AnotherNewb
Okay, I have been working on my buddies galant VR4 for a while now and we ordered a "turbonetics" VBC off of ebay, I think it is counterfit. It lookes just like the kit that summit racing sells minus 2 90 degree elbows, it came with instructions but no box. Here is the problem, it looks just like a pressue regulator for an air compressor with 3 inlets and one outlet marked with an arrow. I took it apart and there is no ball and spring just a plastic plunger diaphram and spring. I have a vacuum line running from the intake manifold to the inlet side of the BC and a line from the outlet to the WG. It is only making stock wastegate boost no matter how many times I turn the knob. I tried blowing in the inlet side of the BC and only after completely turning the knob out is air able to flow freely. Is this a bleeder type BC? If so, I have it hooked up wrong, don't I. Thanks for the help
