setting base fuel pressure
omertaitalia
Downtown Los Angeles CA/Lake Tahoe,CA
i have a aeromotive and searched google up and down, I've read on a tuners post that you need to start the car, remove the turbo hose and plug that bung then adjust fuel pressure. is this the correct way to do it if not can you point me in the right direction, can't find a vfaq either.
dmj
orlando FL
Car would run extremely rich at idle, fouled plugs, black smoke and fuel smell are some "side effects".
marvinmadman
Lafayette, Louisiana
Doesn't really matter. As long as the car doesn't kill, u should be ok. Running only makes sure u have the proper voltage going to the pump. Just pull the line off, plug the manifold if u want, then set the pressure.
Brunoboy
San Bruno,CA Home of SFO
pull the vac line off the FPR. Leave the FPR nipple open and set the pressure to desired pressure and reconnect the line. The vac line doesnt need to be capped off when adjust fpr because the FPR isnt seeing any pressure other than fuel. Easiest way is to tell ECMLink to activate the fuel pump and set pressure that way so no vacuum is needed.
-Shane
joggle
Active member
Rochester, NY
There is a fuel pump test connector in the engine bay it is capped off and is a single wire. I don't recall if you ground it or apply 12 volts. That will run the pump without the engine running. Safer that way.
beaner
b'ham, mi
Important! I set my afpr with the engine off, then I started the car and had to readjust it. Next time I have to adjust it, I'll try with the engine off and jumper cables connected to a running car.
