iLLeffeKt vr-4
I think I have an issue with the shifter cables but I'm not sure yet.
It doesn't want to go smoothly into reverse and it doesn't go into 1st, 2nd or 5th.
If I put it into 2nd or 4th then it goes into 1st, 3rd, or 5th but not all the time.
I want to order new cables but I don't know which ones.
The code on the transmission is KW5M332NPZS and below that KD7195.
According to the HowTo section the transmission is out of a
US TEL 1G 3/89 - 6/90 (shift link) -> w5m332npzs
Now which cables do I order from extreme?
The 3/1/89' to 6/1/90' Eclipse or the 6/2/90' to 5/3/93' Eclipse
I don't think the cables were ever changed on this car so I'm assuming that when the previous owner/s changed the transmission from a 91 to a 90 the shifter bracket from the 91 was swapped on the 90.
Should I take pics of the bracket and post it here? Any of you guys know the difference between a 89-90 and 90-93?
