Galant VR-4 Forums » Galant VR-4 » How To and Info Archive » Busted Throttle Butterfly Screws
Pivvay
Galant VR-4 org Post #: 109001 posted 04/07/04 09:28 PM     Remind Me!  Send Private Message   Edit Post
So I'm finally rebuilding my throttle body with the new orings from MachV (thanks Kibo) and my new FIAV and ISC blockoff plate. Of course 2 screws on the butterfly broke in half. Who knew PB blaster soak(s) and the right size screwdriver wouldn't be enough for me? [Roll Eyes] So the electric screwdriver and all my weight got them out in 2 pieces. The threads are still fine.
Now I need to put everything back together sometime soon so where can I pickup 2 more screws? Also what grease did everyone use on the seals? Does anything work or does it need to be silicon based per the VFAQ?
Finally not stressed about breaking some screws. Go Civic power! [Big Grin]
| | | IP: (128.138.45.69) | Report this post to a Moderator
Senior Ricer
1552/2000
Galant VR-4 org Post #: 109002 posted 04/07/04 09:35 PM     Remind Me!  Send Private Message   Edit Post
If it has to be silicon based get some Sil-Glyde from the local NAPA store. It is used to lube brake caliper pins/sliders so if you plan on doing your own brakes you'll definitely have use for it. I gotta get around to doing my t-body one of these days.
John
Posts: 13235 | From: Orange County, NY | Member Since: 09/11/03 | IP: (68.193.209.233) | Report this post to a Moderator
Pivvay
Galant VR-4 org Post #: 109003 posted 04/07/04 09:42 PM     Remind Me!  Send Private Message   Edit Post
So far the TB is super easy except for the screws i broke. Sometimes they come out easy, sometimes not. I just need to know how to replace them now and if the grease has to be anything special.
turbogalant
Galant VR-4 org Post #: 109004 posted 04/07/04 10:20 PM     Remind Me!  Send Private Message   Edit Post
Bone yard, ace, true value.
| | | IP: (65.177.241.207) | Report this post to a Moderator
Pivvay
Galant VR-4 org Post #: 109005 posted 04/07/04 10:23 PM     Remind Me!  Send Private Message   Edit Post
quote:
So they're a standard size? If so I'll fix them tomorrow at work or run to the hardware store. my guess is they're m5x.8?
Hibrn8
Galant VR-4 org Post #: 109006 posted 04/07/04 10:37 PM     Remind Me!  Send Private Message   Edit Post
Ace seems to have all the metrics, even the most rare ones.
| | | IP: (67.248.54.134) | Report this post to a Moderator
OneTitle to rule them all.
77/2000
Galant VR-4 org Post #: 109007 posted 04/08/04 08:32 AM     Remind Me!  Send Private Message   Edit Post
Get titanium screws. [Smile]
Posts: 13500 | From: Chicago, IL | Member Since: 07/29/02 | IP: (68.254.141.70) | Report this post to a Moderator
Oztek
Galant VR-4 org Post #: 109008 posted 04/08/04 08:46 AM     Remind Me!  Send Private Message   Edit Post
The problem with those screws is that they seem to be made from an extremely soft metal. If you don't have a very good grip with the screw-driver, they will strip out very easily.
Luckily I had a spare throttle body around that I could canibilize for parts.
| | | IP: (63.68.196.38) | Report this post to a Moderator
Pivvay
Galant VR-4 org Post #: 109009 posted 04/08/04 08:50 AM     Remind Me!  Send Private Message   Edit Post
mine started to strip so I tried another method, namely the electric drill on a high clutch setting with a screwdriver bit. With all my weight down on the screw and drill it didn't strip but it did snap them right in half. Then the bottoms easily came out the other way. Depending out how hard they peened the bottom of the screw I'm not sure some would ever come out in one piece!
Senior Ricer
1552/2000
Galant VR-4 org Post #: 109010 posted 04/08/04 09:36 AM     Remind Me!  Send Private Message   Edit Post
What are you gonna do to keep the new ones in? Peen them again or maybe a little tack weld?
John
a_santos
Brasileiro Turbinado
Galant VR-4 org Post #: 109011 posted 04/08/04 10:53 AM     Remind Me!  Send Private Message   Edit Post
A budget mod to do while it is out is grind the shaft down so that is is more aerodynamic. You can also grind the ends of the screws if they stick out. Tha way when the butterfly is fully open, it has a lower profile.
Posts: 2057 | From: San Diego, CA, USA | Member Since: 10/22/02 | IP: (198.111.39.21) | Report this post to a Moderator
RayH
561/1000
Galant VR-4 org Post #: 109012 posted 04/08/04 11:09 PM     Remind Me!  Send Private Message   Edit Post
quote:
And if you have alot of time on your hands, grind the leading and trailings edges of the plate, taking care not to change the overall diameter.
Posts: 2700 | From: NJ | Member Since: 04/09/01 | IP: (167.211.190.2) | Report this post to a Moderator
Pivvay
Galant VR-4 org Post #: 109013 posted 04/08/04 11:41 PM     Remind Me!  Send Private Message   Edit Post
I was just going to red locktight the screws. Maybe hit the backs with a punch too.
| | | IP: (162.18.125.155) | Report this post to a Moderator
turboflanagan
I would give myself something respectable.
478/1000
Galant VR-4 org Post #: 109014 posted 04/08/04 07:16 PM     Remind Me!  Send Private Message   Edit Post
You are going to cryo the assy after you balance it right? [Wink]
Posts: 2551 | From: Peachtree Corners, Georgia, US... | Member Since: 03/05/01 | IP: (64.63.212.219) | Report this post to a Moderator
Pivvay
Galant VR-4 org Post #: 109015 posted 04/08/04 07:34 PM     Remind Me!  Send Private Message   Edit Post
Yep...my freezer is standing by [ROFLMAO]
Senior Ricer
1552/2000
Galant VR-4 org Post #: 109016 posted 04/08/04 09:20 PM     Remind Me!  Send Private Message   Edit Post
quote:
VERY IMPORTANT!!!! Don't forget to magnaflux it too. [Wink]
John
sleepyvr4
I Hate Kitty Cats
Galant VR-4 org Post #: 109017 posted 04/08/04 09:22 PM     Remind Me!  Send Private Message   Edit Post
I got lucky and only ruined one of my screws. I got a replacement in an old r/c parts bin.
Posts: 2359 | From: Key West | Member Since: 12/25/03 | IP: (24.154.50.222) | Report this post to a Moderator
Pivvay
Galant VR-4 org Post #: 109018 posted 04/08/04 09:30 PM     Remind Me!  Send Private Message   Edit Post
They seem to be m4x.70. anyone confirm?
PacManVR4
Galant VR-4 org Post #: 109019 posted 04/08/04 10:01 PM     Remind Me!  Send Private Message   Edit Post
I would rather not grind down the TB shaft...
| | | IP: (64.63.217.18) | Report this post to a Moderator
TWEAKD4
Member ++
59/1000
Galant VR-4 org Post #: 109020 posted 04/09/04 06:56 AM     Remind Me!  Send Private Message   Edit Post
Vfaq is your friend. From http://www.ca.dsm.org/faq/tb-shaftseals.html. This faq says to use 4mm x .75. My local DO-It-Best didn't have that size so I used 4mm x .70 and they worked fine. Just used red locktight and all is good.
Posts: 605 | From: Fort Wayne, IN | Member Since: 03/24/02 | IP: (63.233.205.27) | Report this post to a Moderator
Pivvay
Galant VR-4 org Post #: 109021 posted 04/09/04 06:59 AM     Remind Me!  Send Private Message   Edit Post
Thanks for the link. I had been looking at the other VFAQ on it and it didn't mention size.
Pivvay
Galant VR-4 org Post #: 109022 posted 04/10/04 08:30 PM     Remind Me!  Send Private Message   Edit Post
m4 screws were right. I used 8mm length and loctited them. Now it's all reassembled, TPS readjusted, new oring, cleaned. Smooth as it's ever been and snaps right back closed.
Now if it would stop SNOWING I could put the GVR4 back together with it's new goodies.
0 registered and 9 anonymous users are browsing this forum.
Generated in 0.185 seconds in which 0.072 seconds were spent on a total of 14 queries. Turbo powered.
