IP: (208.54.38.147) | Report this post to a Moderator
GVR47111K
711/1000
Galant VR-4 org Post #: 1065622 posted 05/03/12 04:47 PM     Remind Me!  Send Private Message   Edit Post
To a board memeber? Or soon to be board member?
-Will V.
'92 #711/1000 KG
Justin
Galant VR-4 org Post #: 1065630 posted 05/03/12 05:37 PM     Remind Me!  Send Private Message   Edit Post
Maybe...
1 registered and 25 anonymous users are browsing this forum.
Generated in 0.077 seconds in which 0.041 seconds were spent on a total of 14 queries. Turbo powered.
