Galant VR-4 Forums » Galant VR-4 » How To and Info Archive » FREE mod: short-throw shifter
Luke
201/2000
Galant VR-4 org Post #: 228216 posted 06/17/05 09:59 AM     Remind Me!  Send Private Message   Edit Post
Simply drill and tap on the shift lever closer to the pivot point.
I moved inwards by about 33% or so, resulting in 33% shorter throw back-and-forth in the cabin.
I used "8mm X 1.25" which matches perfectly with the diameter of the stock pin.
You will also need to make the rubber-stopper thicker in the shifter base. Otherwise, you run the risk of breaking your shift fork when you shifting hard.
I have run with this mod for almost 2 years, and no issue.
2.3L 6-bolt, BJ's ported 2G head, TRE tranny, GT3076R, 255lph, 850cc, AFPR, ROM emulator, Aquamist, ETS FMIC, LSD rr Quaife ft diff, WL swaybars, Bilstein, HKS 264/272 cams, ZT2 WBO2
Posts: 752 | From: San Jose, CA | Member Since: 07/16/02 | IP: (209.213.198.25) | Report this post to a Moderator
mistaVR4
Rest in Peace
484/1000
Galant VR-4 org Post #: 228223 posted 06/17/05 10:35 AM     Remind Me!  Send Private Message   Edit Post
Thats pretty cool man! Can you get a pick of the thicker rubber stopper you put in the shift base also.?
Thanks,
-Steve
SteveW
484/1000 Kensington Grey - Running VERY well :-)
564/2000 Belize Green ~ SOLD
749/2000 Summit White ~ SOLD
1989 Chrysler Conquest TSi SHP ~ SOLD
2004 Saab 9-5 ARC ~ Daily Driver
Posts: 4768 | From: Boulder, CO | Member Since: 12/16/03 | IP: (162.18.75.92) | Report this post to a Moderator
bazeng
work in progress
Galant VR-4 org Post #: 228308 posted 06/17/05 05:47 PM     Remind Me!  Send Private Message   Edit Post
wicked!!!
Australia's Slowest VR4
Posts: 2520 | From: Melbourne, Australia | Member Since: 02/06/03 | IP: (211.28.99.35) | Report this post to a Moderator
Luke
201/2000
Galant VR-4 org Post #: 228351 posted 06/17/05 08:18 PM     Remind Me!  Send Private Message   Edit Post
For the bump stopper on the shifter base, simply cut a small section of a hose and zip tie around the stock stopper to make it thicker.
Like so..
Posts: 752 | From: San Jose, CA | Member Since: 07/16/02 | IP: (64.169.94.111) | Report this post to a Moderator
Luke
201/2000
Galant VR-4 org Post #: 228353 posted 06/17/05 08:20 PM     Remind Me!  Send Private Message   Edit Post
In addition, to install a leather shift boot, you can reuse the bottom portion of your old accordion-style rubber boot.
Like so.
What the shifter looks like:
SGTdave
Galant VR-4 org Post #: 228538 posted 06/19/05 01:02 AM     Remind Me!  Send Private Message   Edit Post
Thats pretty cool Luke,
How far down the shift lever do you drill the hole. like a 1/2 inch or somthing
| | | IP: (68.7.120.26) | Report this post to a Moderator
Luke
201/2000
Galant VR-4 org Post #: 228545 posted 06/19/05 01:22 AM     Remind Me!  Send Private Message   Edit Post
I drilled it all the way through, and also tap it all the way through the lever.
Then I use a bolt, a washer, and a nylon lock-nut at the bottom..
I will try to take a picture of this.
The bolt does not clamp down on the shifter bushings.
The lock-nut at the bottom of the lever kinda acts like a jam nut.
91VR4NNJ
Galant VR-4 org Post #: 228558 posted 06/19/05 06:32 AM     Remind Me!  Send Private Message   Edit Post
MODS: Can you make this one a sticky in the "how to section?"
| | | IP: (70.111.15.75) | Report this post to a Moderator
Ian M
waiting for the bus
487/2000
Galant VR-4 org Post #: 228571 posted 06/19/05 09:22 AM     Remind Me!  Send Private Message   Edit Post
Here is another similar,with adjustable shift stops,off VFAQ.com:
http://mario.germain.com/shifter.html
#487/2000 Summit White
Edited by Ian M (06/19/05 09:25 AM)
Posts: 2348 | From: Martinsburg,WV | Member Since: 01/11/02 | IP: (69.160.67.86) | Report this post to a Moderator
0 registered and 2 anonymous users are browsing this forum.
Generated in 0.021 seconds in which 0.012 seconds were spent on a total of 14 queries. Turbo powered.
