Galant VR-4 Forums » Galant VR-4 » How To and Info Archive » How do you bleed the master/salve clutch cylinders???
MX4
Member +++
Galant VR-4 org Post #: 10048 posted 05/02/02 04:29 AM     Remind Me!  Send Private Message   Edit Post
Hey people,
Another easy one for you guys. I need to bleed my clutch cylinders as we have just rebuilt them with new seals. I know there is a special bleeder thing you can buy but I dont have the cash right now. I also know there is a way two people can bleed the system without it. My question is how do you do it and what nipple do you use to do the bleeding. Also where are these located? Please please help me....im desperate....
Thanks guys
Ryan
[This message has been edited by MX4 (edited 05-02-2002).]
Posts: 767 | From: New Zealand | Member Since: 04/09/01 | IP: (165.84.1.12) | Report this post to a Moderator
ken inn
BJ Titsengolf lifer
Galant VR-4 org Post #: 10049 posted 05/02/02 09:26 AM     Remind Me!  Send Private Message   Edit Post
the clutch slave has the bleed screw on it. it usually has a little rubber dust cap, but yours may be long gone. you crack it open only about a half turn, then depress the clutch pedal, and then pull it back up. the trick is to make the bleed line coming off of the bleed screw go up, then down into your receptacle. i take an old empty can of brake fluid, make a hole in the cap, and run my line(a clear line is best, so you can see the fluid coming out) into the cap. once you crack the bleed screw, you can loosen it with your fingers. it is an easy one person job, just make sure your resevoir doesnt empty. if you have difficulty, then you need another person to help. what you do, is tell them to step on the pedal, and hold it when it goes down, dont release it until you say. then, you loosen the bleed screw, when the pedal is all the way down, tighten up the bleed screw, and pull the pedal back up top. repeat a couple of times, and the system should be bled. i bleed my brakes and clutch all the time, and i never use the speed bleeders, just the line, and make sure it goes up, so when you release the pedal, no air goes backwards, only fluid.
Posts: 7529 | From: krum texas | Member Since: 02/23/01 | IP: (63.146.72.149) | Report this post to a Moderator
beavis
Dynomember
Galant VR-4 org Post #: 10050 posted 05/08/02 03:35 PM     Remind Me!  Send Private Message   Edit Post
if you don't have a friend to help you, it is possible and easy to gravity bleed the clutch line. simply open up the bleeder screw and keep the resevoir full untill only fluid comes out. this is how i do mine and it works fine.
Posts: 1172 | From: so cal | Member Since: 01/29/02 | IP: (138.23.89.47) | Report this post to a Moderator
number3
Galant VR-4 org Post #: 10051 posted 05/08/02 09:16 PM     Remind Me!  Send Private Message   Edit Post
I installed a speed bleeder in mine and it makes it a snap with one person or two. A clear hose lets you see the air bubbles or lack of.
Removing the slave from the tranny (but keeping it hookup to the line of course) to allow for the drain to be the highest point helps removing trapped air. For some reason the factory put the drain on the bottom making it possible for air to get trapped.
Harry
Posts: 7623 | From: KoP, PA | Member Since: 06/26/01 | IP: (68.80.14.121) | Report this post to a Moderator
Remo
Galant VR-4 org Post #: 10052 posted 03/28/04 12:43 AM     Remind Me!  Send Private Message   Edit Post
can anyone tell me the speedbleeder part number that fits in place of the clutch bleeder nipple?
| | | IP: (144.132.25.5) | Report this post to a Moderator
gvr4ever
Forever Member
347/1000
Galant VR-4 org Post #: 10053 posted 03/28/04 04:37 AM     Remind Me!  Send Private Message   Edit Post
quote:
Generic speed bleeders come with multiple nipples in different sizes. One of them should fit. You want nipples in differnt sizes too. I like them in different sizes anyway. If they were all the same size, life would be boring.
Nipple!
Posts: 5950 | From: central Indiana | Member Since: 08/06/02 | IP: (209.107.92.217) | Report this post to a Moderator
OneTitle to rule them all.
77/2000
Galant VR-4 org Post #: 10054 posted 03/28/04 04:48 PM     Remind Me!  Send Private Message   Edit Post
Wow, good thing this topic was resurrected, I was just about to search/ask on this very topic.
I lost my clutch a few weeks ago (slowly engaged closer and closer to the floor until I could no longer drive it safely)... my clutch resevoir was almost empty.
Since it obviously lost fluid does that mean I *should* replace the seals in the cylinders? I was not able to determine exactly where the leak is, though there does appear to be a small amount of fluid near the clutch pedal and I recall a faint petroleum smell -- but if it was leaking in the footwell I would have expected more than just trace amounts of fluid.
Is the cylinder rebuild materials something I can get a generic autoparts store, or do I go Conicelli?
Thanks.
Posts: 13500 | From: Chicago, IL | Member Since: 07/29/02 | IP: (24.14.18.251) | Report this post to a Moderator
4g63t
Galant VR-4 org Post #: 10055 posted 03/28/04 05:34 PM     Remind Me!  Send Private Message   Edit Post
Thanks.
Yeah, me too. Specifically, I remember everyone agreeing that the rebuild kits everywhere have the wrong size piston, did anyone ever find a source for the right size? I have 2 slave cyls that are just sitting here waiting to be rebuilt.
Posts: 2073 | From: Lancaster PA | Member Since: 01/31/02 | IP: (67.171.99.197) | Report this post to a Moderator
TOF
Galant VR-4 org Post #: 10056 posted 03/29/04 09:19 AM     Remind Me!  Send Private Message   Edit Post
I bought both rebuild kits (master and slave) at Advance Auto Parts.
Tru Torque CMK351513 CLUTCH MASTER CYLINDER KT
Tru Torque CSK352155 CLUTCH SLAVE CYLINDER KIT
They are the correct ones for all USDM GVR4s.
| | | IP: (139.177.224.71) | Report this post to a Moderator
Bimmubishi
giant log
Galant VR-4 org Post #: 10057 posted 03/29/04 09:21 AM     Remind Me!  Send Private Message   Edit Post
This thread covers the bleeding question.
Search
Ryan, there's a slave rebuild kit from www.taylorautomotive.com that's cheap. It's two or more o-rings that's pretty much it. I used it a while ago and it worked great. I'm not sure/don't remember about the master cylinder though.
Posts: 5701 | From: Boston, Massachusetts | Member Since: 07/15/03 | IP: (128.197.64.109) | Report this post to a Moderator
77/2000
Galant VR-4 org Post #: 10058 posted 03/29/04 11:33 PM     Remind Me!  Send Private Message   Edit Post
Thank you!
Posts: 13500 | From: Chicago, IL | Member Since: 07/29/02 | IP: (24.12.59.172) | Report this post to a Moderator
WFOVR4
Galant VR-4 org Post #: 643800 posted 05/07/08 11:13 PM     Remind Me!  Send Private Message   Edit Post
Don't forget another really nice trick when bleeding a clutch slave cylinder. When you are done with the process of pumping the pedal and cracking the bleeder screw, try this. Get a hold of the slave rod, crack the bleeder and manually push the rod as far as it will go into the cylinder and then close the bleeder. It gets the air out that the pedal can't.
| | | IP: (206.53.29.183) | Report this post to a Moderator
Generated in 0.046 seconds in which 0.022 seconds were spent on a total of 14 queries. Turbo powered.
