Water pump opinions
cspetros
Port Norfolk, VA
It has come time to replace the water pump on one of my Galants. The pump has started pooping water out of the weep hole.
I found a replacement water pump on PartsDinosaur.com: Replacement Water Pump. The cost of this pump is only $40.
I priced a stock water pump at the dealer for $122 /ubbthreads/images/graemlins/jawdrop.gif.
My question: In your opinion, which pump should I go with, and why? $40 or $122? Is there some sort of hidden reliability issue here?
Thanks /ubbthreads/images/graemlins/smile.gif
Lonewolf64
Birmingham, Alabama
I used the $40 dollar pump and it popped prematurely at 40k. I'll never get a non OEM water pump again. Take that however you want to.
SmoothCustomer
Lexington, KY
I ended up being forced to go with a cheap-o and I've been scared ever since I first turned the key.
Edit: Pretty sure those oem ones aren't even mitsu, but it is definitely what you want.
dsmless
tucson,az
i used a autozone one with no problems for about ayea of long driving, but used a mitsu t-belt, some tings you cant beat oem
Brunoboy
San Bruno,CA Home of SFO
I have a gates timing belt in the garage my friend put on his car then took it off. still good he says, uhm your right about some things just need to be OEM like a headgasket, cant cheap out there lo.
-shane
Polish
NE, IN
I'm broke and felt like being risky, I ordered the $24 Rock Auto pump. We'll see. /ubbthreads/images/graemlins/hsugh.gif
/ubbthreads/images/graemlins/uhh.gif
cspetros
Port Norfolk, VA
Quoting Polish:
If Polish has the balls to try one, then so do I. We'll give you a report.
Polish
NE, IN
Quoting SmoothCustomer:
Lol I didn't even know they came that cheap.
Me either, but for the cost of an oil change I'll give it a shot.
Quoting cspetros:
/ubbthreads/images/graemlins/rofl.gif
My report will be a while - car will be JSB for another few months at least.
thecman02
Kalamazoo,MI
Hm. I have this decision coming up too because my engine build is almost done. Saving a Benjamin up front is mighty tempting, but having to replace the damn thing withing a month or two of installing would piss me off badly. I guess it just comes down to luck. I would think you have a better chance of not getting effed with oem pump as opposed to cheap, but you never know.
jepherz
KC, Missouri
I usually go with the premium version of a pump at NAPA or the likes. I had an OEM pump go at 80k, and never had a knock off go before 60k, so I just replace them when I do the timing belt. A lot of OEM parts can be had reboxed outside of the dealership for much cheaper.
Barnes
Richland, WA
Quoting Polish:
Polish spec water pump re-install to follow after 10k miles.
cspetros
Port Norfolk, VA
That's not what the inside of any proper water pump I have seen looks like /ubbthreads/images/graemlins/uhh.gif
Yeah, the stock AISIN pump has a turbine looking thing with blades. The pump in that link doesn't.
