What would the largest fitting tires be on a 17x7.5 rim?
bazeng
Melbourne, Australia
I guess I'm asking more specifically about the height of the tire since I'm running the 3.909 ratio box/diff.
Opinions guys?
Baz
belize1334
Bozeman, MT
I'm a fan of 225 tires. They're wide enough to have good grip but not so wide that they walk all over the road when it's rutted. A 225/45/17 tire would be 25" tall compared to the stock 24.2" and I wouldn't go much taller than that or you may find the tire rubbing the inner fender wall when you turn in. I have a set of 225 tire on my 16x7 and I like the way it hangs past the rim a little. You won't get that on a 7.5" wheel but considering that people run 205s on 7s, 225 on 7.5 is probably not too narrow a tire for the rim.
iLLeffeKt vr-4
NYC
Galant wheel/tire info can be found here
On a 7.5" wide rim you can fit 235/40-17's but depending on offset it might rub.
bazeng
Looking at the database, 225 45 R17 sound ok.
235 45 R17 I wouldn't mind trying BUT I don't want to be stuck with tires that scrub.
They are for EVO V enkei F1 rims.
I've gone 5stud!
Quoting iLLeffeKt vr-4:
Agreed, this is about the most you can fit on there, but the car may actually be more responsive and predictable on 225's.
iLLeffeKt vr-4
NYC
Taken from the same link:
rim tire offset comments backspace
17x9 245/45/17 25 Konig Villan for 95+ Mustang 6.27
17x9 255/40/17 25 Konig Villan for 95+ Mustang 6.5
17x9 255/40/17 28 Sticks out about 1" Kuhmo V700's 6.62
17x9 255/40/17 30 Sticks out a little 6.7
Note: It appears that a tire/wheel combo that ends up with a total back space number of 6.0 to 6.7 will work
It also depends on what tire size you go with.
Quoting bazeng:
Do you guys think a 17x9 +22 offset rim would fit our cars?
17 x 9 with a +22 offset would put the wheels well past the fenders. Even if you were to use a 17 x 8 wheel the +22 offset is too agressive to fit inside stock fenders.
Daryl
bazeng
Hmmm...
I might just stick the the 17x7.5" rims then.
Although it would look great with flared gaurds, I just don't think there is much gain for doing this.]
Thanks for the info!
