FREE mod: short-throw shifter
Luke Senior Member 201/2000
posted 06/17/05 09:59 AM
Simply drill and tap on the shift lever closer to the pivot point. I moved inwards by about 33% or so, resulting in 33% shorter throw back-and-forth in the cabin. I used "8mm X 1.25" which matches perfectly with the diameter of the stock pin. You will also need to make the rubber-stopper thicker in the shifter base. Otherwise, you run the risk of breaking your shift fork when you shifting hard. I have run with this mod for almost 2 years, and no issue.
2.3L 6-bolt, BJ's ported 2G head, TRE tranny, GT3076R, 255lph, 850cc, AFPR, ROM emulator, Aquamist, ETS FMIC, LSD rr Quaife ft diff, WL swaybars, Bilstein, HKS 264/272 cams, ZT2 WBO2
Posts: 752 | From: San Jose, CA | Member Since: 07/16/02 | IP: (209.213.198.25) |
posted 06/17/05 08:18 PM
For the bump stopper on the shifter base, simply cut a small section of a hose and zip tie around the stock stopper to make it thicker. Like so..
Posts: 752 | From: San Jose, CA | Member Since: 07/16/02 | IP: (64.169.94.111) |
posted 06/17/05 08:20 PM
In addition, to install a leather shift boot, you can reuse the bottom portion of your old accordion-style rubber boot. Like so. What the shifter looks like:
posted 06/19/05 01:22 AM
I drilled it all the way through, and also tap it all the way through the lever.
Then I use a bolt, a washer, and a nylon lock-nut at the bottom.. I will try to take a picture of this.
The bolt does not clamp down on the shifter bushings. The lock-nut at the bottom of the lever kinda acts like a jam nut.
