Turbo timer = no rad. fan
mitsuturbo
Near Seattle, Washington
My radiator fan does not come on when the car is running on the turbo timer. It's not a stock fan. It's a 14" 2200cfm puller, but i've removed the resistor and it's just running off two of the fan wires. It runs fine when the ignition is on. Once i switch the ignition off and the turbo timer takes over, the fan WILL NOT run.
Has anyone else had this issue? Solution?
