Galant VR-4 Forums » Marketplace » Parts For Sale » FS: Part out 91 GVR4, #597, aftermarket and stock
cody
Member ++
991/2000
Galant VR-4 org Post #: 1245599 posted 03/17/19 10:41 PM     Remind Me!  Send Private Message   Edit Post
Due to some major rust issues and a loss of interest I am parting out #597. The first stage of items for sale will be the engine and any aftermarket parts. The shell is currently complete and all items from it are for sale. If you don't see it listed please feel free to ask. Pricing doesn't include shipping, I would prefer pick up for larger items but I can certainly arrange freight. I do accept paypal.
XTD 6 puck clutch and chromoly flywheel. Approx 2,500 miles $125
FMIC vertical flow core, brand unknown. Core dimensions 24x6x3, with tanks 11" tall. 2.5" in/out connections. Will include piping w/ stock blow off valve. Piping was set up for turbo listed below. $250
Honda aluminum radiator. 3 row core, dimensions are 14x16.5x2.75. Includes Spal slim fan w/ shroud. Will include stainless coolant pipes. $200
B&M oil cooler w/ hoses. Cooler dimensions 11x8.25x1.5. $75
Front strut bar, brand unknown. $10
Turbo/exhaust manifold/wastegate. Masterpower T70 turbo, normal shaft play, custom top mount forward facing exhaust manifold. Tial 38mm wastegate. Will include oil feed/drain line and wastegate dump tube. $1000
Mallory AFPR w/ gauge and feed line. Model 4305M. $100
3 Urethane motor mounts. Missing front. Engine timing side was modified to eliminate mount by PS bracket. $30
FIC 750 injectors $125 **SOLD**
4G63T engine. Stock internals. ARP head, main and rod hardware. MLS head gasket. Machined balance shaft. 90 oil filter housing w/ 1/2 JIC fittings. Powder coated valve cover. Approx 2500 miles on rebuild. $1000
3" GM MAF and translator w/reducer couplers to 2.5". Translator is missing cover. Has 2g MAF plug. $50
Voodoo MBC. $10
Non Cruise throttle cable. $10 **SOLD**
Non EPROM ECU $50
Apexi SAFC 2 w/ extension harness and stand. **SOLD**
Adjustable fan control relay w/ temp probe for radiator. $15
AEM wideband w/ sensor and gauge stand. $100
Blitz 60mm electric gauges w/ sensors. Oil pressure in kpa/bar, Boost in kpa/bar, temp in celcius. $100/ea or all 3 for $250.
3G Eclipse wheels with Fuzion Touring 215/50R70 tires. Rims are powder coated a dark bronze. Tires and wheels in good shape, lots of life left, don't have a gauge to measure depth. No center caps. $350
Evo 8 F&R seats. Front seats have brackets to fit into a Galant. Rear seat foam has been cut to fit in Galant. No tears. $400
Edited by cody (03/20/19 08:01 PM)
Posts: 630 | From: Neenah, WI | Member Since: 01/24/05 | IP: (2605:a000:a906:1) | Report this post to a Moderator
Lesac
Galant VR-4 org Post #: 1245602 posted 03/18/19 08:57 AM     Remind Me!  Send Private Message   Edit Post
what coilovers are on the car? Is the hood in good shape?
736/2000 sold
848/1000 current daily
Posts: 37 | From: OMAHA | Member Since: 12/09/18 | IP: (2620:0:10ee:10:e) | Report this post to a Moderator
cody
Member ++
991/2000
Galant VR-4 org Post #: 1245604 posted 03/18/19 09:27 AM     Remind Me!  Send Private Message   Edit Post
K-Sport coil overs. I have a friend interested in these, which is why I didn't post them. Should he change his mind I'll post them up. Hood is in decent shape. Some scratches, but isn't rusted under the front lip. I'll get some pictures this afternoon.
Posts: 630 | From: Neenah, WI | Member Since: 01/24/05 | IP: (70.92.85.83) | Report this post to a Moderator
Lesac
Galant VR-4 org Post #: 1245605 posted 03/18/19 09:40 AM     Remind Me!  Send Private Message   Edit Post
sounds good, I may need more parts as well. Hows the rear window trim?
736/2000 sold
Posts: 37 | From: OMAHA | Member Since: 12/09/18 | IP: (2620:0:10ee:10:9) | Report this post to a Moderator
idreamidrive
Member +
394/1000
Galant VR-4 org Post #: 1245606 posted 03/18/19 09:45 AM     Remind Me!  Send Private Message   Edit Post
Front and rear window trims, I really just need the corner pieces.
Posts: 429 | From: Murray, KY | Member Since: 10/10/12 | IP: (2605:a000:1610:4) | Report this post to a Moderator
Rrohde84
Galant VR-4 org Post #: 1245613 posted 03/18/19 12:53 PM     Remind Me!  Send Private Message   Edit Post
do you have a front steering rack
Posts: 27 | From: Mundelein il | Member Since: 08/13/16 | IP: (204.58.206.13) | Report this post to a Moderator
cody
Member ++
991/2000
Galant VR-4 org Post #: 1245614 posted 03/18/19 12:56 PM     Remind Me!  Send Private Message   Edit Post
Currently has a manual steering rack in it.
cody
Member ++
991/2000
Galant VR-4 org Post #: 1245615 posted 03/18/19 02:06 PM     Remind Me!  Send Private Message   Edit Post
Checked out the hood, it does have the typical rust under the front lip.
cody
Member ++
991/2000
Galant VR-4 org Post #: 1245616 posted 03/18/19 02:07 PM     Remind Me!  Send Private Message   Edit Post
Lesac
Galant VR-4 org Post #: 1245618 posted 03/18/19 03:17 PM     Remind Me!  Send Private Message   Edit Post
Thanks for checking, Iíll pass on the hood but still interested in these window trim parts Iím missing.
736/2000 sold
Posts: 37 | From: OMAHA | Member Since: 12/09/18 | IP: (72.14.241.63) | Report this post to a Moderator
Terrance362
needs moar imput
565/2000
Galant VR-4 org Post #: 1245622 posted 03/18/19 09:45 PM     Remind Me!  Send Private Message   Edit Post
I need the non cruise cable
565/2000
699/2000
Posts: 370 | From: Winston-Salem, NC | Member Since: 08/14/06 | IP: (2606:a000:1018:4) | Report this post to a Moderator
yonwd
Newbie
Galant VR-4 org Post #: 1245627 posted 03/19/19 01:16 PM     Remind Me!  Send Private Message   Edit Post
how much for the manual steering rack? in good working condition?
Posts: 9 | From: Waukegan, IL | Member Since: 05/07/14 | IP: (99.74.66.97) | Report this post to a Moderator
cody
Member ++
991/2000
Galant VR-4 org Post #: 1245628 posted 03/19/19 01:40 PM     Remind Me!  Send Private Message   Edit Post
Rack is in good working condition. Its still in the car. $125 + freight. Probably wont get to taking it out till the weekend.
cody
Member ++
991/2000
Galant VR-4 org Post #: 1245637 posted 03/20/19 08:14 PM     Remind Me!  Send Private Message   Edit Post
All window trim is available and in good shape. Just need to remove it without wrecking it. Will do this tomorrow.
Lesac
Galant VR-4 org Post #: 1245639 posted 03/21/19 12:26 PM     Remind Me!  Send Private Message   Edit Post
Excellent thank you!
736/2000 sold
cody
Member ++
991/2000
Galant VR-4 org Post #: 1245643 posted 03/21/19 04:13 PM     Remind Me!  Send Private Message   Edit Post
Got the rear window trim out. $25 +shipping. I'll have to see if the trim will fit in a tube. Not sure about the bottom piece.
Lesac
Galant VR-4 org Post #: 1245646 posted 03/22/19 08:23 AM     Remind Me!  Send Private Message   Edit Post
I only need the 2 parts from my above picture. If anyone else needs the rest of it then have at it.
736/2000 sold
mscatchell
Newbie
Galant VR-4 org Post #: 1245785 posted 04/10/19 09:30 AM     Remind Me!  Send Private Message   Edit Post
Did your vhl have ABS or did you already delete it? I have a 87 JDM and the pump just started leaking. I'm looking for either a used pump or for the NON-ABS prop valve if you have it. Thanks
Posts: 11 | From: Morton Grove, Illinois | Member Since: 03/22/17 | IP: (2600:1702:e90:58) | Report this post to a Moderator
cody
Member ++
991/2000
Galant VR-4 org Post #: 1245790 posted 04/10/19 02:55 PM     Remind Me!  Send Private Message   Edit Post
ABS was removed by a previous owner. I did scrap the shell already and unfortunately the valve was one item I did not remove before hand.
BLUELIGHTSBABY
532/1000
559/1000
666/1000
Galant VR-4 org Post #: 1245851 posted 04/17/19 01:51 AM     Remind Me!  Send Private Message   Edit Post
Do you have the drive shaft and carrier bearings?
Posts: 68 | From: Franklin, NC | Member Since: 09/17/12 | IP: (98.25.2.228) | Report this post to a Moderator
Lonewolf64
Obviously the answer is......
889/1000
1247/2000
Galant VR-4 org Post #: 1245871 posted 04/17/19 07:48 PM     Remind Me!  Send Private Message   Edit Post
How is your driver's side A pillar plastic trim?
1992 Galant VR-4 #889
1991 Galant VR-4 #1247
2007 Civic Si DD
Posts: 1197 | From: Birmingham, Alabama | Member Since: 05/18/06 | IP: (74.110.184.160) | Report this post to a Moderator
I ain't no puny human
866/1000
Galant VR-4 org Post #: 1245872 posted 04/17/19 07:50 PM     Remind Me!  Send Private Message   Edit Post
Quoting BLUELIGHTSBABY:
You want new carrier bearings, used ones will most likely tear when reinstalling as they would be over 25-year old rubber
Thom
(SOLD) 866/1000 (PTE 1200's, billet 20g+, DSMLink v3, eagle/ross, .020 over, 272's, GC/AGX Coilovers)
Posts: 907 | From: Indianapolis, IN | Member Since: 09/24/14 | IP: (2601:803:c600:5b) | Report this post to a Moderator
vargh4
Newbie
Galant VR-4 org Post #: 1245884 posted 04/19/19 04:32 PM     Remind Me!  Send Private Message   Edit Post
Brake calipers? I'd be interested in all four.
Posts: 1 | From: East coast | Member Since: 01/07/19 | IP: (72.83.97.253) | Report this post to a Moderator
thomasmutter
Newbie
Galant VR-4 org Post #: 1245942 posted 04/24/19 10:20 PM     Remind Me!  Send Private Message   Edit Post
Messaged you about a few parts. Shoot me a text 5412927970. Thank you
Posts: 2 | From: medford oregon | Member Since: 12/30/14 | IP: (2600:1:9718:981f) | Report this post to a Moderator
Gersonseagle
Newbie
Galant VR-4 org Post #: 1245955 posted 04/27/19 03:29 PM     Remind Me!  Send Private Message   Edit Post
What color is the front bumper? More pics n price? Also the bumper lights available?
Posts: 1 | From: Elgin, Il | Member Since: 06/05/18 | IP: (2600:387:b:5::b5) | Report this post to a Moderator
Pages: 1 | 2
1 registered and 13 anonymous users are browsing this forum.
Galant VR4.org Moderator:  4orced4door, curtis, steve, atc250r, jcgalntvr4-244, cheekychimp, jepherz, Rausch, toybreaker, G, iceman69510, pot
Generated in 0.064 seconds in which 0.039 seconds were spent on a total of 14 queries. Turbo powered.
