turbo oil feed plug
marvinmadman
Lafayette, Louisiana
What's the options for plugging the oil port in the head when sourcing oil from the OFH? I am looking at maybe doing something simple like a bolt from Home Depot or something if I can't find a factory plug at the pullapart yard. Also what cars would have them? NT eclipse? Hyundais? Or if I have to order one, which site is best?
JackstandTSi
Columbus Ohio
Quoting marvinmadman:
I think the bolt is a m10 1.25 bolt but unsure of length if you dont want to wait for shipping.
Boostin_AWD
Active member
Utah
I personally just used a bolt from the hardware store. About 10-15mm long should do.
marvinmadman
Just found 2 at the junkyard. 1 from a turbo 2G and 1 from a 90 SOHC Galant. Both are identical and fit perfect. Hope this helps somebody else.
Boostin_AWD
Active member
Utah
All turbo 2g's will have them because the turbo feeds from the ofh. They are also in all non turbo 1g's with a 4g63. I found a '94 galant that had a 2.4l dohc and looked to have a 2g head?? That had the plug as well.
G
zompton
I wonder what the mitsu part number is for this.
