Galant VR-4 Forums » Galant VR-4 » How To and Info Archive » GVR4 - running list of items to eliminate/convert...
sleepyvr4
I Hate Kitty Cats
Galant VR-4 org Post #: 810696 posted 07/14/09 07:58 AM     Remind Me!  Send Private Message   Edit Post
Stage 1 Weight Reduction:
Basic GVR4 stock parts (including engine) to eliminate/modify to reduce weight without compromising safety, emissions, driveability, or anything else "normal"...
1. ABS to non-abs - Click here for how to...
2. Power Steering to 1.8 manual rack, or simply remove all components
3. 4WS (new rear DSM subframe or block off)
4. Cruise Control to DSM 1.8 cable
5. Power Antenna to stubby or shaved/plugged
6. Power Seatbelt to 3 point harness conversion or simply stock lap belt
7. Sounds deadening material removal
8. Power mirror to standard lightweight mirror conversion
9. Aluminum driveshaft(s) installed
10. Stock to Carbon fiber/lightweight hood, fenders, trunklid
11. Stock to lightweight wheels
12. Foglight removal
13. Balance shaft removal
14. Eliminate stock heat shields
15. EGR elimination
16. Lightweight battery
17. Alarm system removal
18. Tool kit, jack and spare tire
19. Stock to lightweight seat conversion
20. Race/Lightweight steering wheel
21. Sunroof elimination (lexan etc)
22. Lightweight flywheel install
23. Intake manifold bracket removal
24. Stock speaker amplifier removal (stereo remains)
25. Wiring harnesses hacked of useless wires
26. Lightweight exhaust (titanium?)
27. Eliminate spoiler
28. Aluminum transfer case install (???)
29. Dashboard hacking/gutting
30. Aluminum/Scirocco Radiator install
31. '92 Center tail light section swap
32. Suspension - save about 25lbs converting to coilovers
33. Under Dashboard Mat elimination
34. Driver's side Motor mount hack
Stage 2 Weight Reduction:
Advanced weight reduction techniques that are "quote unquote" legal/acceptable to some who would still consider the car a daily driver. Many of these cross well over into Stage 3 to some...
1. A/C & all components
2. Heater core/lines
3. Emissions & all related
4. Aluminum bumper install or bumper elimination (some people do this on DD)
5. Timing Cover(s) elimination
6. Stereo and all components removed
7. Remove door crashbars
8. Exhaust down pipe only
9. Eliminate glovebox
10. Stock gas tank to fuel cell
Stage 3 Weight Reduction:
Purely for race intentions - these modifications do not appear daily driver mode at all and compromise everything a daily driver is...
1. Remove all seats except driver's seat
2. Remove interior panels, console, carpet, trim etc.
3. Dashboard removal
4. Lexan to replace all windows
5. Eliminate exhaust
Edited by sleepyvr4 (09/12/09 06:32 AM)
Posts: 2359 | From: Key West | Member Since: 12/25/03 | IP: (65.113.95.97) | Report this post to a Moderator
OneTitle to rule them all.
77/2000
Galant VR-4 org Post #: 810725 posted 07/14/09 10:12 AM     Remind Me!  Send Private Message   Edit Post
Factory amplifier in trunk (if 1991)
Ryan Hertz
Posts: 13501 | From: Chicago, IL | Member Since: 07/29/02 | IP: (69.209.93.194) | Report this post to a Moderator
blacksheep
Baraqsheep
205/1000
Galant VR-4 org Post #: 810727 posted 07/14/09 10:19 AM     Remind Me!  Send Private Message   Edit Post
1) Interior Wiring harness modification - Remove all ABS, door sensors, auto belt wiring, stereo wiring, heat, AC, relays etc. You will be surprised. I removed about 10 lbs from my evo doing that. I am sure you can do engine bay harness too...
2) Fuel tank - run fuel cell!
3) Dash support beam/ door support beams
How "race" do you want it?
1992 Galant VR-4. 205/1000. Nile Black. Sunroof.
Posts: 15473 | From: Urbandale, Iowa 50323 | Member Since: 05/01/02 | IP: (206.195.193.254) | Report this post to a Moderator
9t1tsi
Galant VR-4 org Post #: 810740 posted 07/14/09 11:11 AM     Remind Me!  Send Private Message   Edit Post
how do you remove the heater core? Thats in the dash correct? so would you have to remove the entire dash before it can be done?
| | | IP: (71.244.246.175) | Report this post to a Moderator
blacksheep
Baraqsheep
205/1000
Galant VR-4 org Post #: 810753 posted 07/14/09 11:38 AM     Remind Me!  Send Private Message   Edit Post
Pretty sure dash has to come off although I havent done it in a gvr4, personally. You have to undo the two coolant lines running in/out the car on the firewall. Same for AC if you are pulling Evap.
sleepyvr4
I Hate Kitty Cats
Galant VR-4 org Post #: 810780 posted 07/14/09 01:26 PM     Remind Me!  Send Private Message   Edit Post
Not sure about heater core - may want to keep if car overheats and turning on heater fan is only option...
Balance shafts gotta go
CarRacer
Giant Sack of Ginger
83/2000
Galant VR-4 org Post #: 810877 posted 07/14/09 07:21 PM     Remind Me!  Send Private Message   Edit Post
Personally I'd keep the timing covers. No sense in letting a rock ruin your day.
I'd add the stock water/oil cooler as well as the water lines going to the turbo. It cleans things up a bunch.
James
83/2000
Missed Shift | Auto News
Posts: 4370 | From: Shakopee, MN | Member Since: 06/28/07 | IP: (166.205.4.17) | Report this post to a Moderator
BoostedAWD91
815/2000
Galant VR-4 org Post #: 810884 posted 07/14/09 07:51 PM     Remind Me!  Send Private Message   Edit Post
if u want to remove the heater core, u have to remove the entire dash. personally i would just leave it in unless its just a track car
#815/2000- Lexus Pearl White
Posts: 2937 | From: Danville,Pa | Member Since: 03/01/07 | IP: (159.240.11.254) | Report this post to a Moderator
Old Balls
425/1000
Galant VR-4 org Post #: 810887 posted 07/14/09 07:57 PM     Remind Me!  Send Private Message   Edit Post
One thing I would NOT eliminate.....A daily driver.
1992 Galant VR4 click
Edited by Terry Posten (07/14/09 07:58 PM)
Posts: 9009 | From: Davenport, Iowa USA | Member Since: 12/16/03 | IP: (173.27.93.117) | Report this post to a Moderator
TakumiJr
Member +
Galant VR-4 org Post #: 810945 posted 07/14/09 11:36 PM     Remind Me!  Send Private Message   Edit Post
Front seats with some milk crates
- '91 GVR4- JSB wannabee
Posts: 299 | From: MA | Member Since: 09/27/06 | IP: (66.152.233.10) | Report this post to a Moderator
sleepyvr4
I Hate Kitty Cats
Galant VR-4 org Post #: 810979 posted 07/15/09 05:27 AM     Remind Me!  Send Private Message   Edit Post
Quoting CarRacer:
Myself (for about a year on 1746) as well as about 3 dsm friends have been running w/o timing covers for years. One friend rallied a 1g awd auto on several occasions and never had any problems...
1941Galant
Will fight mice for food
1941/2000
Galant VR-4 org Post #: 810987 posted 07/15/09 07:19 AM     Remind Me!  Send Private Message   Edit Post
'89 underdash and glovebox will take a little weight off.
Posts: 1905 | From: Charles Town, WV | Member Since: 08/21/04 | IP: (70.44.252.218) | Report this post to a Moderator
1990ggsxnj
Member ++
1578/2000
Galant VR-4 org Post #: 811047 posted 07/15/09 11:38 AM     Remind Me!  Send Private Message   Edit Post
Quoting sleepyvr4:
Quoting CarRacer:
What do you gain out of doing this though??? Besides being able to change the belt without having to take it off.
"Is that Spool Drool? EWW!"
90GGSX Blue-Chesapeake
91GVR4 Nile Black-Sidney (Sid)
Posts: 525 | From: Blackwood, NJ | Member Since: 11/21/08 | IP: (12.175.119.20) | Report this post to a Moderator
324vr4
manly-loud yet refined
324/1000
Galant VR-4 org Post #: 811050 posted 07/15/09 11:43 AM     Remind Me!  Send Private Message   Edit Post
You can get close to 40lbs eliminating the sunroof too...and its at the TOP of the car where you don't want weight...haha ZAP
Posts: 1240 | From: Bozeman, Montana | Member Since: 04/28/06 | IP: (69.51.103.82) | Report this post to a Moderator
sleepyvr4
I Hate Kitty Cats
Galant VR-4 org Post #: 811091 posted 07/15/09 12:39 PM     Remind Me!  Send Private Message   Edit Post
Exactly. Change that baby when you change your plugs and oil lol...
Posts: 2359 | From: Key West | Member Since: 12/25/03 | IP: (12.156.182.26) | Report this post to a Moderator
throughfaith323
39, 40, 41
1922/2000
Galant VR-4 org Post #: 811108 posted 07/15/09 12:58 PM     Remind Me!  Send Private Message   Edit Post
both threads are really good. maybe someone can come up with a list and put things in order of what should be done first. things that are free and things that no one would mind removing. then things for race cars and then things that cost money... also things that are dangerous to remove/chnage.
after that list is compiled another thread can be started as maybe a sticky? i might be interested in starting this list when i get some extra time. hopefully someone else can start it too.
what you guys think?
1991 GVR4 1922/2000--selling performance parts
Posts: 528 | From: Forked River, NJ | Member Since: 09/24/08 | IP: (159.214.124.1) | Report this post to a Moderator
sleepyvr4
I Hate Kitty Cats
Galant VR-4 org Post #: 811242 posted 07/15/09 06:49 PM     Remind Me!  Send Private Message   Edit Post
that's what we can compile here on this thread -
how about 3 sections:
1. basic crap to remove that does not affect driveability or emission laws or safety etc...
2. advanced weight reduction techniques that are "quote unquote" legal/acceptable to some who would still consider daily driver
3. all out race purpose weight reduction mods
I'll compile it up top on this thread...
feedback appreciated - I'll keep adding ideas...
sleepyvr4
I Hate Kitty Cats
Galant VR-4 org Post #: 811255 posted 07/15/09 07:42 PM     Remind Me!  Send Private Message   Edit Post
feel free to PM me new ideas - discrepancies can be posted in the thread for debate...
throughfaith323
39, 40, 41
1922/2000
Galant VR-4 org Post #: 811269 posted 07/15/09 08:08 PM     Remind Me!  Send Private Message   Edit Post
sounds good to me...i want to come up with more sections to make it more specific maybe after we have a lot of stuff.
like
-safety(removing bumper supports, jack/spare tire etc)
-luxury(cruise, AC, heater core, some interior, PS, etc)
-things you can buy(bumpers, cf hood, cf trunk, flywheel, driveshaft, wheels, seets, under dash, balance shaft elim, glove box, antenna, seat belts/harness, etc)
-emissions(egr,charcoal canister, etc)
-things that prob only a track car would do that would change the car alot(lexon windows, as much interior as possible, etc)
there is absolutely nothing wrong with yours its just that i like to be very specific and this is the type of list i had in mind. it helps so that people know what list they can ignore and what list to look at.
Posts: 528 | From: Forked River, NJ | Member Since: 09/24/08 | IP: (72.90.1.190) | Report this post to a Moderator
throughfaith323
39, 40, 41
1922/2000
Galant VR-4 org Post #: 811271 posted 07/15/09 08:11 PM     Remind Me!  Send Private Message   Edit Post
my bad man i didnt see your list . i like that stage idea. i say you make both cause the stage idea is cool and then if you want to just look right to a specific category you can look at what i had for categorys. know what i'm saying? i def like both tho. nice list
eviLntt
eVIL_DNB
938/1000
Galant VR-4 org Post #: 811365 posted 07/16/09 01:11 AM     Remind Me!  Send Private Message   Edit Post
Aluminum radiator? How about switching out the the tail light center piece for one without lights in it (only the 92's?).
Posts: 1026 | From: Santa Rosa, CA | Member Since: 04/03/06 | IP: (71.135.110.228) | Report this post to a Moderator
galantgti
Galant VR-4 org Post #: 811372 posted 07/16/09 02:16 AM     Remind Me!  Send Private Message   Edit Post
Man, i just don't get it. I really don't get it. Why buy a rare VR4 if you are going to delete everything? Just buy a GSX or something, put a 4g63T in it, and delete everything from that one. The outcome is exactly thesame, the only difference is that you aren't fucking up another one from the 3000 rare vr4's....
Anyway, why would you seriously remove the timing covers?? They weigh almost nothing, and a small rock can be enough to f*ck everything up. Not everything is about weight, there's a bit of safety involved as well. Safety to keep your engine running, and what you are doing now is just dumb. If you didn't need timing covers, don't you think that they where never installed then? That's almost thesame as removing your valvecover for weight reduction....
Just my 0.02 $
| | | IP: (86.80.16.73) | Report this post to a Moderator
sleepyvr4
I Hate Kitty Cats
Galant VR-4 org Post #: 811379 posted 07/16/09 05:19 AM     Remind Me!  Send Private Message   Edit Post
If you remove the valve cover oil will spew everywhere
sleepyvr4
I Hate Kitty Cats
Galant VR-4 org Post #: 811381 posted 07/16/09 05:33 AM     Remind Me!  Send Private Message   Edit Post
Quoting galantgti:
Just my 0.02 $
Listen gti - don't get your loincloth in a stiff over this - no one is saying that these mods have to be done. Some people have different interests with the car. This is simply a list of what one could do in order to reduce weight for obvious track reasons all while really making the car less leaky, replacing 20 year old parts, cleaning up that circus of an engine bay, etc. Tell you what - when I eliminate my timing cover I'll donate it to you - then you can put two on your car for added safety!!! You know people have actually had timing belts fail because the timing cover collected debris and eventually it ended up in the belt?!? That belt is moving so effin fast that the tiniest rock making contact with the belt is going to zing off into outer space - as opposed to actually traveling through a gear and the belt with the belt going 1,800rpm. We need a myth buster on this...
galantgti
Galant VR-4 org Post #: 811383 posted 07/16/09 06:05 AM     Remind Me!  Send Private Message   Edit Post
Wasn't meant to be personal towards you
You do that, always wanted a second timing cover. I'm going to glue it on the other one to make it stronger....
Pages: 1 | 2
0 registered and 2 anonymous users are browsing this forum.
Generated in 0.058 seconds in which 0.013 seconds were spent on a total of 14 queries. Turbo powered.
