WTB:
thecannoliman121
Active member
Rhode Island
Hello everyone
About to finish my small re-build on my 1991 gvr4. there are a couple things i need to finally finish it.
1. cylinder head
2. balance shaft remove kit
Pretty sure that is it. if anyone and everyone could help me out that would be great. i my water pump seized up on me and did some work to my head. all the leads are, lack of better words, fucked, and now im back to where i started. i can find the gaskets and timing belt kit everywhere fine but i just need a little help with these. so if someone can offer me some help on where to find them that would be great.
fourforty
Active member
soth saint paul, MN
not that i know much, but have you considered a stub shaft with an oil groove replacement for your balance shafts? or is that what you are trying to find?
mitsuturbo
Near Seattle, Washington
Quoting thedsmguy:
I have lots of heads in various shapes.
I'm not sure what's funny about this. Seems to be he was trying to make a legitimate attempt to help you get what you need. Most of us rebuild heads rather than buying new ones.
Also, if you have a balance shaft and a welder, you have a BSEK just waiting to happen. Simply chop the back side of the balance shaft off and weld the hole shut. Flip the bearings in their bores so the oil holes are blocked off on the front BS and you're good to go.
