Slipping clutch diagnosis help
CarRacer
Shakopee, MN
I'm 100% positive my clutch is slipping in my car but I'd like help getting an idea on what parts I might want to buy before tearing the car apart so I can get it on the road quicker. Slave cylinder is brand new when I installed the new transmission. Clutch and flywheel were both purchased new by myself. Fidanza aluminum flywheel and a 3.2 pp/disk setup. These parts all have 10,000 miles on them, with less than ten launches in that mix.
Car has the normal symptom of wanting to rev in higher gears. The pedal feel has changed with the onset of these symptoms and has gotten easier to push. I'm not sure if that indicates the pressure plate took a sh*t or the disk is dying.
Thanks for any input.
curtis
Clarksville TN
Sounds like the disk died. You'll need a new disk and a friction disk for the fidanza wheel. If you want a PTT dual disk give me a pm I have a buddy selling one has 2 new disks and the flywheel and pp plate has probably 1000 miles on it since new. He pulled the trans to fix the center diff and while apart replaced the disks then had another problem so he's parting the car out. He told me $750 for the PTT. The trans is already out so could ship the stuff out quick.
On a side note just be thankful this isn't you. click me
JNR
ca
You have good fluid and/or bled properly?
Nabeel
K.S.A
Transfer case fools me. I thought clutch slipping. So check it before spending$$$
CarRacer
Shakopee, MN
Quoting curtis:
Ugh, don't tempt me. I daily the car and don't plan on making huge power so a twin disk is probably impractical for me. Thanks for the offer though, it sounds good.
Fluid was fresh at time of clutch/flywheel/trans install. I don't think it ever got hot, but I could have missed something. I ordered a new clutch and pressure plate just in case either is toast. I plan on limping it through the week and swapping it over the long weekend. It's gotten more finicky and is starting to slip on any major throttle input. I don't think it's a broken axle as mentioned by chat cru today, as it smells of burning clutch after a few slips and the change in pedal feel still scares me into thinking it is a slipping clutch. Disappointing to say the least after the few miles I've put on this car.
Thanks for the input.
ApexHunter
Marysville, WA
Quoting curtis:
/ubbthreads/images/graemlins/eek3.gif That is hilarious and sad. It's guys like that who prompt manufacturers like Ferrari to sell the Enzo, FXX etc to certain buyers. Lexus LFA is gonna be the same way. I bet with a little coercing from the checkbook the rules bend a little though.
Sorry to threadjack.
JNR
ca
wow, on the video! how do you even accomplish something like that, ha ha...*almost* feel bad for the guy tho, but what a waste of a clutch and who knows what else (judging by this, who know how he drives it).
