rearend question
Redwood
Moses Lake, Wa
so i have been looking for this for a bit but could never come up with a real answer on, what the lenght of a vr4 rearend is compared to a 2g.
and what is the rearend in a galant, is it the lsd 3 or something else. i no that the one in the 2g is an lsd 4 but wasnt sure on whether or not that it would fit into my car. i have seen alot of people say that they have destoryed a lsd 3 with not very much power so i kinda would like to put a stronger one in my car seens how my goal is to be around 450ish hp.
thought conserns greatly appreciated
DynastyLCD
Harwinton, CT
2g rear diffs will not work, period. the axles are different, and the mounting points are entirely different as well.
you most likely have a "3-bolt" rear end. you can tell its a 3-bolt, because there are 3 bolts holding the axle to the hub.
a good upgrade, is a 4-bolt LSD rear end from a 1g DSM. make sure you get the diff, the axles, and the axle cups that go on the hub, and you will be good to go!
citymunky
Chesapeake, VA
Also not all 3 bolts are LSD's. The stock 3 bolt rear diff with the 4WS gear is a open diff. 3 bolt diff's from early DSM's are LSD's. I have a 3 bolt LSD with a "B1G" on the decal.
JNR
ca
be aware also that automatics had different gear ratios than manuals (and I'd bet there is some other variances between DSM/VR-4, etc.) with that regard...Just make sure you either swap your gears or get the correct one to match the front, or else you'll be shopping for a T/C soon /ubbthreads/images/graemlins/grin.gif
