wiper relay
6gCarb
Active member
Makati City, Philippines
i tried searching can't seem to find it on the threads /ubbthreads/images/graemlins/dunno.gif
where is the wiper relay located and any specific part number?
thanks.
6gCarb
Active member
they are all in the same speed, from what i know is that it should vary.
it used to wipe stop wipe stop on the first one, but now, they are just all the same.
I tried looking for it near the wiper motor, but it aint there. /ubbthreads/images/graemlins/bawling.gif
Spyke169
Greenfield, Wi
When you turn them off do they just stop where they are? or do they return to the bottom of the windshield? When the relay is unplugged that is what they will do. Relay is mounted on the firewall, passenger side of the car. It has been a while so I couldn't tell you exactly where.
6gCarb
Active member
Yes they do return where they started when turned off, even if i turn the wiper switch off in the middle of the movement. I tried looking for the one in the firewall passenger side, can't seem to find it.
Spyke169
Greenfield, Wi
It should be right next to the wiper motor, for you it would be mounted above your master cylinder (assuming by your location the car is right hand drive)
Paddy1337
Active member
PA/NC
how about if the wipers are just very very slow? is that just the motors? I was considering increasing power to them, lol.
