Whats in your gvr4 tool kit?
1badgvr4
georgia
I know everybody has an emergency tool kit.I need to update mine so what do you guys carry in yours?
iLLeffeKt vr-4
NYC
AAA, hydraulic jack and atool box in the back with pretty much everything in it. Tool box with everything in it weighs about 120lbs /ubbthreads/images/graemlins/grin.gif
spooling92vr4
long island, NY
Used to have in my eclipse at all times. spare ecu, coil pack and transitor. small husky socket set w/ spark plug socket and long extension, 10,12,14,17,19 mm gear wrench, pliers, cutting dikes, 4 in one screwdriver, electical tape, some wire, gloves, tire worms (plugs),oil, extra set of spark plugs and zip ties...
and thats driving around town.
1badgvr4
georgia
Quoting spooling92vr4:
Thats the answer I was looking for.
fivestardsm
Middle, Michigan
+1^^ and also:
Extra set of front pads, Brake fluid, slave cylinder, 2 or 3 hammers, all my timing tools (you never know when you might need to do a repair for someone if you travel) at least 1 extra alt belt, fuel pump relay, a small go-jo can full of misc. bolts & nuts, a few extra lug nuts, a test light, analog multi meter, and some extra wire incase, and flashlight's everywhere!
But then again, this is probably why my fuel economy was so poor!!
Nartanian
Richfield, MN
Quoting 1badgvr4:
Emergency tool kit?... Who needs one of those? /ubbthreads/images/graemlins/grin.gif
Armitage
Herndon, VA
^^ Seriously! I carried around a full tool box for like 7 years in the trunk and never once needed it. After 210k miles the car is still dead nuts reliable and I don't carry any tools anymore /ubbthreads/images/graemlins/wink.gif
So far:
-screw driver set
-metric socket set with extensions
-assortment of metric screws/bolts, washers, clips, zipties, fasteners
-1qt oil
-1gal coolant
-jack
-9-LED flashlight
-magnetic telescopic tool
-work gloves
-assortment of electrical taps, wires, fuses, and tape.
TylerAdamson
Iowa City, Iowa
8mm - 19mm standard depth and deep well
22mm, 24mm and 32mm
Spark plug socket
17mm - 19mm 1/2 drive sockets
Allen keys
Full set of screw/nut drivers
Brake parts cleaner/PB Blaster
Oil filter
Zip ties
Duct tape
Tin snips
Aluminum jack
Safety wire and safety wire pliers
Hair spray (intercooler pipes) oil
Qt of
Gallon of Coolant
Thermostat
2.5'' T-bolt
Various sized worm clangs
I think that about sums it up
91GSR
Newport News, VA
set of sockets
set of wrenches
LED light i can attach to my head so i dont have to hold a flashlight
mallet
screwdrivers
extra lug nuts
2 jacks (bottle jack and hydraulic jack
electrical tape
wd40
