Galant VR-4 Forums » Galant VR-4 » How To and Info Archive » making cam degree tools
Galant VR-4 org Post #: 1201203 posted 02/09/15 12:31 PM     Remind Me!  Send Private Message   Edit Post
These solid lifters and crank bolt extender are inspired by Jafromobile. This is just the way I did it.
I found all the pieces at a local ace hardware.
After removing the cap valve and spring I drilled out the sleeve in the upper portion of this lifter. I then fit a SS screw nut and threaded bushing inside the unit. The bushing and nut when tightened against each other allows the height to be locked in place.
If you can find m14x1.5 threaded rod and 3 nuts this would be very easy. I couldn't source that locally so I came up with this as a solution. I cut the head off a m14 bolt and slid the shoulder into a 5/8 coupler. If you leave some splinters on the top of the bolt you can thread it in pretty strait. When it butted up against the bolt from the other side I welded it in place. The summit degree wheel has a collar for a 5/8" bolt so it worked out well.
I didn't use a dial gauge to center my bolt befor welding. Measured at the tip of the 5/8 bolt there's a difference of .098" I don't think its going to make much of a difference for a rotational measurement I will be taking, but your welcome to take more care when assembling yours.
Hope this helps some of you out. Enjoy.
Posts: 1499 | From: ronkonkoma, ny | Member Since: 12/19/12 | IP: (24.45.85.14) | Report this post to a Moderator
EHmotorsports
Capt Fabbin Stabbin
1865/2000
Galant VR-4 org Post #: 1201204 posted 02/09/15 12:51 PM     Remind Me!  Send Private Message   Edit Post
I would recommend getting it almost perfect from the start. any variant can make the reading off 1 or more degrees.
Posts: 1278 | From: Beaverton | Member Since: 09/26/12 | IP: (98.246.179.90) | Report this post to a Moderator
715/1000
1284/2000
Galant VR-4 org Post #: 1201214 posted 02/09/15 02:28 PM     Remind Me!  Send Private Message   Edit Post
What do you use for the degree wheel Evan?
#1284/2K NB, Totaled
#715/1K KG, Rebuilding
02 Acura TL daily duty unit
12yr+ Vr4 owner.
Honda/Acura master tech.
Family Guy
EHmotorsports
Capt Fabbin Stabbin
1865/2000
Galant VR-4 org Post #: 1201227 posted 02/09/15 03:26 PM     Remind Me!  Send Private Message   Edit Post
Quoting prove_it:
He is not far off on what I would do. I have access to a lathe so it makes things much easier to true everything up. but if he had a way to use a thick washer to make it true to the crank and then weld it all together It could possibly make it perfect. Granted there would still be some deflection from welding depending on the technique.
But I would use the biggest diameter wheel I could find and fit given the engine. Small wheels make things more touchy and require a greater deal of attention when setting up.
715/1000
1284/2000
Galant VR-4 org Post #: 1201228 posted 02/09/15 04:15 PM     Remind Me!  Send Private Message   Edit Post
What is the total length needed for the solid lifter?
12yr+ Vr4 owner.
Family Guy
715/1000
1284/2000
Galant VR-4 org Post #: 1201469 posted 02/12/15 12:37 PM     Remind Me!  Send Private Message   Edit Post
Found a nice video relating to this. Orginally posted over on tuners, but has a different mount idea that seems very nice.
Cam degree video
12yr+ Vr4 owner.
Family Guy
Galant VR-4 org Post #: 1201680 posted 02/14/15 08:46 PM     Remind Me!  Send Private Message   Edit Post
Good video, However hes copping Automobiles tool to the T. As stated I offered my solution as an alternative. Good luck tapping that tool steel by the way.
I doo like the press fit bolts though. That was a good idea too.
7 1G DSM's now a GGSX build.
Posts: 1499 | From: ronkonkoma, ny | Member Since: 12/19/12 | IP: (74.71.90.241) | Report this post to a Moderator
0 registered and 4 anonymous users are browsing this forum.
Generated in 0.031 seconds in which 0.012 seconds were spent on a total of 14 queries. Turbo powered.
