vr4 brake upgrade
dsmless
tucson,az
have searched and searched but no luck, want to know if theres a write up or someone here has installed 92+ dsm brakes on there galant but kept it 4 lug still??
524of1000
San Antonio, Tx
Our brakes are the larger eclipse brakes. You'd be swapping the same brakes over. From what I've heard, the N/T 3000gt calipers have slightly larger pistons and *should bolt on. The 3000gt VR4 calipers are a sure fire upgrade, but require a 5 lug swap, adapter brackets, calipers, rotors and 17x8 +35 wheels.
Okayplayer
Denver, CO
The 2 piston calipers that our cars come with stock are considered the big big brakes for dsm's. If you want to go bigger, there is the option to use 3000gt/stealth rt brakes which are 4 piston calipers. There is even a kit for it on tunersnation
citymunky
Chesapeake, VA
Quoting 524of1000:
Yes the 3000GT SL front brakes are bigger than OEM Galant VR-4 brakes since 3000Gt was a bigger car. They do bolt-on to hubs with no kit.
Here a set for sale:https://www.galantvr4.org/ubbthreads/showflat.php?Board=UBB1&Number=1040297&page=0&fpart=1
The 3000GT VR-4 had 4 piston front brakes calipers and do adapter brackets (TunersNation), calipers, rotors and rims 17x8 +35 offset or bigger. 5-lug swap is not needed but makes life a bit easier.
dsmless
tucson,az
Thanks this is what i was looking for, theres a 3000gt N/t in the local pullers , thats why I asked
dsmless
tucson,az
Yeah and its all rust free too so no broken or stuck bolts, theres a base model 89 galant here too w manual seatbelts and under dash pocket colors blue tho
makedollarz
Phoenix
I used all the above, 3000gt pads, calipers, and tunersnation adapter plate, and just ordered new rotors drilled for the 4lug galant style. Saved the hassle of 5 lug swap and i already had purchased aftermarket 4 lug wheels, so saved that headache as well, its worth the swap for sure in braking feel.
