Weird noise (high pitch, faint metal on metal, dog whistle)
James
Port richey Florida
I recently developed this noise and it's hard to diagnose because it is happening at a lot of different times. At first I thought it was really faint brake squealing but it happens at a idle sometimes. Here's a list of then it has happened.
Note it's from the FRONT PASSENGER side:
Idle when I start the car
At an idle and a blip the gas
Coasting down in gear
Maintaining speed in gear IE 35mph in 3rd gear partial throttle
Braking
Only thing I have done was lightly crush my 1g bov and replace my BOV/UICP gasket.
I did a BLT to see if I could get the sound to happen and got nothing.
MellowVR4
Milwaukee, Wi
Does it do it when ur cruising at a certain speed? like not letting off gas at all which would actuate the bov.
James
Port richey Florida
Yea I think that would be covered in example2
"Maintaining speed" example: 35mph in third gear. Where I don't really have to be on the gas or completely off it.
James
Port richey Florida
Here's a 8secondnvideo of the noise. This is keeping speed of 25mph in second gear. Just enough throttle to keep the speed, no brakes
Seems like it doesn't want to upload for some reason
Racah15
Colorado springs CO
It's your BOV. Especially if it's a 1g. I've had this happen on my 1g. It sounds like a really high pitched , dog whistle type sound. It's from the BOV valve not closing completely during vacuum situations. So it makes a loud whistle from the valve not closing completely. Take off the BOV vacuum line and plug it on the vacuum side. See if the noise continues. Drive, idle, etc.
IF it doesn't, it's your BOV. Either replace it, or....replace it..
If it does, then it might be your valve. You may have damaged it during crushing. I've seen a few people improperly crush them and it ruins the BOV.
Haha
Oh PS. Your video doesn't work
tyeler18
Casa Grande, AZ
^^ This guy is dead on. I have a crushed 1g bov on my 1g that does the same thing as well as an uncrushed 1g BOV on my 2g that does it. It was annoying the hell out of me and I finally swapped it out with an ebay greddy I had laying around to see if that was the problem. I pulled the top off the uncrushed bov and the diaphragm had a very slight tear in it. Must've been just enough to cause it to leak.
