Suspension info needed
rost
tarzana,ca
I currently have a combo kyb agx/megan springs on my car.Ive read if you want an even drop you have to use 1.5 drop rear springs.I think megan are 1.9 drop.I've read a member saying you can use some sort of a spacer with a 1.9 in drop springs and it will even it out.What exactly can you use?
Second question,im pretty sure my front struts are blown.I bought them from some dsm owner used,the came assembled with some lowering springs,and he said they were not blown.In any case,i think they are.When driving on the freeway,the car feels like a boat.And when i push on the front end it doesnt stop right away,but kinda keeps moving.The question is,could it because they are set on the softest setting,or are they actually blown.Thanx in advance.
SouthCaliVR4
North county San Diego
I can't say on the springs but my w/my agx's the car can barely be moved let alone bounce at all after the fact. I'd say your's are blown. they do have a lifetime warr but you'll need a buddy working an auto parts store to pull that off getting them second hand.
rost
tarzana,ca
As far as bumpstops go,do i have to cut them when lowering the car,or leave stock length?
