WTB: bolt
adamvr4
skokie/ il
Im looking for the 14mm bolt that is closest to driverside that bolts the carrier bearing and the AC bracket to the block. Im missing mine because i eliminated the ac when i first got the car and dont know what i did with it and i need it for my alternator relocation bracket. Does anybody know the thread and size I'll just go to the part store.THANKS for any help
toybreaker
iconoclast
I *believe* that particular bolt leads a hard life, as I've seen a lot of threads about troubles with the hardware in that location.
I've also had to drill a hardware store bolt broken off in the block in that location.
Looking at the factory bolt, it *appears* to be a "shoulder" style bolt.
Best bet would be a new one from the dealer/jnz, but for all intents and purposes, a used one in good codition would be just fine.
In fact, I'd rather have a used factory bolt that a brandy new generic one.
Pot or the Dsmguy will probably have a used one.
Good luck with your search
It is a shoulder bolt with a tight clearance to the mounting bracket(s) holes they go through. Specialty bolt for sure.
