Twin Disc Clutch Survey
arapp
Member
So Cal
This is just a survey so see which twin disc clutch setup you guys run/prefer on your GVR4’s.
I'm in the market for one and would like some feedback good/bad from those that are running them.
slugsgomoo
Tacoma, WA
I would probably run the triple exedy that magnus was selling for a while, or the gear drive quartermaster, if I were buying new now- neither option was available when I bought mine.
That said, I pulled my engine (sold the 2.0 this weekend) and looked at my clutch (PTT high torque), and I have no spline wear, and the clutch basically looks new. Never really launched on it, but some hard miles with flat shifting at 9k+ on a 67mm turbo at 26psi /ubbthreads/images/graemlins/laugh.gif
I'll try to remember to take some pics when I go home.
mitsuturbo
Near Seattle, Washington
I have the 6 leg QM geardrive. I absolutely love it. It is very noisy, though.
If i were buying one again, i'd definitely, with zero doubt, go for the Quarter Master 8 leg Gear Drive twin.
arapp
Member
So Cal
Thank you for the info, I see there are several Quartermaster 8 Leg twins on there I'll do more research.
Did you use their hydraulic release bearing or stick with the stock mitsu T/O bearing and fork?
Also how does the clutch pedal pressure feeling compare? Im trying to find one close to stock, my ACT2600 is beating me up.
slugsgomoo
Tacoma, WA
My PTT is definitely lighter than stock. I'm using the PTT throwout bearing, which uses the backing plate from the OEM TOB to install (bearing is conical, OEM is not supported with my clutch).
To make mine more driveable, I have the 2g FWD slave cylinder, and the 2g accumulator tank and it still requires practice to get comfortable with (valets will hate you /ubbthreads/images/graemlins/bowrofl.gif )that said... I doubt I would run a twin unless I needed to- that being either high torque, or high RPM shifting. Otherwise they are a bit race-car-y to live with.
Southbend has some nice single disc options that turbowop and others have reviewed quite positively here.
mitsuturbo
My QM pedal effort is about like stock (possibly lighter). Definitely nowhere near what a 2600 is.
I'm running stock TOB and a Comp clutch fork that is clearanced for the pressure plate.
A twin is definitely not for everybody. It certainly gives the car a much more "race only" feel to it. Stop and go traffic is pretty shitty. These clutches are basically on or off. There's not much in between. And slipping them isn't a great idea, since the floater will warp fairly easily, as will the pressure plate. Fortunately, individual parts to rebuild/repair these are fairly inexpensive. I paid 800 for my clutch used with great frictions, but the PP and Floater were blued and warped beyond belief. It cost me another 200 to replace the PP and floater.
EMX5636
Bucks County, PA
I absolutely love my Exedy twin plate. But sadly, I don't think they're available anymore. I bought a spare a while back for parts in case I needed to rebuild it. I have 25-30k on it at 500~ whp.
