Galant VR-4 Forums » Galant VR-4 » How To and Info Archive » AFPR testing
AFPR testing
OneTitle to rule them all.
77/2000
Galant VR-4 org Post #: 109023 posted 03/27/04 11:23 PM     Remind Me!  Send Private Message   Edit Post
I'd like to run this by everyone to make sure I'm doing this right.
I just finished installing my Full Throttle AFPR... I ran the fuel pump with the logger and adjusted the reg until I could get it to hold at 43psi with the pump running. When I stop the pump pressure bleeds off every second like: 26,13,8,6,5,4... Does that seem right or am I leaking somewhere? (AFPR is clean, no leaks)
Will I be okay with 43psi base, having 450cc injectors, stock intake (screw not backed out), rewired stock pump (for tonight at least). My trims used to be 105,110,110 or thereabouts and I routinely could hit 100%+ duty cycle.
Thanks in advance!
Posts: 13501 | From: Chicago, IL | Member Since: 07/29/02 | IP: (24.14.18.251) | Report this post to a Moderator
Pivvay
Galant VR-4 org Post #: 109024 posted 03/27/04 11:56 PM     Remind Me!  Send Private Message   Edit Post
leak at the stock o-ring (tank fuel pump) is my guess. Mine drops after you shut it off but very slowly over an hour or so
| | | IP: (128.138.45.69) | Report this post to a Moderator
KenGVR4
Galant VR-4 org Post #: 109025 posted 03/28/04 01:37 AM     Remind Me!  Send Private Message   Edit Post
Most aftermarket fuel pressure regulators will bleed off pressure fairly quickly. It's not a big deal, you'll probably notice it takes a bit more cranking to get the motor started though.
Posts: 278 | From: Seattle, WA | Member Since: 05/13/01 | IP: (67.170.54.139) | Report this post to a Moderator
Senior Ricer
1552/2000
Galant VR-4 org Post #: 109026 posted 03/28/04 08:56 AM     Remind Me!  Send Private Message   Edit Post
quote:
Same here, I am using a Kirban Billet AFPR.
John
[ 03-28-2004, 10:44 AM: Message edited by: atc250r ]
Posts: 13235 | From: Orange County, NY | Member Since: 09/11/03 | IP: (68.193.209.233) | Report this post to a Moderator
turboflanagan
I would give myself something respectable.
478/1000
Galant VR-4 org Post #: 109027 posted 03/28/04 11:20 PM     Remind Me!  Send Private Message   Edit Post
You should be fine, just running rich for a while.
Posts: 2551 | From: Peachtree Corners, Georgia, US... | Member Since: 03/05/01 | IP: (64.63.213.13) | Report this post to a Moderator
a_santos
Brasileiro Turbinado
Galant VR-4 org Post #: 109028 posted 03/28/04 12:42 PM     Remind Me!  Send Private Message   Edit Post
I had my fuel pressure at 43 with the car running. My car was running rich, so I turned it down to 37-38. My car takes a bit more cranking to start, since I installed the Aeromotive FPR. No big deal though.
Posts: 2057 | From: San Diego, CA, USA | Member Since: 10/22/02 | IP: (68.41.75.130) | Report this post to a Moderator
MikeL
Galant VR-4 org Post #: 109029 posted 03/28/04 01:53 PM     Remind Me!  Send Private Message   Edit Post
You need to set the base with the vacuum hose disconnected, if the car is running, the vaccum will lower the pressure.
| | | IP: (24.46.19.147) | Report this post to a Moderator
77/2000
Galant VR-4 org Post #: 109030 posted 03/28/04 04:39 PM     Remind Me!  Send Private Message   Edit Post
It could very well be leaking at the pump, but the good news is I'm replacing it, perhaps tonight. It's my second attempt at this (first pump was DOA) so it should go really fast. I imagine that removing the stock pump and then putting it back in didn't help much. [Smile]
Yes, I know the vac line needs to be disconnected (if the engine is running), see I ran the pump with the car off. No need to remove the line. [Big Grin]
quote:
Originally posted by Hertz:
I ran the fuel pump with the logger...
It might be the AFPR releasing fast, but it didn't always seem consistent, almost like the more pressure, the faster it would release. Though it did pressurize failry quickly... before the AFPR I never really had any priming issues. I haven't started the car yet.
Thanks for the help guys!
77/2000
Galant VR-4 org Post #: 109031 posted 03/28/04 10:50 PM     Remind Me!  Send Private Message   Edit Post
Finally started the car after nearly 2 weeks. She fired right up... was running a little lean, but nothing crazy. This is all after a battery relocate, coolant temp sensor rewire and AFPR install. [Big Grin] There did not seem to be any pressure problems and the pressure subsided much slower than when I was testing it initially.
...still much more on the to-do list.
LunarShadow
Galant VR-4 org Post #: 109032 posted 03/30/04 06:19 PM     Remind Me!  Send Private Message   Edit Post
You guys know I have the Kirban for which the Full Throttle is familiar. One of the first things I noticed is that it bleeds off fuel pressure. The stock FPR would hold the pressure for many hours. No worries, what it does when running is what is important.
| | | IP: (172.157.114.62) | Report this post to a Moderator
G-GSX Turbo
Galant VR-4 org Post #: 109033 posted 03/30/04 10:01 PM     Remind Me!  Send Private Message   Edit Post
The fix for the slow starting is a timed relay running off switched ignition like every other normal vehicle on the planet.
| | | IP: (66.188.250.100) | Report this post to a Moderator
77/2000
Galant VR-4 org Post #: 109034 posted 04/08/04 07:34 PM     Remind Me!  Send Private Message   Edit Post
I was looking for Paul Mc's post on his install, but I guess my own is a good place to put these...
Funky adapter plate installed
after having lost one screw and purchasing a new set. Minor grinding was required for a good fit. The sparking dust is some aluminum particles. The rag is a must if you don't want to lose any more screws. (Duh) Yes, the spark plug boot is a little close.
AFPR installed, no gauge.
I only needed to buy one extra elbow to get a good angle on the gauge. Used PTFE tape... The supplied elbow was used to angle the supply nipple towards the hose. It honestly took me 15 minutes to figure out how this thing should be set up.
AFPR installed w/ Jeg's gauge
which was $20 plus $10 shipping, for which I now have two Jeg's decals and receive a catalog of parts I can't use every month.
Oh yeah, I also replaced my ground wires with some stuff I had laying around. (right-hand side, off back of manifold)
Edited by Hertz (11/10/08 02:26 AM)
Posts: 13501 | From: Chicago, IL | Member Since: 07/29/02 | IP: (67.167.201.59) | Report this post to a Moderator
Mitsuturbo
Galant VR-4 org Post #: 109035 posted 04/09/04 06:36 PM     Remind Me!  Send Private Message   Edit Post
Thanks in advance!
100% IDC, but what software were you logging with? I have found that DSM Logger has a glitch in the IDC % and will spike sometimes up to 30% more than actual IDC
MMCD does not have this problem
| | | IP: (67.161.247.241) | Report this post to a Moderator
Paul Mc369
Galant VR-4 org Post #: 109036 posted 04/09/04 07:10 PM     Remind Me!  Send Private Message   Edit Post
Selfish bastard. [Razz]
Great idea...wish I thought of it. [Applause] I hate that hole.
Others have done it with one as well. I just couldn't make my gauge clear the regulator without two. [Confused]
quote:
It honestly took me 15 minutes to figure out how this thing should be set up. [Ugh]
Stupid bastard. [Razz]
quote:
AFPR installed w/ Jeg's gauge which was $20 plus $10 shipping, for which I now have two Jeg's decals [Confused] and receive a catalog of parts I can't use every month.
No, no, no, Jegs has FREE shipping. That was a $10 handeling fee. Just read there weekly e-mail, it will tell you. [ROFLMAO]
I'm glad to see you got it up and running. Good work. I hope I was at least a little help. It was nice to give a little knowledge back for a change. [We're Not Worthy]
| | | IP: (24.196.238.31) | Report this post to a Moderator
0 registered and 4 anonymous users are browsing this forum.
Generated in 0.05 seconds in which 0.022 seconds were spent on a total of 14 queries. Turbo powered.
