Galant VR-4 Forums » Galant VR-4 » How To and Info Archive » JDM Mirrors
JDM Mirrors
AMG to EVO
Galant VR-4 org Post #: 110167 posted 05/06/03 10:54 PM     Remind Me!  Send Private Message   Edit Post
For anyone that wants to wire up JDM power folding mirrors, here's you do it. First you need four relays, a dual momentary switch and at least 7 rolls of different color wires. You will be pairing up the relays and wiring them like this:
OPEN
30 to brown wire on mirror
85 to orange wire on mirror
86 momentary switch
87 12volt positive constant
87a ground
CLOSE
30 to red wire on mirror
85 to green wire on mirror
86 momentary switch
87a ground
Once you have wired both pairs of relays you can connect the two wires from the open relays that go to the switch and the two from the close relays that go to the switch. Most momentary switches ave three terminals. The open pair of wires go to one side and the close pair of wires goes to the other. The center terminal on the switch gets 12volts positive constant. Doing the wiring like this will make the mirrors one touch open and close.
Jose......
| | | IP: (64.12.96.102) | Report this post to a Moderator
gtluke
Fegbasket
Galant VR-4 org Post #: 110168 posted 09/28/03 10:09 AM     Remind Me!  Send Private Message   Edit Post
old post but it came in handy for me
thanks!
Posts: 4210 | From: dirty jersey | Member Since: 09/16/01 | IP: (138.89.87.126) | Report this post to a Moderator
AMG to EVO
Galant VR-4 org Post #: 110169 posted 09/28/03 09:32 PM     Remind Me!  Send Private Message   Edit Post
Hey GTLUKE did you change the glass from the JDM mirrors?
Jose........
SpyderVR4
Member +
130/2000
Galant VR-4 org Post #: 165901 posted 12/24/04 01:46 PM     Remind Me!  Send Private Message   Edit Post
Jose........
probably should it will be angled differently.
I did similar conversion from a Nissan Silvia onto a USDM 240SX
91GVR4 Belize Green #130/2000 RIP
Posts: 372 | From: Lancaster, PA | Member Since: 06/05/04 | IP: (141.158.186.98) | Report this post to a Moderator
misterfixit
Victory Runner
Galant VR-4 org Post #: 174790 posted 01/20/05 06:15 AM     Remind Me!  Send Private Message   Edit Post
For info, all jdm mirrors are made the same as lh, rh ones.
Its the little base that bolts the main lump to the door that changes the angle of the thing, just undo the 3 phillips bolts and throw away the jdm bracket, then bolt up ur us lhd braket, then bolt it back on the door.
Hey presto the mirror sits at the right angle!
Rich
92 UK 1800 GALANT DD
88 JDM E39A GALANT VR-4, running. But only just.
93 CB4A --- rewound
91 PDM GTI Resurection project. Aborted
Stuff Index
Posts: 1555 | From: Midlands, UK | Member Since: 08/04/04 | IP: (194.129.249.241) | Report this post to a Moderator
Sigmac
Galant VR-4 org Post #: 667503 posted 07/10/08 03:46 PM     Remind Me!  Send Private Message   Edit Post
thanks to this post it helpt me a lot.
I have made this diagram, if some one are better to look at a diagram then some text. ( I am! )
I have mix the JDM and the europerin mirror to one whit power folding and power heading for when it is cold
Regards
Sigmac
| | | IP: (87.49.167.99) | Report this post to a Moderator
Garfield Wright
Galant VR-4 org Post #: 667907 posted 07/11/08 11:53 AM     Remind Me!  Send Private Message   Edit Post
Quoting misterfixit:
Rich
For the countries that drive on the right hand side (like the US) you will need to switch out the jdm mirror glass for your stock ones. This is due to the different aspect ratio from the right hand side of the car vs. the left.
| | | IP: (75.74.8.7) | Report this post to a Moderator
Generated in 0.028 seconds in which 0.012 seconds were spent on a total of 14 queries. Turbo powered.
