stainless steel fuel lines
LordAthey
Council Bluffs, Iowa
Anyone running these all the way from the pump to the rail with a aftermarket fuel filter? If so can you tell me where a good place to buy the lines are and what side you guys used. looking for about 300hp to 400hp.
Muskrat
Lexington, KY
Are your fuel lines bad?
You don't need larger fuel lines for 3-400 hp.
If you do go this route, make sure you buy fuel rated lines, not generic stuff.
LordAthey
yea its rusted through on one part of the car so I need to replace them. So i figured why i was down there get the stainless steall braided ones. Where did you get yours from?
TylerAdamson
Iowa City, Iowa
Call up Jay White at Jay Racing. He sells a feed and return line kits. I think he sells them for $100.00 each. They are all -6 line and fittings. He also offers filters and would probably give you a decent deal if you buy it all at the same time.
Fuel return
Bosch fuel feed
The fuel feed kit is pricey but it includes everything you need. Pump, filter, fittings, lines, and clamps to mount the hose.
