stuck on a 1g swap in #26/ 2000
505VR4
Member
santa fe, nm
Im stuck on a engine swap. Im doing a 1g fully built engine swap and don't have the right front engine bracket. i have the original vr4 front cross member n front motor mount. my question is will a 1g front engine bracket fit the vr4 mount? or do i need the vr4 specific front engine bracket for the front motor mount?
Do you mean the forward mount bracket that sits below the turbo? If so, then yes, it's a GVR4 specific mount bracket. It should be numbered 344. They are rare too.
505VR4
Member
santa fe, nm
yea its that bracket. i swapped in a 92 1g n cant find my bracket when it got back from a shop that did the engine build. but as a 1g engine wont it need the 1g front bracket? i heard a galant gsx front bracket will work too.
LIV4PSI
O-H-I-O
No, it needs a Galant bracket. The blocks are identical, it's the positioning of the front mount that is slightly different
Quoting 505VR4:
The Galant GSX bracket will work, but that's just as rare. Only the GSX though, the fwd will not.
