Single Din Radio Trim + Triple Gauge Pod Insert & Double Din Radio Trims
noglets
Active member
coeur d alene, idaho
Recently just finalized the design for my Single Din Trim with a triple gauge pod insert along with a double din radio trim. These are modular so you can put the insert in the top or bottom slot and rotate them 180 degrees to put them in RHD cars, everything is available over HERE
