Sunroof Delete?
Fiascoxl
Stuarts Draft, Va
Ok so after staying up till 5 a.m. last night and battling a few hours this morning before work I still cannot find my electrical short causing my sunroof relay fuse to blow.
I narrowed it down to a blue with black stripe wire leading to the ETACS(what a wonderful overly complicated p.o.s. system to say the least). I pulled back as much wire as possible and cannot find any burnt wires or anything. I'll also add that the wire is acting like a ground when applied to the negative side of my volt meter and the positive to positive.
This is consistent with me originally doing the same to #13 fuse location with the top of it seeing battery voltage(fed from main) and the lower portion seeing ground somehow possibly leading up to that LB wire going into the etacs. /ubbthreads/images/graemlins/banghead.gif
Ok so now the backstory is complete has anyone successfully and cleanly installed a piece of tinted lexan into the hole and removed all the heavy sunroof motor, glass and tracks? Seems like some window weld would work easily but finding a seal to overlap onto the roof so it doesn't looked hacked would be tricky? A carbon plug would really be trick but I seen a aftermarket company that wants a lot for a custom plug and the whole sunroof if possible there.
Any Suggestions? /ubbthreads/images/graemlins/dunno.gif
idreamidrive
Murray, KY
check out honda tech for ideas, that place is a gold mine sometimes.
I know my friend just recently did a carbon plug for his em1. click
Not sure the idea will work for what you want.
JNR
ca
I thought it had been done on here, but it was quite some time ago and probably got deleted with all the other "old stuff". You probably already searched for it, though.
Personally, I would just fix the sunroof...mainly because I like it and did use it quite a bit. Never gave me issues, although thought I read that the drains should be kept cleared out from time to time.
vr4play
Cincinnati, Ohio
I made my own sunroof delete. I still have the mold but don't really want to try and make a carbon one as mine came out kind of funky. Good enough for me but I wouldn't sell one. I can make a fiberglass one though. I have the one that I used to test fit before making the carbon one if your interested. Just needs painted.
Fiascoxl
Stuarts Draft, Va
Yes I am very much interested. Does it go in by itself? I really want to get rid of the tracks as well as the glass.
edit: found the post with the sunroof delete in it, I knew I seen it before. click
