Shifter/base bushings
MellowVR4
Milwaukee, Wi
I have a dumb question but, For those with brass shift linkage bushings and solid shifter base bushings experience any excessive transmission noise? especially when you remove the center console and drive with it off?? I would think the console insulates most of the noise, but just curious on everyone else experiences...
Thanks for any input on this..
tektic
ronkonkoma, ny
Yes there is an audible difference. With the shift boot on it quiets a little, But its not that big of a difference to begin with. I have an aluminum flywheel that I suspect was also contributing to noises. I have removed it and am going to be putting it back together this week so ill let you know at the end of the week.
MellowVR4
Milwaukee, Wi
Thanks man, please lmk...Mines make noise, normal noise you can say. But my trans is rebuilt with new cables. Kind of sounds like one of those rally videos when they have the camera in the car... but not as aggressive!
KiNgMaRtY
Corona, CA
I've had them all along with a real Symbroski kit. They basically just hold the shifter base to floor with solid mounts rather than the rubber mounts. Audibly, there is not any difference, very minimal if any, in everyday usage unless perhaps you have your windows closed, radio off and oem exhaust to attempt to hear the difference.
tektic
ronkonkoma, ny
I was leafing through the FSM and saw there is a secton that goes over the whole alignment process. Check it out. I know when I set up mine I was missing some special spacers and such. It made it impossible to go into reverse.
MellowVR4
Milwaukee, Wi
I did see the one on VFAQ, and I followed the directions. Since the OEM vr4 cables only has one adjustment on the left cable, I cant seem to get the right cable to be straight, it gets cocked once I remove it from the arm just the like the vfaq pics show.
KiNgMaRtY
Corona, CA
The majority of the good base bushings have a groove that will seat inside the base of the shifter base so it will center it.
MellowVR4
Milwaukee, Wi
My main question leans more towards the cable bushings with the noise issue that i'm having. I have brass right now and wondering if by having brass would increase the amount of noise that the trans produces? vs the stock rubbers..
Any less damped vibration will increase noise propagation. Less rubber, less damping.
