Question: Where can I get a new harness connector?
alansupra94
Wayne,NJ
Well, after fighting with this electrical problem for my AEM EMS, it seems to stem from a loose connection with my ECU plug. For whatever reason, jiggling the harness causes the AEM EMS to either read perfect or in this limp mode. I traced every wire and they all intact 100%. It seems to be the actual wire connection to the plug is loose because when I move the wires around or pull the plug up, AEM EMS reads fine.
SO the question is: Where can I get a new or used ECU plug?.
Right now, AEM EMS is reading fine but I don't like it being like this.
alansupra94
Wayne,NJ
Junkyards don't exist in NJ. Well they do but they charge out the ass because they have computerized pricing. Also don't really have time to go out there.
ok well in that case, if need be i can just grab you some or one. just let me know exactly which one(s) you need.
alansupra94
Wayne,NJ
Honestly at this point, I might not even de-pin the harness since the last time ended up with this problem.
I might solder and shrink wrap the hold damn thing for that connector since about 5 wires are shrink wrapped like that anyways.
broxma
San Antonio Tx
I'm headed to the yard tomorrow. Which connector do you need?
/brox
And Yes Donkey, I did eventually send yours out. Was just a delay.
raptorWagon
Oak Harbor, WA
You need one of the 3 ECU connectors? I can snip snip mine off and mail them out. My engine harness is trash, so why not? /ubbthreads/images/graemlins/dunno.gif
