Galant VR-4 Forums » Marketplace » Cars For Sale » FS: 1992 Galant VR4 Green 297/1000, Toms River, NJ, $3500 OBO
whitetalon92
Galant VR-4 org Post #: 1039197 posted 12/10/11 06:33 PM     Remind Me!  Send Private Message   Edit Post
I'm listing my 1992 Mitsubishi Galant VR4. The reason for selling is simply no time for it or DSM's anymore. Have gotten into a turbo E36 M3
ASKING
. -3500 O/B/O
Mod List:
Stock longblock with around 80k on it. (Bought the motor off Nate)(compression numbers are 155-156 across the board)
60-1 garret turbine w/ mitsu exaust housin
ACT 2600 Clutch (basically new less then 1k miles)
Stock resurfaced flywheel
bosch spark plug wires with new NGK bpr7es plugs
removed 4ws system and lines installed 4 bolt rear with axles and LSD
relocated battery to trunk
walbro 255 hp fuel pump w/ rewire kit
white line front and rear sway bars
white line front and rear strut tower bars
Front and rear powerstop rotors and metalmaster pads
SS brake lines
1g steering wheel
2g mas
Kenwood DVD player and drop down dvd screen in the rear
Custom Seude and leather interior with embroidered VR-4 in the front and back seats w/ Starion head rests
Apexi AVCR -works intermitently (may need to be repaired by Apexi)
Autometer mech oil pressure guage
Autometer egt guage w/ TRE egt probe
Autometer Boost guage in odometer cluster also comes with the stock cluster
powder coated engine mounts w/ prothane inserts
HKS SSQV BOV
Powder coated wiper arms and trim
Polyurethane A- arm bushings
Aeromotive FPR
-6 an fittings and SS fuel line from tank to fuel rail
Ported SBR exhaust manifold
3in turbo back exhaust with ceramic coated 2.5in O2 housing
DSM link V2
AEM Wide-band O2
Tires replaced
*upgraded black* ISC
Wheel bearings replaced
Igniter replaced
New Mitsu OEM oil pan
Custom FMIC with 2.5 pipes and core dimensions 24x12x3 with 3in end tanks
FIC 850 injectors
THE BAD
1. Power Steering Leak, from what I can tell the lines started to rust out.
2. Back Passenger door has a dent/crease from what looks as though it can be repaired quite easily and cheaply. never had it checked out as it did not bother me at all.
3. Idle issue that I am working on as the car is for sale.
4. MAY need clutch slave cylinder replaced, replaced with extended rod and adjusted and car will shift fine normally. Does fight you should you try to rip thru gears. (Including replacement with sale, if I cant get around to getting it installed)
5. The only other bad I can really say that I can think of is paint oxidation on hood,roof, and trunk spoiler(typical spots and somewhat easily replaceable)
If you should have any questions either PM me here, ask in the thread or feel free to text at 732-300-6011.
Some pics
Edited by whitetalon92 (11/09/12 10:28 PM)
Posts: 27 | From: Lakewood,NJ | Member Since: 03/02/09 | IP: (76.117.220.29) | Report this post to a Moderator
whitetalon92
Galant VR-4 org Post #: 1039199 posted 12/10/11 06:41 PM     Remind Me!  Send Private Message   Edit Post
Some more Pictures. If someone would like any others let me know.
138/2000
152/1000
Galant VR-4 org Post #: 1039279 posted 12/11/11 05:23 AM     Remind Me!  Send Private Message   Edit Post
wow really nice car, if i had the money i would come get it now. GLWS
138/2000
152/1000
Posts: 3613 | From: Klamath Falls, Or | Member Since: 07/27/11 | IP: (70.44.2.98) | Report this post to a Moderator
whitetalon92
Galant VR-4 org Post #: 1039448 posted 12/12/11 02:06 AM     Remind Me!  Send Private Message   Edit Post
Quoting transparentdsm:
Thank you, your comment is much appreciated.
DSMGVR4
Trunk Flexion
Galant VR-4 org Post #: 1040839 posted 12/18/11 06:45 PM     Remind Me!  Send Private Message   Edit Post
Since the motor came out of an AT car, does it still have the smaller cams?
John
Posts: 643 | From: Piscataway, NJ | Member Since: 03/09/02 | IP: (24.44.101.163) | Report this post to a Moderator
whitetalon92
Galant VR-4 org Post #: 1040880 posted 12/18/11 11:36 PM     Remind Me!  Send Private Message   Edit Post
No, when the motor was timed stock turbo cams were used. should anyone be skeptical, I can include another set of stock turbo cams I have from a previous dsm I owned. Any other questions, let me know.
As well as a Price Bump 3900 O/B/O
Edited by whitetalon92 (12/19/11 12:19 AM)
twonineseven
Weird
324/1000
Galant VR-4 org Post #: 1041346 posted 12/21/11 03:17 PM     Remind Me!  Send Private Message   Edit Post
I really miss this car, free bump for a fun car to drive.
original post with pics of the custom interior
click,f12,&Words=&Searchpage=1&Limit=25&Main=841092&Search=true&where=bodysub&Name=6592&daterange=1&newerval=&newertype=&olderval=&oldertype=&bodyprev=#Post841092
Edited by twonineseven (12/21/11 03:26 PM)
Posts: 449 | From: Lancaster, Pa | Member Since: 04/29/07 | IP: (174.54.20.38) | Report this post to a Moderator
whitetalon92
Galant VR-4 org Post #: 1043047 posted 01/01/12 12:48 PM     Remind Me!  Send Private Message   Edit Post
New Years day bump. Looking to move the car soon, a few things the M3 needs that I wish to get done. Before I can do all that the vr4 has to go. So if anyone is interested in the car toss me a offer. Worse I can say is no, but as long as its not some obscene offer IE 2 bazooka bubblegum and a lollipop we may be able to come to some agreement. Looking forward to hear from forum members as I have no real desire to sell it to someone who is not a member or has no clue about the car. As stated in the first post any questions or concerns I can address just let me know, and I will respond as fast and prompt as I can. Take care and Have a good new year.
whitetalon92
Galant VR-4 org Post #: 1043388 posted 01/03/12 11:53 AM     Remind Me!  Send Private Message   Edit Post
Feeling a bit better, can contact me or him both can answer questions. So feel free to pm or text.
1.Andrew
2.732-300-6011 - text would be preferable
Should for some reason, you are unable to get a hold of me you can still get a hold of my friend. Though unless something happens, I should respond promptly or as promptly as I am able. Thanks again.
His contact info
1.Anthony
2.732-300-2952 - text preferable
Edited by whitetalon92 (01/05/12 04:15 AM)
turbojew
Small Tattoo of 97 Chrysler Concorde on Left Buttock
Galant VR-4 org Post #: 1043668 posted 01/04/12 03:31 PM     Remind Me!  Send Private Message   Edit Post
nice car would love to buy it as im in howell but i cant seem to sell my 89 starion.
97 Chrysler Concorde 20k original
89 Mitsubishi Starion Sold
I vant b0000000000000000st.
Posts: 126 | From: Dallas, Tx | Member Since: 01/02/12 | IP: (24.38.212.196) | Report this post to a Moderator
whitetalon92
Galant VR-4 org Post #: 1043806 posted 01/05/12 04:07 AM     Remind Me!  Send Private Message   Edit Post
Thanks for the compliment. Keep me up to date on your on your starion sale. Who knows depending on how long you may sell yours and be able to pick up mine. Good luck, and thanks again for the compliments.
138/2000
152/1000
Galant VR-4 org Post #: 1044437 posted 01/08/12 03:05 AM     Remind Me!  Send Private Message   Edit Post
you wouldn't want an 01 jetta 1.8t would ya??
138/2000
152/1000
turbojew
Galant VR-4 org Post #: 1044787 posted 01/10/12 12:10 AM     Remind Me!  Send Private Message   Edit Post
my dad is looking for a car and has 2500 to spend....maybe we can work something out.....
138/2000
152/1000
Galant VR-4 org Post #: 1044808 posted 01/10/12 05:04 AM     Remind Me!  Send Private Message   Edit Post
pm me about it, i my father and i own a car lot.
138/2000
152/1000
whitetalon92
Galant VR-4 org Post #: 1046205 posted 01/18/12 03:08 AM     Remind Me!  Send Private Message   Edit Post
Price Update - 3600 O/B/O
I am willing to work with people, but please be realistic.
Edited by whitetalon92 (01/30/12 08:38 PM)
whitetalon92
Galant VR-4 org Post #: 1049023 posted 01/30/12 08:40 PM     Remind Me!  Send Private Message   Edit Post
Giving it a bump...Also adding that I would be interested in trades + some cash. Not looking for a even trade though, have some things I have some small things I have to do so even trade is just not in the cards.
turbojew
Galant VR-4 org Post #: 1049032 posted 01/30/12 09:07 PM     Remind Me!  Send Private Message   Edit Post
Fix the idle issue? Still offering the 99 Sable fully loaded and some cash.
Posts: 126 | From: Dallas, Tx | Member Since: 01/02/12 | IP: (24.38.213.61) | Report this post to a Moderator
whitetalon92
Galant VR-4 org Post #: 1049343 posted 02/01/12 11:04 AM     Remind Me!  Send Private Message   Edit Post
Send me a PM with the offer and details on the car, and maybe we can work something out.
whitetalon92
Galant VR-4 org Post #: 1052707 posted 02/21/12 05:46 AM     Remind Me!  Send Private Message   Edit Post
Still for sale, wanting to move it as the M3 is staring me down and wants new shit heh..
turbojew
Galant VR-4 org Post #: 1054648 posted 03/03/12 10:36 PM     Remind Me!  Send Private Message   Edit Post
Have you fixed the idle issue and the slave cylinder?
whitetalon92
Galant VR-4 org Post #: 1054685 posted 03/04/12 02:27 AM     Remind Me!  Send Private Message   Edit Post
No, as far as the idle issue I believe its just something stupid such as adjusting setting in link for idle etc. The slave cylinder I have not replaced yet (part is bought already). Between lack of time since most my free time is spent with doctor visits and shit. The cold has also been a bit of a deterrent. Just to curtail any other inquiries about the issues listed I have no really gotten around to any of them mainly for the same reasons I listed above. Honestly though should all of the issues listed of been repaired by me the price would of been adjusted nor would it be this price. As is from my point of view I personally have spent enough on it, especially as I now have a different platform I prefer and always intended on getting. \
Should there be any other questions from anyone, please do not hesitate to ask I will respond as fast as I can. if there is a need for more pictures I will see what I can do to get them as fast as possible. There are other pictures on the site linked by the guy I bought the car from in this thread. It has pictures of the interior (fantastic looking), as well as pic of the stereo setup in the trunk (sounds great as well). Well that went on long enough, as I said any other questions just ask.
turbojew
Galant VR-4 org Post #: 1054958 posted 03/05/12 06:25 PM     Remind Me!  Send Private Message   Edit Post
Does the car have current inspection?
whitetalon92
Galant VR-4 org Post #: 1091570 posted 10/28/12 04:11 PM     Remind Me!  Send Private Message   Edit Post
Figure I would bump the thread. A lot has been going on and I have not been all that motivated. Still looking to sell it though, and didn't want to make a new thread to add to the clutter..
138/2000
152/1000
Galant VR-4 org Post #: 1091572 posted 10/28/12 04:28 PM     Remind Me!  Send Private Message   Edit Post
are you interested in any trades?? i have a 99 duragno with 141,xxx miles on it.
138/2000
152/1000
Posts: 3613 | From: Klamath Falls, Or | Member Since: 07/27/11 | IP: (70.44.237.230) | Report this post to a Moderator
1990/2000
Galant VR-4 org Post #: 1091671 posted 10/29/12 10:37 AM     Remind Me!  Send Private Message   Edit Post
Please put your asking price in the thread title, as per the rules for this section.
Thanks!
the bitterness of low quality remains long after the temporary joy of a low price has faded
Posts: 3533 | From: Never Summer Ranch, Colorado | Member Since: 04/30/06 | IP: (208.54.38.249) | Report this post to a Moderator
Pages: 1 | 2
1 registered and 26 anonymous users are browsing this forum.
Generated in 0.096 seconds in which 0.047 seconds were spent on a total of 14 queries. Turbo powered.
