Timimg with CAS and a timing light
Number996
Gaithersburg, MD
Hey guys, great news; rewired missing plug from harness to give ecu power and she turned right over. My issue now is as follows;
Engine turned over fine, fired maybe once per cylinder then died. So accounting for compression, fuel, and spark, i then moved onto timing.
The further i advanved the timing (moving CAS clockwise when lookig at it) the closer the engine got to starting and idling. The engine finally started, held a shaky idle when timing was fully advanced and a friend clocked the engine with a light gun at what he guessed look like 15* BTDC. I knew this wasn't right. SO, i depressed the timing fully (all the way counter clockwise when looking at the CAS) and went to investigate the idle screw. The idle screw was in all the way and i assumed this was also incorrect. I proceeded to unscrew the idle screw about two full turns, left timing fully depressed, and started the engine. She started and idled alot better, but there was still some fuel coming out of the tail pipe so i shut her down before attempting to time her with the timig gun and went to bed because it was late.
I'm going to try to time her again after work. My homework is indicating our engines like 5*BTDC, is this accurate?
My biggest concern is if i did any damage to the engine starting her with idle screw all the way in and timing fully advanved for less than maybe 5 min? And again with timing fully depressed for another 5 min? There was also ALOT of fumes and white smoke from exhaust manifold but i think thats prob something simple i can figure out myself.
Thanks guys! Almost there
