Galant VR-4 Forums » Galant VR-4 » How To and Info Archive » 1g TEL shifter - Now with shift boot!
Key Fob Guy
Galant VR-4 org Post #: 83163 posted 01/21/04 08:00 AM     Remind Me!  Send Private Message   Edit Post
before:
after:
Damn thats better. Now I have to get my VR6Eater leather shift boot in there and put the whole console back together
:update: Got the VR6eater shift boot in there now. I ordered it for a stock shifter height but had to make it work with the DSM shifter.
Edited by steveVR4 (09/23/05 06:59 AM)
Posts: 18895 | From: NJ | Member Since: 09/11/03 | IP: (208.215.178.150) | Report this post to a Moderator
Pivvay
Galant VR-4 org Post #: 83164 posted 01/21/04 08:15 AM     Remind Me!  Send Private Message   Edit Post
looking good! i'm sporting the same setup. And don't worry, you'll get good at taking the console apart and putting it back together after you do it 50 more times [Razz]
| | | IP: (162.18.125.155) | Report this post to a Moderator
G-GSX Turbo
Galant VR-4 org Post #: 83165 posted 01/21/04 09:52 AM     Remind Me!  Send Private Message   Edit Post
I was going to be tackling this next after the fuel system is done.
I have a 90 and a 91 TEL shifter and boot. Which am I more than likely going to have to use?
Did you modify your's in anyway to shorten the throw?
Did you upgrade the cable heim joints to all steel units or did you just use the nylon ones?
| | | IP: (66.188.250.100) | Report this post to a Moderator
Key Fob Guy
Galant VR-4 org Post #: 83166 posted 01/21/04 10:15 AM     Remind Me!  Send Private Message   Edit Post
I believe the 90 is different and wont work. Don't quote me on that though.
I didn't modify it to shorten the throw, its just a normal stock DSM shifter.
I didn't have to mess with any "cable heim joints"... at least I don't think I did. [Confused]
G-GSX Turbo
Galant VR-4 org Post #: 83167 posted 01/21/04 10:26 AM     Remind Me!  Send Private Message   Edit Post
OK so these are the same as the 91's+ then? That's cool, I have both.
The heim joints I refer to are the little rod ends that the cables connect to on the shifter that actaute the linkages on the tranny. They have a nylon bushng in them vs a steel one.
It is an upgrade I saw somewhere but don't remember where. Here is a pic I pulled off the VFAQ to illistrate what I am reffering to.
They are 6mm Heim joints (or Rod end to some) and can be replaced for about $10.
This pic, while highlighting another part, you can see the nylon in the heim joint on the right. I pulled them off on one of the cars I got the shifters from, so I could have it to find a replacement, and it is VERY sloppy.
Key Fob Guy
Galant VR-4 org Post #: 83168 posted 01/21/04 11:04 PM     Remind Me!  Send Private Message   Edit Post
I'll have to take a look at that, but to answer your question then, I didn't mess with that, all I replaced was the actual shifter. Its much better already.
4drwhore
Galant VR-4 org Post #: 83169 posted 01/21/04 11:22 PM     Remind Me!  Send Private Message   Edit Post
Can I just swap out the actual shifter arm to a 91 and thats it? or do i have to change the whole assembly?
| | | IP: (65.83.172.250) | Report this post to a Moderator
Key Fob Guy
Galant VR-4 org Post #: 83170 posted 01/21/04 12:36 PM     Remind Me!  Send Private Message   Edit Post
Its just the shifter arm.... one bolt through the center, and a cotter pin holding it on at the bottom. You do have to loosen the whole console in order to be able to slide the arm on/off.
henrok
Galant VR-4 org Post #: 83171 posted 01/21/04 07:39 PM     Remind Me!  Send Private Message   Edit Post
hey sorry to get off the topic but how do u guys get your leather looking so soft and supple? most of your interior pics show nice and soft leather. can u fill me in on it?
| | | IP: (205.188.208.172) | Report this post to a Moderator
marvinmadman
136/1000
Galant VR-4 org Post #: 83172 posted 01/21/04 07:47 PM     Remind Me!  Send Private Message   Edit Post
Yeah me too, car was sitting for a year before I bought it. [Frown] leather = hard
Posts: 2354 | From: Lafayette, Louisiana | Member Since: 11/10/03 | IP: (66.79.1.102) | Report this post to a Moderator
MMorgan
294/1000
Galant VR-4 org Post #: 83173 posted 01/21/04 07:53 PM     Remind Me!  Send Private Message   Edit Post
http://www.ikeya-f.co.jp/english/index.html
anyone ever seen the Ikeya Forumula Sequential shifter? would any of you consider something like this? they should make one for our cars
Posts: 1918 | From: Haymarket, VA | Member Since: 03/16/03 | IP: (152.163.252.136) | Report this post to a Moderator
Generated in 0.043 seconds in which 0.027 seconds were spent on a total of 14 queries. Turbo powered.
