Galant VR-4 Forums » Galant VR-4 » How To and Info Archive » 2-Bulb Corner Wiring
gvr4_power
Galant VR-4 org Post #: 306462 posted 02/14/06 01:53 PM     Remind Me!  Send Private Message   Edit Post
I already searched, but didn't find anything definitive.
1. Can I pull the wiring harness our of the plug and put it in the JDM on (individual wires)?
2. To avoid ricer "speed blinkers", how should I wire the turn signals (series or parallel)?
| | | IP: (67.133.157.138) | Report this post to a Moderator
OneTitle to rule them all.
77/2000
Galant VR-4 org Post #: 306464 posted 02/14/06 01:57 PM     Remind Me!  Send Private Message   Edit Post
There should be three wires coming from dual-bulb corners.
Ryan Hertz
Posts: 13501 | From: Chicago, IL | Member Since: 07/29/02 | IP: (68.254.141.65) | Report this post to a Moderator
gvr4_power
Galant VR-4 org Post #: 306473 posted 02/14/06 02:21 PM     Remind Me!  Send Private Message   Edit Post
Sorry, I guess I should clarify the drawing and make sure I have it right.
The corner parking lights and corner turn signals have a common ground, correct? Looking at the connector, I can figure out which positive goes to the parking lights, and which goes to the signals.
The drawing just uses the + and - for the turn signals. I ignored the parking light.
77/2000
Galant VR-4 org Post #: 306476 posted 02/14/06 02:28 PM     Remind Me!  Send Private Message   Edit Post
Yes common ground. I don't think that serial/parallel will make any difference in the blink rate. The blinker just "senses" the load and I believe either way the load will be the same.
Ryan Hertz
gvr4_power
Galant VR-4 org Post #: 306481 posted 02/14/06 02:35 PM     Remind Me!  Send Private Message   Edit Post
So it's speed blinkers no matter what?
misterfixit
Victory Runner
Galant VR-4 org Post #: 307404 posted 02/16/06 12:32 PM     Remind Me!  Send Private Message   Edit Post
All blinkers are parallel, THe front and rear bulb have to be hooked like that otherwise whan youblow a bulb you'd loose them. The Wattage (load) is what is wrong. You'll have to hook your original front blinker in parallel with the rear bulb on the jdm 2 bulb corner. the front bulb on the corner is just a sidelight.
Rich
92 UK 1800 GALANT DD
88 JDM E39A GALANT VR-4, running. But only just.
93 CB4A --- rewound
91 PDM GTI Resurection project. Aborted
Stuff Index
Posts: 1559 | From: Midlands, UK | Member Since: 08/04/04 | IP: (83.67.111.64) | Report this post to a Moderator
gvr4_power
Galant VR-4 org Post #: 307506 posted 02/16/06 04:08 PM     Remind Me!  Send Private Message   Edit Post
Ok, I'll give that a try. Thanks!
0 registered and 24 anonymous users are browsing this forum.
Generated in 0.023 seconds in which 0.012 seconds were spent on a total of 14 queries. Turbo powered.
