What gauges did you start with?
James
Port richey Florida
A lot of people take a different process when setting up their gauges. what order did you take? I usually go Boost, wideband, and oil gauges first. do you prefer EGT over Wide band? both? neither? Water temp before oil? talk about it.
btw ill be in a the market for these items soon, soooooo, yea.
raptorWagon
Oak Harbor, WA
EGT isn't really needed anymore these days with wideband being the more accurate between the two.
I started with Boost, Water Temp, Wideband.
DynastyLCD
Harwinton, CT
Quoting citymunky:
Boost, Wide Band, Oil pressure.
this.
i also use a water temp gauge. its nice to read numbers as opposed to lines.
Ian M
Martinsburg,WV
When I started,the setup was a boost gauge,and a multimeter to monitor O2 voltage...there wasn't widebands or even pocketloggers yet. Just realized it's been 14 years. Yikes.
4Grim
Orlando FL
Mine has been this order:
Boost
Oil pressure
Fuel Pressure
Water temp
Wideband
boostedinaz
Scottsdale, AZ
Quoting citymunky:
This was my setup.
At one point I also had an EGT gauge. Wasn't bad I just didn't want to take it out when I got my wideband.
mitsuturbo
Near Seattle, Washington
I consider oil pressure to be the most important. Boost would be second. Wideband 3rd.
Having said that, i've outfitted my latest build with a boost controller which monitors/displays boost, oil pressure, fuel pressure, and voltage. I went ahead and used my old EGT gauge, even though it's not all that useful anymore, but it's mounted on the A pillar right under my WBo2 gauge. I may decide to get rid of the EGT at some point, and replace it with something else, such as water temp, but for now I figure i'll see how it works in conjunction with the wideband.
vtecds1
Las Begas
Quoting Ian M:
Back in the day I relied on a boost, egt gauge and jumptronix.
Same here. The Jumptronix gauge was neato.
As of now in 1051 I have Defi boost and EGT and my PLX wideband display. I'd replace the EGT with oil pressure, but I can't find these old style Defi-link gauges anymore. And I don't wanna get new style ones because these match the factory [green] dash lights almost perfectly.
biglady112
Commerce City, Co
If you do any real tuning and actually race your car, EGT's are still very important. It has save our engine multiple times. Granted we run four EGT's with warning lights setup on our RacePak dash.
With that said, I actually don't run any gauges. I datalog everything. I am not into having someone look in my car and going and steal my sh*t. The last car I put together which a friend now owns, has a Tranny Temp gauge(auto tranny) and a wideband. Both installed in the glove box so they are out of sight.
beaner
b'ham, mi
Most important to me is boost press, oil press, fuel press, wideband. Fuel pressure I used once, and oil pressure I'll look at maybe once a month maybe.
Quoting biglady112:
Same. I really regret cutting my dash up to install gauges. Could have a bone stock appearing interior if I never messed with it. /ubbthreads/images/graemlins/banghead.gif
With dated dsmlink setups being so cheap now, I'll never run another gauge in a dsm again. Logging all those values is the only way to go IMO.
mikus
Aurora IL
^ agreed - gauges are useful for a period (setup, diagnostics) but if you're not messing with your setup they're not all that useful. Even boost - if your setup is static, do you really look at it anymore?
If I could go back I would have run some sort of logging & diagnostic app from day one (even PDA), far more useful than gauges have been.
