Suspension suggestions
rjoey24
New member
phila
Hi all, I'm looking to drop the car an inch but I want the same comfort as the stock suspension. What setup can you guys point me to?
basic H & R lowering springs are probably your easiest road. You could also use 1G AWD springs if you can find them. I did this on my daily driver years back, but did cut a half coil from the fronts. With the H &R some guys like to cut some out of the rear to level the car more. You should be able to find some posts here talking about this.
KiNgMaRtY
Corona, CA
The most comfortable suspension that I had in my Galant was H&R springs with Koni struts. You will have to cut a piece of the rear spring if not it will have major rake.
