Shifter issues
I have not ever done much of anything with a shifter, so issues that arise with it are typically problems that I have never dealt with or corrected. What mine is doing is it's harder to get it into first gear now, I usually have to put it in second first then slide into first. Additionally, every so often it will grind/rumble a bit when I go into senond or third. I'm not too sure on where to start, I have heard that it's my bushings, cables shifter, trans etc...
Also I'm not sure if the outside temp has anything to do with it, it has been below freezing almost every day for the past month.
Thanks in advance guys.
Brunoboy
San Bruno,CA Home of SFO
synchros? try changing fluid? theres a mixture for the tranny fluid that people are using that consist of i think redline tranny fluid and shockproof. someone correct me if im wrong.
KiNgMaRtY
Corona, CA
Does the shifter have a lot of play? Could be worn bushings. Have you tried adjusting the clutch master cylinder at the pedal?
KiNgMaRtY
Corona, CA
Get new shifter bushings from Mitsu. There are a total of 6. 4 are the same and 2 are different.
