Which Evo Coilovers can be used on 91 GVR4
VR4MOE
Member
Copiague, NY
Hey Guys,
I am currently running stock 4 lug. But wish to keep it 4 lug. Can I use any Evo coil overs on my GVR4?
VR4MOE
Member
Copiague, NY
Thanks for the reply.
Would you know which Evo I can use suspension from?
Also do you have a link of this "3SX adapters" that can be purchased?
fuel
Toronto, ON, Canada
Evo 8/9 will need the adapters for the rear, Evo X will need the lower bush on the rear shock changed out to work.
You can get the SCE adapters direct from Supercar Engineering (where you can purchase just the rears instead of the whole set) - click
VR4MOE
Member
Copiague, NY
OK just to confirm that this would work on my 91 Galant VR4?
I want to confirm because it does not state the GVR4. Only vehicle mentioned is the 3000 GT VR4
fuel
Toronto, ON, Canada
Yes works on the Galant VR-4 (and 1st gen Diamante AWD). 3000GT/GTO and Diamante AWD share the same platform which is derived from the 6th gen Galant AWD.
slugsgomoo
Tacoma, WA
don't you also have to run different bolts on the front lowers, and put some sort of spacers in, as the evo knuckles are thicker than 1g/gvr4?
467
Royal Oaks, Ca 45 min S of San Jose
I have the rear SCE adapters direct from Supercar Engineering for the Evo shocks and springs and there is an issue with them that has been noted by others.
The 3/S has a R lower shock mount with a larger diameter taper than the GVR4. This means that if you install the tapers of the mount and adapter aligned with each other the way they were designed for, the fit will be sloppy. If the adapter is installed with tapers opposite to each other, the smaller diameter of the taper on the adapter fits closely (no slop) on the larger end of the mount closest to the trailing arm.
I can see how this would work short term, but there will be a very small amount of bearing surface between the tapered mounting stud and the reverse tapered adapter. I am afraid to run it this way as I think the white adapter bushing (feels like nylon) is going to deform and get hogged out and loose.
slugsgomoo
Tacoma, WA
The best question in this thread that hasn't been asked is WHY.
Unless you already have coilovers for an Evo, why not just get Galant specific ones? If you do have a set, why not just buy the right mounts (assuming the threaded body is a standard diameter).
It's not 2004, there are options that don't involve "cobble something together"
