Galant VR-4 Forums » Galant VR-4 » How To and Info Archive » ISC?? We don't need no stinkin ISC!
JonGVR4
Galant VR-4 org Post #: 10059 posted 05/24/02 08:35 PM     Remind Me!  Send Private Message   Edit Post
[ 03-12-2004, 07:09 AM: Message edited by: Jon ]
| | | IP: (64.129.136.41) | Report this post to a Moderator
NoMoreVR4
Galant VR-4 org Post #: 10060 posted 05/25/02 10:53 AM     Remind Me!  Send Private Message   Edit Post
I was thinking of that. Does it actually work? Also I was about to post about the Vacuum hoses on the TB that goes to thermostat housing we dont need those either right. I took out my heater & A/C & no longer have the core or nothing So i'm going to block off all of the coolant lines & bypass the TB see any problems. I dont think there are.
[This message has been edited by 1312VR4 (edited 05-25-2002).]
| | | IP: (63.52.132.43) | Report this post to a Moderator
DarkDevilMMM
if I want a potential headache, I rather just get another GVR4
335/1000
Galant VR-4 org Post #: 10061 posted 05/25/02 12:38 PM     Remind Me!  Send Private Message   Edit Post
no CE light on? or the car idles? hmm.... nice...
Posts: 4065 | From: Vacaville, CA | Member Since: 06/08/01 | IP: (208.59.199.233) | Report this post to a Moderator
JonGVR4
Galant VR-4 org Post #: 10062 posted 05/28/02 07:32 AM     Remind Me!  Send Private Message   Edit Post
no check engine light and the car idles pretty well.
| | | IP: (205.145.64.64) | Report this post to a Moderator
TeamDucktape
Galant VR-4 org Post #: 10063 posted 05/28/02 07:53 PM     Remind Me!  Send Private Message   Edit Post
When are the "plates" coming to market and how much for them?
| | | IP: (216.183.225.195) | Report this post to a Moderator
NoMoreVR4
Galant VR-4 org Post #: 10064 posted 05/28/02 09:39 PM     Remind Me!  Send Private Message   Edit Post
I just made mine for $2.15
| | | IP: (63.52.202.247) | Report this post to a Moderator
JonGVR4
Galant VR-4 org Post #: 10065 posted 05/29/02 07:53 AM     Remind Me!  Send Private Message   Edit Post
quote:
Funny. I bought the piece of aluminum from Home Depot and cut it to fit. The hardest part was getting the old bolts out.
NoMoreVR4
Galant VR-4 org Post #: 10066 posted 05/29/02 10:20 AM     Remind Me!  Send Private Message   Edit Post
Yeah. I had some aluminum laying around.
Tools needed for removal: Phillips screwdriver, hammer, vice grips,WD-40,
12 pack , band -aids, & patience. Them things are a b**ch.
If all else fails break out with the Air Compressor( I almost had to)
| | | IP: (63.52.151.81) | Report this post to a Moderator
teet
Senior Teeter
Galant VR-4 org Post #: 10067 posted 05/29/02 02:12 PM     Remind Me!  Send Private Message   Edit Post
impact screwdriver. they come right out with the correct tools
john
[ 03-12-2004, 07:10 AM: Message edited by: Jon ]
Posts: 1245 | From: northwest | Member Since: 03/08/01 | IP: (134.134.248.27) | Report this post to a Moderator
NoMoreVR4
Galant VR-4 org Post #: 10068 posted 05/29/02 02:32 PM     Remind Me!  Send Private Message   Edit Post
Tried that & it stripped the slots. Vice grips worked good though. I do have all the right tools...lol
| | | IP: (63.52.132.33) | Report this post to a Moderator
Happy Birthday ken inn
BJ Titsengolf lifer
Galant VR-4 org Post #: 10069 posted 05/29/02 03:11 PM     Remind Me!  Send Private Message   Edit Post
what about idle bump up, like when the a/c is on?
Posts: 7529 | From: krum texas | Member Since: 02/23/01 | IP: (63.146.72.149) | Report this post to a Moderator
199of2k
Galant VR-4 org Post #: 10070 posted 05/29/02 08:30 PM     Remind Me!  Send Private Message   Edit Post
Im very interested in this mod, what are the pros/cons and is there a vfaq?
thanks
B
| | | IP: (68.9.133.82) | Report this post to a Moderator
JonGVR4
Galant VR-4 org Post #: 10071 posted 05/29/02 08:44 PM     Remind Me!  Send Private Message   Edit Post
I don't have AC so that isn't a problem. You really need the ISC if you have AC. It idles too rich when the car is cold so you have to keep your foot on the gas a tad bit to let more air in. Not a big deal. Within 1 minute, it idles perfectly.
With a VPC, it actually idles better like this. Another pro is I don't have those coolant hoses running to the throttle body heating things up.
gvr4mike
Galant VR-4 org Post #: 10072 posted 06/03/02 08:59 AM     Remind Me!  Send Private Message   Edit Post
Does this eliminate the FIAV aswell?
Or has anyone just filled the passages for the FIAV with high-temp epoxy? If so, will the car maintain an idle without the FIAV?
trying to avoid replacing the TB due to a bad FIAV...
Mike Jones
615/2000
| | | IP: (158.140.2.102) | Report this post to a Moderator
JonGVR4
Galant VR-4 org Post #: 10073 posted 06/03/02 09:41 AM     Remind Me!  Send Private Message   Edit Post
That entire section where that valve was is gone on my t-body. Idle is fine. You can always block off the FIAV and still use the ISC. Just remove that piece like I did and you'll see what I mean.
Tondar
1667/2000
Galant VR-4 org Post #: 10074 posted 06/04/02 09:37 AM     Remind Me!  Send Private Message   Edit Post
How do you check for a bad FIAV??
Posts: 204 | From: detroit, MI, USA | Member Since: 12/02/01 | IP: (136.2.1.101) | Report this post to a Moderator
NoMoreVR4
Galant VR-4 org Post #: 10075 posted 06/12/02 03:50 PM     Remind Me!  Send Private Message   Edit Post
Just a little update. I did this mod & it works fine.
| | | IP: (63.52.132.17) | Report this post to a Moderator
PRE-EVO
Galant VR-4 org Post #: 10076 posted 04/21/03 01:03 AM     Remind Me!  Send Private Message   Edit Post
Just wanted to ask if you were able to reuse the bolts/screws you took out or if you got some to replace them? If so what kind?
Rich
| | | IP: (199.182.25.228) | Report this post to a Moderator
4g63t
Galant VR-4 org Post #: 10077 posted 04/21/03 03:09 AM     Remind Me!  Send Private Message   Edit Post
When I did this I cut the stock screws shorter with a dremel, worked fine.
Posts: 2073 | From: Lancaster PA | Member Since: 01/31/02 | IP: (68.82.236.19) | Report this post to a Moderator
MMorgan
294/1000
Galant VR-4 org Post #: 10078 posted 09/15/03 05:58 PM     Remind Me!  Send Private Message   Edit Post
Has anyone else done this since april????? any change of opinions?
Posts: 1918 | From: Haymarket, VA | Member Since: 03/16/03 | IP: (64.12.96.102) | Report this post to a Moderator
Minjin
Galant VR-4 org Post #: 10079 posted 09/15/03 06:15 PM     Remind Me!  Send Private Message   Edit Post
I never saw this thread but I did it to my throttle body as well. Works fine. Not for pansies who can't handle a changing idle depending on engine conditions...
Mark
| | | IP: (24.54.214.109) | Report this post to a Moderator
Notorius
Galant VR-4 org Post #: 10080 posted 09/15/03 08:28 PM     Remind Me!  Send Private Message   Edit Post
i bought my car w/ the ISC disconnected. now that the weather is getting colder here in colorado its becoming more annoying to have done but its still not a problem if i let the car sit for a few minutes.
does anyone w/ their ISC disconnected experience a loss in RPMs if they rev the car up a tad, like say to 2000rpms, and keep the pedal still? when i do that, and the car is still cold, it will drop from 2000 to like 600 and feel like its about to stall, then pick back up and be fine after that. just wonderin if anyone else noticed it.
| | | IP: (138.86.12.14) | Report this post to a Moderator
EVT_Chris
Galant VR-4 org Post #: 10081 posted 09/15/03 10:52 PM     Remind Me!  Send Private Message   Edit Post
when my isc blew and ruined my ecu, i made a block off plate. i have recently seen problems with my coolent temp raising and bumping down timing. i don't think it was caused by removal of the fiav and bypassing the lines, but you never know. also, i'm worried that i might have a leak coming from the plate, but thats my error, and won't happen if done correctly. my car stalls sometimes when dropping from higher rpms and when i'm turning [power steering], but i don't know if the stalling problem is from the isc or a bad mas. anyways, its another great way to eliminate wires and shit from under the hood...
| | | IP: (12.107.200.124) | Report this post to a Moderator
sleepyvr4
I Hate Kitty Cats
Galant VR-4 org Post #: 328651 posted 04/16/06 12:09 PM     Remind Me!  Send Private Message   Edit Post
fabbing a plate is too much work, however, is reversible. Bare tb's are cheap, so I did this to a NT 91-94 tb.
the liquid steel was later smoothed out. New tb seals, idles like a champ.
Posts: 2359 | From: Key West | Member Since: 12/25/03 | IP: (24.154.184.10) | Report this post to a Moderator
0 registered and 4 anonymous users are browsing this forum.
Generated in 0.058 seconds in which 0.02 seconds were spent on a total of 14 queries. Turbo powered.
