Timing belt ?
My timing belt has good tension, but it's swaying on the gears to the point where it rubs on the cover by the head. I replaced the belt and tensioners and they all have about 5 miles on them. So before I run out and buy more new stuff do you guys think in missed something in setting up the timing belt or did I just get a bad tensioner. By the way car runs fine just going to kill the belt in no time.
donkeylips
Rochester, NY
So you replaced the belt, the 2 pulleys, and the hydraulic tensioner? Did you use OEM or aftermarket parts?
Hydro tensioner was OEM every thing else was after market.
When it comes to timing components, IMO, always go OEM. Unless your splurging for the gates or the HKS
I'll check the bolt if it tight I'll see if the washer there. I remember when putting everything on (its been a few months now) that the pulleys had little lips on them I put them toward the block because it looked right, could those be on the wrong way.
4wheelsqueal
Shawano,WI
Could have do the same thing I did. You have to rotate the blue idler with the off-center bolt to a certain spot or there will be too much slack in the belt. When I get mine done, will let you know how I did it but pretty sure that's the problem.
